Old 02-02-2008, 07:28 PM   #1
blix666
Member#: 111893
2000 Impreza OBS
"Puff-The Magic Wagon"
Default Cel
car: 2000 OBS
so, the CEL came on a few minutes ago and i won't be able to have it checked until tomorrow.
the only driveability difference is it accelerates very sluggish until about 3000 rpm's then all the sudden it picks right up. no effect out of gear in terms of throttle response...only while in gear.
any initial thoughts?
blix666 is offline   Reply With Quote
Old 02-02-2008, 08:06 PM   #2
imprexaRS03
Member#: 145883
2008 wrx
psm
disconnect your battery..wait 30 seconds and put it back on,you should hear a beep and you reset your ecu.the cel should go away.you might need to do it a few time..have you done any exhaust work ?
imprexaRS03 is offline   Reply With Quote
Old 02-02-2008, 08:46 PM   #3
piker28
Member#: 22664
^^ DO NOT DO THIS
if the cel is not flashin go to a autozone and get it read, come back here and we can help but till than its anyones guess
piker28 is offline   Reply With Quote
Old 02-02-2008, 08:56 PM   #4
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
Originally Posted by piker28 View Post
^^ DO NOT DO THIS
Seconded this. ESPECIALLY if you haven't done any modding to the car. I do do this procedure, but only because I get the phatom CEL for my Lightweights Pulleys and know what it is every time it comes on (Misfire Cyl 1 and 2).
Ohh justa quick tidbit for the lightweight pulley/flywheel guys in an 06-07 2.5i: The CEL is totally random. I say this because I got the code 7 times in a month, and finally reset the ECU and it never bothered me even when I really romped on it (which caused the CEL). 2500 miles later and the battery died on me...and now the CEL came back on because it reset the ECU again
ScubaruImpreza05 is offline   Reply With Quote
Old 02-02-2008, 08:56 PM   #5
blix666
Member#: 111893
2000 Impreza OBS
i fully plan on having the code read...i only posted to see if anybody else had a similar symptom.
i actually had a larger resonator installed yesterday. it was the first thing i thought of when i noticed the light. probably an exhaust sensor then huh?
Old 02-02-2008, 08:58 PM   #6
piker28
Member#: 22664
honestly it could be a ton of things
Old 02-02-2008, 09:03 PM   #7
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
What I would say to do is the same as above. Also just take it easy on your car until you know what it is.
allsubaru83 is offline   Reply With Quote
0136 CEL w/ Pony Express CEL "fix" lstepnio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-17-2003 05:26 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 01:53 AM
gutted uppipe, cel or no cel? recursian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2002 04:57 PM
Wierd Cel after ECU Reset, installed TurboXS TMI, No Cel in Log DiMensionX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 09:19 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 04:23 PM
