Old 02-06-2008, 03:44 AM   #1
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Default Replacing Stock Headers+Exhaust. Buy New Gaskets?
So I have a set of Cobb Headers + High Flow cat and a Stromung exhaust that I will be taking off my car very soon and replacing with my stock set-up. My simple question is, should I purchase a new set of the gaskets (I believe it's a total of 4 that I would need) or just reuse the one's currently on the car? Thanks
-Ellz
Oh yeah. I have an 02 RS. Sorry for not mentioning that.
ejicon is offline   Reply With Quote
Old 02-06-2008, 04:04 AM   #2
EdHilario
Member#: 137398
2004 Impreza 2.5RS
I would.
EdHilario is offline   Reply With Quote
Old 02-06-2008, 02:22 PM   #3
skribblez32
Member#: 120609
2006 2.5i
CGM
It says that you have an MY02 in your car profile, I would change those gaskets. They're pretty cheap and easy to get (Subaru dealer).
skribblez32 is offline   Reply With Quote
Old 02-06-2008, 07:28 PM   #4
02RSBRP
Member#: 159398
When it comes to exhaust systems, you always need to replace the gaskets. Usually when you pull the exhaust apart, it will rip or damage the old gaskets.
02RSBRP is offline   Reply With Quote
Old 02-06-2008, 08:31 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Some have gotten away with reusing the gaskets, need to apply a thin layer of copper gasket maker beforehand though.
Of course, with my luck, I got exhaust leaks AFTER I put new gaskets when I did my headers for the 2nd time
YMMV...
rougeben83 is offline   Reply With Quote
Old 02-07-2008, 12:22 AM   #6
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
O.k cool. Subaruparts.com has the gaskets I need for $40 bucks. I'll order these ASAP =) Thanks for the info guys
Old 02-07-2008, 12:53 AM   #7
Major Johnson
Member#: 120705
2007 FXT Sports
World Rally Blue
Anytime you take apart gaskets from being sealed, you should replace them with new ones.
Major Johnson is offline   Reply With Quote
Old 02-07-2008, 02:04 AM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You should probably order new exhaust studs and nuts for the header to head connection. Those like to rust up and come out in one piece. If you reinstall them like bolts you probably will not get them tight without stripping out the threads in the heads. Plus new hardware is just easier to work with.
Oh and, yes, get new gaskets. Leaks suck.
Tim Sanderson is offline   Reply With Quote
Old 02-07-2008, 04:42 PM   #9
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Thanks. That's a great suggestion. Anyone happened to know what bolt pattern/size they are off hand? I'm going to head over to Scoobymods to find out.
Old 02-08-2008, 02:28 PM   #10
rage557
Member#: 117441
2001 Impreza 2.5rs
When you take your headers off be sure to use a ton of penitrating oil. Some of those studs/nuts may pop off pretty easily but it is also just as easy to snap them and they you have a huge problem.
rage557 is offline   Reply With Quote
Old 04-07-2008, 10:56 PM   #11
Slakker25rs
Member#: 109830
If you get the exhaust nuts off without a whole load of work, then spend the 3 dollars and replace the gaskets. Anything that goes through that many hot cold cycles will definitely show wear.
Slakker25rs is offline   Reply With Quote
WTB stock headers/exhaust manifold ant927 Private 'Wanted' Classifieds 1 02-19-2006 03:19 AM
Best place to buy new gaskets and bolts for Helix Downpipe? STiMUL8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-31-2006 07:46 AM
p&p headers or buy new? brianvancaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-10-2005 12:30 AM
custom cat piece to replace stock rear exhaust pipe / resonator Wagon Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-15-2005 01:24 PM
Do I have to buy new gaskets for... dallas_wrx_blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-08-2002 07:44 PM
