Old 02-04-2008, 05:42 PM   #1
450STi
Member#: 170429
2004 STI
P Sliver
Default what stage STI would this be and does it sound like i good set up
gt3076r on sti and know about how much it would put out with a good tune turboxs utec and the man boost controler that come with aps intake perrin big maf pipe (3in) aps inlet neck and stage 2 snowperformance meth inject invida divorced waste gate dp invida gt200 cat back 255 wal fuel pump and perrin fuel rails and 850cc injcetors
and dr725 fmic
450STi is offline   Reply With Quote
Old 02-04-2008, 05:45 PM   #2
schiarelli
Member#: 152896
2002 WRX psm wagon
For Sale!
that would be past stage 4. Im no expert, but I would GUESS you would be pushin more than 450 whp with that setup
schiarelli is offline   Reply With Quote
Old 02-04-2008, 05:47 PM   #3
fastlanerex
Member#: 133391
2004 boosted saleen
white
do some research on here bro youll be suprised what youd find as far a stages it would be a stage 4 i guess. thats a nice setup for a DD sti perrin gt30r kit's are amazing my friend has one on a stock internal sti with meth made 450whp. hope that helps.
fastlanerex is offline   Reply With Quote
Old 02-04-2008, 05:50 PM   #4
450STi
Member#: 170429
2004 STI
P Sliver
no 450 460 to be safe and i am type not to turn up every day i have turboxs utec and the man boost controler that come with aps intake stage 2 snowperformance meth inject invida divorced waste gate dp invida gt200 cat back 255 wal fuel pump right now and it puts down 302whp and 370wtuq not shure how harsh of a tune that is but the other stuff is here just havent got it on yet
Old 02-04-2008, 05:53 PM   #5
450STi
Member#: 170429
2004 STI
P Sliver
that what i am hoping for also the turbo kit is from ATP performance what a .63 a/r stock mount they say rated for 500whp no problem
Old 02-04-2008, 05:54 PM   #6
450STi
Member#: 170429
2004 STI
P Sliver
thanks for the info
Old 02-04-2008, 06:50 PM   #7
elusiv
Member#: 170501
PSM TXS Stage Eleventy
You're gonna end up tossing that boost controller anyways when you get a better boost solenoid, which is highly recommended for a larger setup.
My advice, DON'T OVERBUILD A CAR. What I meant by that is if you are new to cars in general or even a specific model that you don't know much about, don't jump balls in unless you are quite wealthy. Things WILL break. You WILL have to do extra maintenance. If you can't do a lot of it yourself you're going in over your head.
elusiv is offline   Reply With Quote
Old 02-04-2008, 07:18 PM   #8
Badler
Member#: 133597
Originally Posted by 450STi View Post
gt3076r on sti... ...invida divorced waste gate dp...
Is this a bolt on? No EWG?
edit: Just saw that it is a bolt-on. Don't expect rotated 30R#'s like people have been quoting. Probably not even close actually.
Badler is offline   Reply With Quote
Old 02-04-2008, 07:20 PM   #9
240STi
Member#: 130400
08 Evo X
Here I COME!!!!
learn to type a correct sentence using periods and commas, cause I could not understand what you have or want to do with what you have.
240STi is offline   Reply With Quote
Old 02-04-2008, 07:30 PM   #10
Badler
Member#: 133597
I bet you have no idea of what a 450whp STi even feels/drives like, most don't. Driver should be your first mod, not a 30R.
Old 02-04-2008, 07:39 PM   #11
waktasz
Member#: 86356
2015 s1000r
wheelie monster
That's what I was thinking. I couldn't tell if he was thinking of buying one, or upgrading his to that level or what.
waktasz is offline   Reply With Quote
what does it sound like? againstdan Newbies & FAQs 6 10-14-2008 09:18 PM
UP / DP Exhaust Leak / WG Flutter - What does it sound like?? Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-10-2005 12:49 PM
Exhaust leak - what does it sound like? shoooter_j Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 10-31-2004 08:30 AM
What does it sound like??? silvscorp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-09-2004 11:52 PM
What does it sound like when your turbo fan is clipping? 0260B4U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-10-2003 02:38 AM
