Old 02-06-2008, 01:13 AM   #1
viaburn26
Member#: 167272
2004 STi
Default Gruppe-S Headers And Primitive Skid Plate
will i have any issues putting the 3/16th plate on over the gruppe-s unequal length headers ?
my mods right now are
2004 Aspen White STi - Cusco Engine & Tranny Mounts , Kartboy Rear Subframe Outrigger Race Bushings , Kartboy Pitch Stop , TiC Subaru Rear Diff Mount Race Bushings , TiC Tranny Crossmember Bushings , Whiteline Rear Sub Frame Lock Down Bolts , Cobb AP Stage 2 Map , Xs Power Tmic , Dual Nrg Catch Cans , Freddies Hose and Mount Kit , Gruppe-S V2 Coated Headers , Invidia V3 Downpipe , Spt CatBack , Nrg Hood Struts , Rear Strut Bar , Spt Turbo Heat Shield , K&N Drop In Filter , Amsoil Motor Oil , RCE V2 Yellow Springs are on the way !
viaburn26 is offline   Reply With Quote
Old 02-06-2008, 10:01 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Yep probably - at least w/out alteration.
You may need to use large spacers to fit the skid plate over the headers
and that will probably drop the skid plate way down.
Jamie
Old 02-06-2008, 11:31 PM   #3
viaburn26
Member#: 167272
2004 STi
well i put it on today used 3 spacers on each bolt up front and it still rattles , wonder if i should space the rear bolts to ...
p.s. there are only 2 bolts up front right now since one broken off . argh . now i have to remove the sub frame to get the bolt out . there isn't any play in the plate with the one bolt missing but i think there still to close to the headers ... how far did others space theirs out ? did they also space the rear bolts out ?
Old 02-11-2008, 06:57 PM   #4
viaburn26
Member#: 167272
2004 STi
its on now with no rattles took the 3 washers off added a nut and one washer , so now the bolts won't fall out when i take if off and it provides the correct amount of space for the headers . key to using the nut is to leave it at the end of the bolt so when you put it on it will go all the way down and not leave a gap between the frame and nut .
FS: Primitive skid plate and diff protector for WRX superg Private 'For Sale' Classifieds 3 01-31-2006 10:24 AM
Can Primitive skid plate owners (Front & Back) tell me what I'm missing? Kyguy Interior & Exterior Modification 2 10-19-2005 05:54 AM
Gauging interest: FS Primitive skid plate - 93-01 Impreza Subie Gal North West Impreza Club Forum -- NWIC 2 04-28-2003 06:15 PM
FS: Primitive Skid Plate - used Subie Gal North West Impreza Club Forum -- NWIC 3 05-10-2002 12:42 PM
Rear diff. fluid change w/ Primitive Skid Plate HomerJay Service & Maintenance 8 01-13-2002 10:26 PM
