Old 02-04-2008, 08:33 PM   #1
pints99
Member#: 100020
Default 06 sti throwing codes and hesitating badly
I recently passed the 2 year mark on my car and have currently 73,000 miles. Most especially when cold, but still sometimes when the car is warm, the car will hesitate and buck under partial throttle (~5-15% throttle). I recently had my 60,000 mile service which replaced my spark plugs, so I'm pretty sure they are not the issue. My accessport pulls codes p0301, p0302, p0303, p0304, and then gives me to sets of question marks, I guess it doesn't know the other codes or is confused otherwise. I've made an appointment with subaru to check it out, however I was wondering if anyone else has had a similar problem and could share it with me. Only mods are the accessport set on stage one 91 octane map. Reverting to stock map does not alleviate the issue. Thanks for you help guys.
I have checked the code lists online and those 4 codes indicate misfire on cylinders 1-4.
pints99 is offline   Reply With Quote
Old 02-04-2008, 08:39 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
the accessport isn't a code reader. go to a local parts store and use their obd2 code reader instead.
report back.
Old 02-04-2008, 09:05 PM   #3
makeawish
Member#: 170697
I'm no mechanic, but I do troubleshoot computers and 90% of the time the cause to a problem is something that recently changed. Were the plugs changed 13,000 mile ago or recently..
If it was recent and the only change was your plugs, maybe they are bad. Just because they are new doesn't make them good. Could be wrong part number, wrong gap, bad connections...
then again it could be anything.. I wish you luck and hope it's a $2 part. please post a followup when it's diagnosed..
makeawish is offline   Reply With Quote
Old 02-04-2008, 09:51 PM   #4
pints99
Member#: 100020
The problem began before the maintenance. I thought it was the plugs too...but they have since been changed and the problem remains. I've tried a few different maps on the computer and reverted it completely to stock and none of that seems to work. That leads me to think it's a mechanical problem. It's much less or non-existant after the car has been running 10 minutes or so.
Need new Tires for 06 STI, throw me some suggestions. REX_22 Tire & Wheel 0 01-17-2010 12:30 PM
STI Throwing Codes jmanSTI Texas Impreza Club Forum -- TXIC 11 02-26-2007 02:52 PM
STI Throwing Codes? jmanSTI TXIC Private Classifieds 2 02-25-2007 11:58 PM
STi throws cel and crazy idle!! why???? intpostman23 Service & Maintenance 3 02-07-2006 11:44 AM
'04 STi Stalling, sputtering, and hesitating feeling at WOT R&D Auto Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 06-28-2005 05:39 PM
