Old 02-06-2008, 02:29 PM   #1
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Default Installing STI headlights on WRX (04')
I just have a quick question about the pinouts for the USDM STI leveler motor. i have the schmatic for the leveler switch wire diagram, but im just confused which pin on the leveler motor plug is pin 1. if someone could add the pin numbers to this pic and repost it, it would be greatly appreciated.
here is the direct link http://i56.photobucket.com/albums/g1...k/IMG_2149.jpg
these are from an 04' STI going into an 04' WRX wagon
*EDIT*
Since i didnt have much luck finding info for this install on here, i will put up what i have found.
If you didnt get the plugs with your headlights, and cant find plugs for it, here are the pins for the USDM 6 pin (8pin with 2 dead pins levler switch)
if you need the schematic for the leveler system let me know i have it.
Switch Headlight
Pin Pin
SW0 - 7 1
SW1 - 6 2
SW2 - 3 3
SW3 - 4 4
+12V- 2 5 +12V
GND - 8 6 GND
skingfreak is offline   Reply With Quote
Old 05-17-2011, 04:02 PM   #2
defy_piff
Member#: 278484
Default sti headlight install on a wrx
hey i saw ur post, i am installing sti hid on my wrx and am not sure what to do to make them work correctly. two of the plugs, plug in and the other one cannot be used. i need the schematic for the leveler system but not sure what i do with the pins . if you could hellp that would be awesome thanks
defy_piff is offline   Reply With Quote
Old 05-17-2011, 05:02 PM   #3
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
hey man not sure if this will help but I'm sure these guys can make a harness for you just give them a call or this may even be the harness you need in the link.
http://shop.lightwerkz.net/product_i...products_id=13
spoolinej25 is offline   Reply With Quote
Old 05-18-2011, 02:20 AM   #4
defy_piff
Member#: 278484
thanks bro i just ordered it
Old 05-18-2011, 12:47 PM   #5
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
No problem glad I could help.
How to install STI headlights into WRX 2006 jay25RS Electrical & Lighting 9 01-29-2008 07:59 PM
Way to install STi TMIC on WRX with Samco I/C hose... txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-01-2006 12:01 PM
Please assist: Want to install STI parts on WRX goixiz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-13-2006 08:06 PM
Help Installing STi Splitters on WRX Kaze Interior & Exterior Modification 3 05-12-2005 03:15 PM
Installing STi wing on WRX Anatoly Newbies & FAQs 21 12-05-2004 11:39 PM
