Old 02-04-2008, 08:43 PM   #1
MIKE DD
Member#: 106818
2003 Truck
Default Car Shudders when i shut it off??
Just flashed a new map to my car and only drove for a few miles nice and easy.
When I shut it off the car shudders, is this normal for a new map?
02 wrx
TBE
CAI
Stage 2 XPT map
and yes i've posted this everywhere.
MIKE DD is online now   Reply With Quote
Old 02-08-2008, 01:00 PM   #2
MIKE DD
Member#: 106818
2003 Truck
I've been told it may be the CAI i'm using, it's an Injen. Any other ideas? Looks like i might have to commit the MAF scaling thread to memory, and go that route.
Old 02-08-2008, 01:11 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
did you had the intake on before the new map?
did it shudder then?
testes1010 is offline   Reply With Quote
Old 02-08-2008, 03:52 PM   #4
MIKE DD
Member#: 106818
2003 Truck
Intake was on when i bought the car, never shuddered. I've owned the car for almost 4 years. Flashed the map, drove the car down the street and came back and shut if off and it
happened. Been running the same map since Monday, doesn't really make any noise, and it does feel like it's coming from the passenger side.
Old 02-08-2008, 03:55 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
If the car didn't shutter before the map reflash, its not the intake unless he done some MAF rescaling but I can't imagine that he would for a STG2 map. Flash it back to stock & see if it does it then.
Old 02-08-2008, 04:25 PM   #6
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Log the fuel trims at idle. If the car isn't having trouble keeping the AFR at 14.7 then it isn't the map's fault.
Is it better to leave a car started for a couple mins or shut it off? aboogabooga General Community 79 11-14-2008 04:11 PM
car runs fine everywhere. turn it off and try to restart it and it will not start chibich Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-21-2007 01:06 PM
macbook pro turns off when i shut it WrxWonderWagon Off-Topic 10 01-10-2007 11:45 AM
Air conditioning smelly when I turn it off wayoutwest Service & Maintenance 7 04-11-2004 08:39 PM
Pros and cons of not using ABS? How do you shut it off? mrtrex Brakes, Steering & Suspension 19 01-21-2004 03:15 PM
