Old 02-06-2002, 12:46 AM   #1
Andrew
Member#: 1170
2005 STi
Default Need to get new piston rings, where to get?
What it says up there. I need new piston rings, so where do I get them other than Subaru? I'd like some stronger than stock ones if possible. thanks.
Andrew is offline   Reply With Quote
Old 02-06-2002, 08:29 AM   #2
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Try Cobb Tuning....
Fitz
Fitz is offline   Reply With Quote
Old 02-06-2002, 08:49 AM   #3
Jay_UK
Member#: 296
Most (read virtually all) rings fitted to replacement pistons use standard subaru rings.
Its not normally the rings that fail, but the ring lands.
I suppose you could try some "total seal" rings, measure up the stock rings and see whats available. (no experience of them though)
J..
Jay_UK is offline   Reply With Quote
Old 02-06-2002, 12:16 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I would stay away from Total Seal for turbo applications. Although I use them in my N/A high horsepower motors, the tolerances and gap they run is to close for turbo apps and we have had some trouble with them. Stock Subaru rings should be fine.
Eric
Eric SS is offline   Reply With Quote
Old 02-06-2002, 03:00 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I think it took about 3 weeks or hard-ish driving on a cracked piston for me to break the stock ring out of the piston. Unfortunately for me, it's hardened and it didn't just slip past the valves and turbo without cauing trouble, like the piston chunk did. :-/
EJ20G Piston Rings, where to get them? MeanEditor Built Motor Discussion 7 04-11-2008 12:38 PM
help! Where do I get NEW o-rings for sti pinks? DieselClown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-28-2006 03:01 AM
HELP:jdm V7 sti 2.0 piston rings?!!?where?!?! xtian Built Motor Discussion 7 10-29-2006 03:00 PM
Need new clutch? and Where to get it? FastWagon Canada Region Forum 3 04-22-2005 03:51 PM
Need a new/used wheel - where to get, best prices?? (Oncoming traffic blows) JLow03 Legacy Forum 8 07-01-2004 11:49 PM
