Old 02-03-2008, 12:44 AM   #1
GrundleJuice
Member#: 165749
Default AT/MT headers
Will headers for a AT fit a MT application? (TWE superstock 4-2-1) for a 07 2.5i the headers are for an '05 style setup.
Old 02-03-2008, 01:53 AM   #2
ZeppelinPie792
Member#: 160287
2007 Impreza 2.5i SE
Newport Pearl Blue
I don't see why it would matter. The gearbox is minimal in when it matters for fitting on headers. You should check other things.
ZeppelinPie792 is offline   Reply With Quote
Old 02-03-2008, 02:55 AM   #3
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
It matters, Headers not designed for AT will not clear the larger gearbox. I MT is smaller so it should be just fine. I am jealous of your TWE. lol
formula91 is offline   Reply With Quote
Old 02-03-2008, 01:45 PM   #4
GrundleJuice
Member#: 165749
yeah, i figured that the MT was smaller so clearance wouldnt be an issue but i wanted to make sure in case there was some weird shape to the MT that caused it to sit lower or something... It already looks like i may have some crossmember clearance issues but im not too worried.. i have welding equipment and everything i need to notch/cut the crossmember and reinforce it otherwise. Goodbye warranty!
Old 02-03-2008, 04:50 PM   #5
EdHilario
Member#: 137398
2004 Impreza
Hmm this only pertains to the TWE's right? Borla's for example, have the same part number/description for their headers and it doesn't specify if it's for AT or MT.
EdHilario is offline   Reply With Quote
Old 02-03-2008, 05:03 PM   #6
GrundleJuice
Member#: 165749
yeah, TWEs is what im asking about or if anyone knows for a fact that the MT gives more clearance that the AT under the car on the 06/07's.
I think the Borlas have quite a bit less tubing and dont snake around before the collector flange so maybe they fit both for that reason.
Old 02-04-2008, 06:43 AM   #7
PA-Outback2000
Member#: 161832
2000 Outback Limited
check xcceleartion.com for any questions about subarus. boxer4racing.com is slightly cheaper. xcceleration guy is sam. they are around most of the time, so if u call later in the day someone, probably sam, will answer. check them out. i am looking into them and random tech cat in the future when i get more money. haha
PA-Outback2000 is offline   Reply With Quote
Old 02-04-2008, 08:50 PM   #8
GrundleJuice
Member#: 165749
well i already have the headers and didnt know they were for AT application until i asked some questions on the phone with TWE. So im not looking for prices or who's cheapest if thats what you meant. Ill check out xcceleration.com. thanks.
Is the crossmember on the frame under the engine/transmission mating area the same for AT and MT on 06/07 2.5i's?
Old 02-05-2008, 12:39 AM   #9
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I believe the the crossmembers are the same, it's just that the AT hangs lower, which is why it's hard for us slushboxers to put on braces without spacers. But then they hit the ground. lol.
So I think they are the same, the only difference is the clearance issue of the AT size.
Old 02-05-2008, 09:47 PM   #10
GrundleJuice
Member#: 165749
cool. i was going to try anyway, but i can sleep better now that i am more confident that they will fit. Thanks for the info, guys. Ill post if i find out different.
Rallyspec, I saw you at Mt. Baker today. skyliner33v North West Impreza Club Forum -- NWIC 3 01-04-2002 04:12 AM
Silver WRX on the way home from a Night session at Mt. High? wistful Southern California Impreza Club Forum -- SCIC 0 12-19-2001 04:35 AM
Video from crash at Mt.Washington! webkris New England Impreza Club Forum -- NESIC 1 07-21-2000 08:17 AM
Subaru at Mt Washington Hillclimb suber New England Impreza Club Forum -- NESIC 4 06-21-2000 04:53 PM
