Old 02-03-2008, 11:21 PM   #1
Subiemaddness
Member#: 162388
2006 Jr built
511whp on pump : )
Default GT30R .63 VS GT30r .82
I am looking for a daily driver and to run around 400 whp? I will be also running a TMIC which kit should i go with?
Subiemaddness is offline   Reply With Quote
Old 02-03-2008, 11:26 PM   #2
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
you wont get there with the .63. You will need the GT3076R with the .82
Stames_wiltz is offline   Reply With Quote
Old 02-03-2008, 11:28 PM   #3
Subiemaddness
Member#: 162388
2006 Jr built
511whp on pump : )
how will the spool be on the.82 compared to the .63
Old 02-03-2008, 11:34 PM   #4
Stames_wiltz
Member#: 143264
2006 WRX TR
Marginal at best... the .63 will probably spool about 100-200 rpm faster but will choke the motor with backpressure. the .63 was designed for the 1.8-2.0L engine. for the 2.5 you NEED the .82 the spool would be barely noticeable and the power difference up top would be huge.
Old 02-04-2008, 12:02 AM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I loved the .63 on my 2.5L, spooled about 400 rpm earlier than the .82. My car did 380 WHP on pump with the .63 at 24 psi. The .82 made 410 WHP at the same boost. The the street I would stock with the .63. You can always move to the .82 in the future, you can buy just the .82 exhaust housing.
mick_the_ginge is offline   Reply With Quote
Old 02-04-2008, 12:42 AM   #6
flycaster
Member#: 60142
2011 WRX
Grey
My experience mirrors Mick's to the T. What the .63 gives you below 5.5K, the .82 gives you above 5.5K. It all boils down to where you want the powerband, and how spool sensitive you are.
flycaster is offline   Reply With Quote
Old 02-04-2008, 11:02 AM   #7
wittmer25
Member#: 102970
2004 STi gt30r
I went from the stock vf39 to the 30r w/ .82 AR turbine housing. Peak torque moved from around 3.5K rpm to about 4.0K-4.2K rpm. But the increase in power is so much that it is worth the wait. Save yourself the money (from switching turbine housings in the future, .63 to .82) and go with the larger turbine housing. You wont regret it.
wittmer25 is offline   Reply With Quote
Old 02-04-2008, 12:32 PM   #8
STIBungy
Member#: 51684
My spoolup was the same going from a .63 to .82 when I added a Gruppe-S unequal length header that was also wrapped. AVCS tuning on my car wasnt changed: 30 degrees up to 4k rpm and then tapers off.
Top end was definitely noticeable between the 2 housings.
STIBungy is offline   Reply With Quote
GT35R .63 or GT30R .82? A data-driven debate on spool-up, top-end, & risk of surge ka mano Proven Power Bragging 123 12-24-2008 04:23 PM
Turbo spool times and power - T3/T04S .63 vs .82 WhiteWoRX1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-05-2007 10:48 PM
Actual comparisons!! GT30R .63 / .82 bigmike25rs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 80 08-22-2006 01:22 PM
GT30R .63 housing vs. .82 housing logs DarthChicken Proven Power Bragging 73 08-01-2006 12:11 PM
Sale or Trade: GT30R .82A/R FS or Trade for GT30R .63 A/R 04RCSTI Private 'For Sale' Classifieds 8 05-23-2006 07:19 PM
