Old 02-03-2008, 12:18 AM   #1
benw
Member#: 103320
1998 swapped
Forester L
Default tuned my first 07 STI... impressions
Well today I tuned a friend's stage-2 + APS TMIC STI. I took extra precautions especially with timing, to ensure that the car was safe and smooth. I used Gabe's strategy of cloning all base timing tables, zeroing advance A and B, and applied a flattened DA on advance C and D of 6 degrees. Gabe's findings and posts helped tremendously, I hopped in and started tuning like an 04-06 and it responded right on the money.
things I like:
- tons of resolution. This is awesome, especially when tuning timing and fuel!
- ECU speed. The ECU seemed to learn and adjust VERY quickly to knock, and overall, seemed much more adept in its timing strategy.
- did I mention the resolution?
- 2007 gears are BADASS.
things I didn't like:
- more resolution means more legwork. however, it was worth it in the end, and was very smooth.
injectors were at 95% and A:F was 11.0 tapering to 10.6 at 7k. Timing was 10-12 at peakboost with a max of 23 degrees at redline (crummy 91 octane, and I think we're still on winter mix).
What are your guys experiences with the 07? I wish I had more time to play around with one!
benw is offline   Reply With Quote
Old 02-03-2008, 12:40 AM   #2
Remnex
Member#: 83790
I have two tuned 07 STIs, and they are certainly an interesting car to tune.
It's funny that you mention the resolution as I was comparing the 06 to the 07 yesterday and the difference is amazing.
Remnex is offline   Reply With Quote
Old 02-03-2008, 11:54 AM   #3
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
when you say keep all base tables the same, do you mean keep them the same as stock, or make all 4 maps identical to each other?
and i think you have a typo above talking about the advance tables... you mentioned B twice but never mentioned D.
good thread though, i'm really interested to know peoples experiences with tuning the 07 STi and what timing methods they used. its about time the definite answer on how to properly tune the 07 STi knowledge is really out there for people to find easily.
TROLL is offline   Reply With Quote
Old 02-03-2008, 11:00 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
I tuned an 07 a few months ago with the knowledge of the new timing advance tables and basing alot of it off my 04-06 STI tunes. I did notice that the cam advance seems different and it seems to like a little less AVCS over the previous years. Other than that it was great! The boost control is also different, not sure if it is a different solenoid. It took a while to get the boost dialed in properly.
blkscooby is offline   Reply With Quote
Old 02-04-2008, 12:20 AM   #5
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
The 07 is a bitch to tune. But once you have it right, it is right. You tune it like a WRX, not an STI really. 0 Advance A&B. Keep Advance C&D the same (whatever you put in there). Keep all 4 base timing the same (whatever you put in there), Only change AVCS B. Fix the knock correction ranges for FLKC (use the whole table) and FBKC ranges. Done.
I do take advantage of the lift throttle/cruise transition multiplier sometimes (not currently though) by using less timing in Base A&C (but these table match), compared to B&D (which should match).
Also, make the fuel tables the same.
Gabe
gabedude is offline   Reply With Quote
Old 02-04-2008, 12:52 AM   #6
gabedude
Member#: 10108
07 STI
Modify the ETC settings as well. I use the 07 EU STI ETC settings.
Gabe
Old 02-04-2008, 01:11 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, I would like to see the 07 EU ETC maps people keep raving about. Is there anywhere to look them up?
Old 02-04-2008, 01:31 AM   #8
benw
Member#: 103320
1998 swapped
Forester L
yes, that was a typo regarding advance tables. I zero A&B and set C&D to the same.
The EU etc settings are the things like accelerator pedal which have a MARKED improvement over the USDM settings.
Old 02-04-2008, 01:32 AM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That's what I've heard, and that's why I want to see what they do different.
Old 02-04-2008, 02:00 AM   #10
gabedude
Member#: 10108
07 STI
The stock ETC settings go from 20% to an 80% jump. No linearity at all. Here is may Stage 1 map to start tuning a stage whatever with. You want the V2 Roms.
Gabe
http://www.xpttuning.com/osecuroms/v...php?f=21&t=811
Old 02-04-2008, 02:04 AM   #11
gabedude
Member#: 10108
07 STI
I run 12.5:1 tapering to 11.3:1. 20 PSI Peak.
94% IDC at 32 degrees out.
This pretty much matches Dataloglab:
Mods:
APS 65 MM CAI
3 Inch Catless TBE (Bellmouth D/P)
My modified XPT stage 2 APS 65 MM CAI map (it is included in the XPT package)
Meth is going on next.
Old 02-04-2008, 02:25 AM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oh man, that's A LOT different and A LOT more complicated than the DBW NA mapping. Stock, both the Requested Torque and Target Throttle Plate Angle tables are the same in all RPM rows AND the column headings are 0, 10, 20..., 80, 100. Then each column is filled with whatever the column heading is. In other words, the stock mapping makes throttle plate angle track accell pedal angle exacty. This results in the throttle pedal being more of an on-off switch because 80% of max torque at any RPM is reached in less than 35% of the pedal travel.
I logged accell pedal angle, load, and RPM. I then plotted the %pedal angle against the % of maximum load. This gave me a curve that looked a little like log(x) but with a sharper knee. I then changed the Requested Torque table so the requested torque is 1/2 the pedal angle %. This has almost eliminated the driveline bounce near idle, given a much more linear power delivery, made shift timing easier (because the engine now begins to fall off as soon as you pick up your foot rather than floating until you get your foot OFF the pedal), and has made the car MUCH easier to control with the throttle in a slide.
I'm going to have to put some serious number crunching into those ETC tables in your STi ROM, gabe. I'd like to figure out why they're varying the mapping with RPM. Do you think it has to do with keeping a given pedal % at a given % of max load as you guys come on boost?
Old 02-04-2008, 04:18 AM   #13
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
like most people have been saying the 07 STi ECU is a pain to start with, but once to figure it out and get it dialed in, its amazing.
I actually made my own request throttle maps instead of using older or EU maps
Benchmark Tuning is offline   Reply With Quote
Old 02-04-2008, 09:41 AM   #14
gabedude
Member#: 10108
07 STI
My EU mapping is not an exact copy, but it gives a 1:1 pedal relationship.
I alos have a soft rev limit (50%) throttle cut at redline to aid in powershifting.
Old 02-04-2008, 03:00 PM   #15
Benchmark Tuning
Member#: 154444
I have my maps set-up 1:1 as well, I have seen the stock DBW maps, and I've set-up both for trial. I found that the way I set mine up gave smoother all around throttle response opposed to all the other mappings that I've tested.
yep...power shifting is fun
Old 02-08-2008, 11:15 AM   #16
max07sti
Member#: 168522
2007 sti
blue
Sounds awsome. I'm going to have to keep researching before I get mine done or attemped it.
max07sti is offline   Reply With Quote
WTT: Norcal: WRX or STI limited leather interior for my mint 07 STI interior wrinklefree Private 'Wanted' Classifieds 3 02-26-2008 07:56 PM
Just bought my first new STI. coming from the Audi world Icon Newbies & FAQs 17 01-24-2008 12:19 AM
First 07 STi Mod Handsome_Rob Newbies & FAQs 31 09-28-2007 08:58 AM
spotted my first 06 sti... martel South East Region Forum 20 08-12-2005 01:39 PM
SUPER JDM GDA TUNE ! my first win at a car show check out these pics...! PomonaWRX Member's Car Gallery 77 12-10-2003 02:33 AM
