Old 02-04-2008, 10:49 AM   #1
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Default Tuning to remove boost spike after UP/DP/Monster TD04 upgrade
Hiya all... need some some quick advice.
I've upgraded my UP/DP and turbo to a Monster TD04 and now I'm gettng a nasty boost spike on WOT. I'm scheduled to take my car to a rally this weekend, and need to get this quickly tuned out so I don't hit boost cut.
Where should I start looking? Any quick tuning advice on how to rapidly remove this spike?
Thanks,
-Eric
Geek Guy is offline   Reply With Quote
Old 02-04-2008, 11:24 AM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
WG duties and TD are your parameters to play with
Hyper is offline   Reply With Quote
Old 02-04-2008, 02:01 PM   #3
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
I'd start with dropping Wgdc jut before, and during the spike. Then set targets and tune the wgdc to them.
ExpO is offline   Reply With Quote
Old 02-04-2008, 02:19 PM   #4
Tgui
Member#: 44771
Disable the spool and puddle option in the 12mph table as well. I'd also disable the "reentry is not a bitch" option.
For real though watch that WGDC. Altering TD to might help boost oscillation as well. Mayhaps look into a prodrive BCS.
Tgui is offline   Reply With Quote
Old 02-04-2008, 02:31 PM   #5
Geek Guy
Member#: 8151
2002 WRX Rally Car
Guys, thanks for the advice. I'll try to give it a shot tonight. Regarding the BCS, no time; event is this weekend, so I'll need to address the issues asap.
I can't remember offhand - are the wgdc and td variables a 3d table, or just a single linear option?
Thanks,
-Eric
Old 02-04-2008, 02:55 PM   #6
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Thanks,
-Eric
Both are 3d (rpm x throttle)
Old 02-05-2008, 05:10 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
for a short run fix since you need it this weekend, you should just tweak the WSGT DC's. The turbo dynamics will take you more time, since you havent done it before.
Also, I had the same problem on my td04 and spent weeks tweaking it in my spare time and could never get rid of it. I was using the stock BCS and I also tried a MBC. Then i slapped a 16G on and used the stock BCS and the dip was gone without changing any of the turbo dynamics values. I chalked it up to the wastegate on teh td04 sticking or something like that.
Old 02-05-2008, 09:15 PM   #8
Geek Guy
Member#: 8151
2002 WRX Rally Car
What do you folks use to log wgdc? It doesn't seem to pull up with Enginuity.
Thanks,
-Eric
Old 02-05-2008, 09:18 PM   #9
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Enginuity. Are your definitions up to date?
Old 02-05-2008, 09:31 PM   #10
Geek Guy
Member#: 8151
2002 WRX Rally Car
I thought so - I checked the site, and the file is dated Dec 3 2007 on my laptop. I don't see anything in the list associated with WG, only the turbo dynamics stuff.
Old 02-05-2008, 10:27 PM   #11
Tea cups
Member#: 103136
it's called "primary wastegate duty cycle"
Tea cups is offline   Reply With Quote
Old 02-05-2008, 11:29 PM   #12
Geek Guy
Member#: 8151
2002 WRX Rally Car
I'll have to check again... I didn't see it in the list, but will double check in the AM
Thanks guys!
Old 02-06-2008, 04:39 AM   #13
Tea cups
Member#: 103136
it is a standard SSM parameter. It is there.
Old 02-06-2008, 11:41 AM   #14
Geek Guy
Member#: 8151
2002 WRX Rally Car
Found the parameter this AM. Not sure why I didn't see it last night.
Anyway, tried to romp on the car to do some datalogging, and couldn't get it to hit on boost cut. Held strong to 17psi, so I guess I'll just chalk it up to fix later.
Thanks fellas!
-Eric
Deadbolt Monster TD04 upgrade question KB21 Newbies & FAQs 39 08-27-2008 03:01 PM
boost spike after installing tmic skubie209 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-02-2006 11:20 AM
boost spike after Samco IC install on 4EAT engr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-23-2005 10:25 PM
Boost Spiking after silencer removal timjgx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-03-2004 12:41 AM
Anyone w/ Cobb Tuned Unichip Get Boost Spikes? bedabi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-12-2001 07:34 PM
