Old 02-05-2008, 12:20 PM   #1
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
Default Rear O2 Sensor Code P0037
Searched my butt off on this, found a ton of info, but still have some questions.
Car- 2003 wrx wagon 108,000 miles
mods-
Vf30
sti pink injectors
255 fuel pump
sti top mount
perrin up pipe
full borla CATLESS exaust (wish i had cats but car came with it.)
cobb AP v1.0 with protune
hallman MBC
resonator delete
k&n filter
Now with that said i have a CEL b/c of code P0037. Rear O2 sensor( which i think is just a NB).
Since the current conditions here in colorado (had 36in of snow in the last 7 days) have prevented me from getting under the car to look @ the wires to visually inspect it, i know if the wires are bad ill just get a ne sensor no big deal.....
but if the wires are OK and the sensor itself is bad, is that b/c of the catless exaust or did it just go bad? Im trying to figure out is this something i should replace or will it just throw the code again after i put a new sensor in.
any help would be great.
ozzy370 is offline   Reply With Quote
Old 02-05-2008, 02:36 PM   #2
Haelan
Member#: 151045
2013 Subaru STI
CBP
Heated O2 sensors have a lifespan of roughly 100,000 miles. Seeing that you have 108k and assuming it's the original sensor--it might have just been it's time to die.
P0037 is REAR O2 SENSOR HEATER CONTROL CIRCUIT LOW (BANK 1 SENSOR 2)
The heater element of the sensor could be toast or it could be shorted to ground if your wires were somehow burnt. Either way replacing the sensor with the attached pigtail / wire harness will fix your issue.
Haelan is offline   Reply With Quote
Old 02-05-2008, 04:05 PM   #3
hondaeater69
Member#: 60324
that code should have been defeated by your protune. contact your tuner.
Old 02-05-2008, 04:34 PM   #4
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
as soon as i do i reflash it goes away for all of 10 seconds and then pops back on. from what i have been reading that code is not taken away by the AP. But i really have no clue. i trush my tuner but i will give him a call
Old 02-05-2008, 04:49 PM   #5
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
by the way i had this code before the protune. if i did a reflash with AP with a generic cobb map (vf30 with 91 oct) it would go away until i would have a boost cut @ 19 psi and was running rich (10:1). the car is now running 16psi max and of course does not have the boost cut and has been leaned out to about 11:1
Old 02-05-2008, 07:01 PM   #6
hondaeater69
Member#: 60324
well running catless that sensor is useless. all codes associated with that sensor should be defeated.
Old 02-05-2008, 07:12 PM   #7
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
so i really should not replace the sensor? and just have the code masked?
Old 02-06-2008, 11:03 AM   #8
hondaeater69
Member#: 60324
you realize that particular sensor has one function... to monitor the efficency of your DP cat. you don't have any, as you know . i don't even have my rear 02 sensor plugged in
Old 02-06-2008, 11:14 AM   #9
Haelan
Member#: 151045
2013 Subaru STI
CBP
+1
I agree, it's really only there for emissions purposes. It ensures you don't have any exhaust gases bypassing the cats between the front and rear O2 sensors via a leak.
Being catless you can run without the rear sensor. I'm the type who wants to make sure everything on the car is functioning the way it is supposed to, or it bugs the crap out of me.
Old 02-06-2008, 04:07 PM   #10
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
yeah. i really just cant stand that CEL staring at me. i no it no big deal but im just trying the most efficent way to deal with it so it wont come back on
Old 02-06-2008, 04:15 PM   #11
Haelan
Member#: 151045
2013 Subaru STI
CBP
If you're using the Cobb AP with the VF30 91 Oct map these codes should be defeated:
CEL Codes Defeated [WHEN USING AS BASE MAP] (** means new to latest revision):
P0037 - Rear O2 Sensor Heater Control Circuit Low
P0038 - Rear 02 Sensor Heater Control Circuit High
P0137 - Rear O2 Sensor Low Voltage
P0138 - Rear O2 Sensor High Voltage
P0139 - Rear O2 Sensor Circuit Slow Response
P0420 - Catalyst System Efficiency Below Threshold
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas)
P1312 - Exhaust Gas Temperature Sensor Malfunction
P1544 - Exhaust Gas Temperature Too High
I wonder why it is still showing up...did your tuner somehow re-enable it?
Old 02-06-2008, 07:18 PM   #12
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
It is a protune. Thats what im thinking, he almost had to. b/c before i had the tune i was using the generic cobb map and it would disappear until i would hit boost cut then i would get it again. now if i reflash with base map on the pro tune it stays off for 10 seconds and comes back up
???? need to talk to tuner ........
Old 02-06-2008, 07:18 PM   #13
hondaeater69
Member#: 60324
protuner's often have their own base maps they start with, with their own parameters. chances are, for whatever reason, the tuner didn't have that DTC defeated. it just takes a simple phone call, email, reflash and you're done.
Old 02-22-2008, 04:42 PM   #14
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
OK.... called tuner... got new maps. reflashed with base and realtime maps. CEL defeated. went on 10 min drive... everything ok. (this was on a wends night if it matters)
so i go and start it today (friday) after 5 seconds of running...not driving the CEL throws again. so i reflash with just the real time map again. still have CEL. im trying not to reflash basemaps due to limited basemap flashes? so i have heard.
ANY HELP!!
i am also waiting on my tuners resonse to this
Old 02-22-2008, 10:28 PM   #15
SDgoods
Member#: 156130
1973 240z Turbo
my rear 02 went bad (i think from my catted dp) and i just simply replaced the sensor and cleared the code with a universal scanner... all good now. (duno if that helps but that is a simple solution)
SDgoods is offline   Reply With Quote
Old 02-23-2008, 05:09 AM   #16
561wrx
Member#: 166427
03 wrx
[IMG]file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]Step 1 - 5
Step 6 - 7
561wrx is offline   Reply With Quote
Old 02-24-2008, 01:37 PM   #17
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
561wrx
what was that post ?
Old 02-24-2008, 02:08 PM   #18
hondaeater69
Member#: 60324
ANY HELP!!
R/T reflashes don't help with defeating CEL's. that logic is contained in the base map. don't worry about using all your flashes, you NEVER WILL. given that, if it didn't work the first time, it wont work the second time. either you flashed the wrong map, or they didn't fix it.
btw, w hen you flash a base it contains all R/T information, no need to waste time flashing the R/T right after you flash the base. the only time you would flash a diff R/T map is if it contained different parameters than the base map... eg a high boost, 100 oct tune etc.
Old 02-24-2008, 02:11 PM   #19
hondaeater69
Member#: 60324
i'm going to PM you my email. email me back the map and i will see if i can open it in street tuner to see if they did indeed defeat that code. if you want...
Old 02-24-2008, 07:02 PM   #20
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
thanks very much, email sent
Old 02-25-2008, 05:27 PM   #21
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
talked to tuner today. said he deleted code P0420 not code P0037. he said that he didnt want to delete it b/c it was an important code and that the o2 sensor needs to be replaced. i will replace the o2 sensor but i wil not be able to till this summer. but i have also heard that that rear o2 is a narrowband and that it really is not important and is essentailly there for emissions. Is this correct?
Old 02-28-2008, 02:51 PM   #22
hondaeater69
Member#: 60324
it's not important at all, it is there to monitor cat efficiency, and you don't have any . there's no need for me to look at the maps, he admitted the problem. that code does not mean the sensor is bad. ask him again, nicely to remove the code, that you will accept all liability. My oem rear 02 sensor isn't even plugged in
FYI Cobb's map's defeat this code also. and i wouldn't go about replacing the sensor... that doesn't make any sense. unplug the sensor from the harness, get the right map, reflash and you're done.
Old 02-28-2008, 04:20 PM   #23
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
i also heard that 02-03 and 04 up are a bit different. is there any truth to the different ecu and what the rear 02 sensor is for?
Old 02-28-2008, 04:20 PM   #24
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
Old 02-28-2008, 04:36 PM   #25
hondaeater69
Member#: 60324
the ecu's are differnet, but the sensor's function is the same.
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
Driving with an O2 sensor code Gonz#75 Rocky Mountains Impreza Club Forum -- RMIC 24 07-17-2009 06:07 PM
FS (OH): WRX/STi rear o2 sensor, MAF sensor, MAP sensor coolblue05 Engine/Power/Exhaust 14 07-07-2009 02:52 PM
FS: 05 STi Front A/F Sensor and rear o2 Sensor - Brand new in box! Timmy Burns Engine/Power/Exhaust 3 01-24-2008 10:38 AM
how to get rid of rear o2 sensor code with Utec and Tuner in a 05? bustaman Engine Management & Tuning 6 06-13-2005 04:59 PM
