Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-04-2008, 11:30 AM   #1
hrmax
Member#: 37216
2004 STI
Question Where to turn rotors?
I am planning on replacing the pads on my STI, as well as install some SS brake lines, but I was planning on having the rotors turned as well. Car has never been tracked and has only had OEM pads so I think I can get away with just turning them. Any know a good place? Thanks!
-Max
hrmax is offline   Reply With Quote
Old 02-04-2008, 11:31 AM   #2
bObby
Member#: 66959
04 STi and E46
M3
sears autocenter
bObby is offline   Reply With Quote
Old 02-04-2008, 11:39 AM   #3
hrmax
Member#: 37216
2004 STI
Originally Posted by overboost View Post
sears autocenter
How much do they charge?
Old 02-04-2008, 12:18 PM   #4
racingfish
Member#: 60976
1969 LGT
FATURBO
sears autocenter
lol.....
racingfish is offline   Reply With Quote
Old 02-04-2008, 12:18 PM   #5
racingfish
Member#: 60976
1969 LGT
FATURBO
sears autocenter
lol.....
and walmart is a good place to get a turbo put in.
Old 02-04-2008, 12:33 PM   #6
Jim.mEh
Member#: 84517
05' Imprezilia
CruiseControl Warrior
^^ They are just rotors. rotors aren't subaru specific? or turbo knowledge specific?
spinning rotors are all mechanically operated? "just set it and forget it"?
Jim.mEh is offline   Reply With Quote
Old 02-04-2008, 12:36 PM   #7
racingfish
Member#: 60976
1969 LGT
FATURBO
considering the brakes.... yes and no.
im sorry i should have said get your oil changed at walmart. Ive repaired blown engines and trannys from walmarts mistakes... and all steming from oil changes.
Old 02-04-2008, 01:01 PM   #8
LegacyGt05
Member#: 80074
2007 BMW 335i
Sapphire Black Metallic
Why do you need your rotors turned? are they warped?
LegacyGt05 is offline   Reply With Quote
Old 02-04-2008, 02:11 PM   #9
hrmax
Member#: 37216
2004 STI
I am putting new pads in so I want to make sure the rotors are fresh and groveless as I don't want to buy new rotors.
Old 02-04-2008, 02:14 PM   #10
racingfish
Member#: 60976
1969 LGT
FATURBO
its a good idea to have them turned when repalcing pads.
Old 02-04-2008, 02:15 PM   #11
Race4thaG's
Member#: 87101
2004 WRX vf34
Subaru Tech
if there not warped just throw pads on(STI only), machining your rotos will just make it run hotter and make them, more prone to warping
Race4thaG's is offline   Reply With Quote
Old 02-04-2008, 04:26 PM   #12
LegacyGt05
Member#: 80074
2007 BMW 335i
If you bead them in properly, you don't need to get your rotors turned if they are in good shape, that's what I have been told. I have been running my HPS pads for a while with no issues.
Old 02-04-2008, 11:37 PM   #13
jmh
Member#: 28568
09 G8 GXP
silver/silver
Race 4 g, have you tried this technique yourself?
jmh is offline   Reply With Quote
Old 02-05-2008, 01:04 AM   #14
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
+1, I've done my fair share of motor repairs/replacement due to Walmart F-ups. They really like to drain Auto trans on VW's and overfill the engine oil. Dumbf***s.
John2.5RS is offline   Reply With Quote
Old 02-05-2008, 01:06 AM   #15
John2.5RS
Member#: 1140
'13 F150 Ecoboost
There's a shop right down the road from where Kevin's shop, JDM importers was. They do great work, I've had them turn a few sets of rotors for me. They only charge $5 even a piece.
I have, it's called, "pad-slapping". Not the best thing to do, but I've done it before, (even on my own vehicle) without any problems. As long as the rotors aren't warped or glazed, there's not a nasty lip on the rotors, and there's enough material in the rotor to last the life of the new pads, you should be good.
Old 02-05-2008, 08:25 AM   #16
hrmax
Member#: 37216
2004 STI
Do you happen to remember the name of the place?
Old 02-05-2008, 10:06 AM   #17
DroppedClutch
Member#: 52313
2005 STiOmgWtfBbq20G
2007 MS3 Black
5 bucks? That's a deal. OP, Brakes Plus will also does it. $15 each if off the vehicle, iirc.
DroppedClutch is offline   Reply With Quote
Old 02-05-2008, 11:26 AM   #18
TixArmy
Member#: 134248
2007 STi-Stage2 -RIP
"Desert Sand on White"
waaa - wait a min hear... we are looking at this All Wrong.... So your car works its way up to 60K miles... Let Walmart change the Oil !!
who wouldn't want a new engine?
TixArmy is offline   Reply With Quote
Old 02-05-2008, 02:29 PM   #19
John2.5RS
Member#: 1140
'13 F150 Ecoboost
I'll get the name & # for you when I'm in the area.
Old 02-07-2008, 05:40 AM   #20
John2.5RS
Member#: 1140
'13 F150 Ecoboost
Tempe Tune-up & repair.
(480) 345-2566
Old 02-07-2008, 06:02 AM   #21
rudeboy_sti
Member#: 124829
2005 STI
WRB/Gold
Autozone, Checkers and Napa will also turn your rotors. When I had my truck and my RS, I used to have Autozone do mine for $7 a rotor.
rudeboy_sti is offline   Reply With Quote
Old 02-07-2008, 08:40 AM   #22
hrmax
Member#: 37216
2004 STI
(480) 345-2566
Many thanks!
Old 02-07-2008, 09:40 AM   #23
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Don't turn your rotors to put new pads on. As others said, it will only make them thinner and more prone to warping. I was a mechanic for years, anyone that tells you that is trying to make a buck. If you are worried about the pads glazing/not seating properly... rough up the surface of the rotors with a piece of sandpaper.
you only need to turn rotors when they are warped, period. If they have heavy grooves, then they need to be replaced. Small groves the pads will seat into quite quickly.
irascible is offline   Reply With Quote
Old 02-07-2008, 09:52 AM   #24
hrmax
Member#: 37216
2004 STI
If the rotors are warped, shouldn't they be replaced and not machined? Even if you machine warped rotors, they won't be balanced.
Old 02-07-2008, 10:05 AM   #25
Caliente Auto
Member#: 59051
2004 WRX Sedan
Okay here is reality. You need to have the rotor thickness checked. We have never mic'ed STI rotors that were not already at minimum spec once the pad life is done.
STI rotors have very little material variance, in other words, they are meant to be changed when you change your pads. I know many on here will debate this but the answer lies in having the rotors mic'ed. If AT or BELOW min thickness they should be replaced, period.
I agree don't turn them. As I've said every time we mic used STI rotors they are already at min so obviously turning them isn't a good idea.
Unfortunately the STI is a performance vehicle and the braking system was designed for performance not necessarily for pad and/or rotor life.....
Caliente Auto is offline   Reply With Quote
Where to get rotors turned in Austin? ronan1975 Texas Impreza Club Forum -- TXIC 5 04-06-2009 05:33 PM
So when to turn rotors and when not to turn rotors... Brahmzy Brakes, Steering & Suspension 2 01-11-2006 01:43 AM
DFW: Where to turn STi Brembo Rotor? salaki Texas Impreza Club Forum -- TXIC 11 12-05-2005 06:00 PM
Fort Worth / Haltom City - where to get rotors turned? wcbjr Texas Impreza Club Forum -- TXIC 5 03-07-2005 11:28 AM
Chicago: Where to get rotors turned? STIRS Mid West Subaru Owners Club Forum -- MWSOC 2 08-16-2003 08:25 PM
