Old 02-06-2008, 02:58 PM   #1
BoostUnderPressure03
Member#: 117724
2003 WRX
Default EGT Readings Accurate?
I will be installing my wideband here within the next few days and would like to get some tuning underway. I do not have the funds right now for an EGT gauge and was wondering how accurate the readings are with just data logging. If they aren't I won't mess with leaning the car out further without an EGT setup.
BoostUnderPressure03 is offline   Reply With Quote
Old 02-06-2008, 05:45 PM   #2
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
If you buy an LC-1 it will work with Enginuity
wrxsti.l is offline   Reply With Quote
Old 02-06-2008, 06:01 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Knowing your EGT is pretty worthless because an elevated EGT can be caused by so many different things, most of which aren't harmful (e.g. higher engine speed, retarded spark advance).
Jon [in CT] is offline   Reply With Quote
Old 02-06-2008, 07:21 PM   #4
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
It may be accurate, but it is too far away from the heads anyways to matter.
Infamous1 is offline   Reply With Quote
Old 02-06-2008, 07:50 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
And where exactly do you think all the heat goes traveling over 3 feet of wrapped header?
I can tell you this much....i can touch my header wrap after driving.
Tell you what....lets get 4 ft of 2.5" pipe and i'll stand on one end with an Acetylene torch and you put your hand over the other end. We'll see how much heat dissipates over 4 feet of wrapped pipe.
Do you have any data that backs up your statement? Data that shows the temp dropping dramatically at various intervals on its way to the EGT?
Old 02-06-2008, 08:30 PM   #6
rkramer
Member#: 118209
2015 WRX Limitec
another example... hold your torch to the pipe and let it blow through for 30 minutes. and then just let raw gas through without igniting it. take a guess what your temp would be at the other end 5 or 10 minutes later... I can tell you it would be ALOT higher then the gas going in. (aka the exhaust gas)
you can't forget about the 3 feet of metal to absorb and release heat. your readings are going to be DRASTICALLY slower to respond because of all the metal to absorb heat, and then also will drop much slower then what is actually happening due to all the piping releasing heat. EGT isn't exactly a fast responding data point anyway, but when you add in a fairly large delay to it due to heat soak, it really doesn't help you much beyond steady state cruise EGT.
Old 02-06-2008, 10:29 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
and my point by saying that i can touch my header wrap after driving was that there must not be a significant amount of heat transfer if the stock EGT is reading 1700*F and i can touch the header wrap....
i'd like to see data from a wrx with the stock EGT and an aftermarket one closer to the heads. Arguing over something with theories is pointless....i just want data.
http://forums.nasioc.com/forums/show....php?t=1301980
http://forums.nasioc.com/forums/show...&highlight=EGT
Old 02-06-2008, 11:06 PM   #8
rkramer
Member#: 118209
2015 WRX Limitec
your header wrap is doing what it is supposed to, acting like a very good insulator and keeping everything INSIDE the wrap hot. (which includes the piping as well as the gas itself)
anyway, see example above... yes your EGT's will be very close to what would be measured in a better spot, nobody is disputing that. But there is also no argument in saying that it will take longer to measure EGT's the further you are from the source. The pipe helps moderate temperatures.
Old 02-07-2008, 01:53 AM   #9
Member#: 117724
2003 WRX
Jeese fellas no need to get in an argument. I realize there are different opinions so I appreciate your input. But I guess my answer is that i need to be careful because it is inaccurate?
Old 02-07-2008, 02:13 AM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
go read through the links i posted, seems to be some good info there...
Using stock egt bung for aftermarket egt readings? Starch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-07-2008 10:07 PM
Accessport boost reading, accurate? 18.9psi eviltwin AccessPort 3 05-08-2006 12:42 AM
Utec map readings accurate? fedrex Engine Management & Tuning 13 03-30-2004 09:11 PM
Factory Boost Gauge - How To Read Accurately Infymus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-19-2003 11:01 AM
My EGT reading IMPBOY Bay Area Impreza Club Forum -- BAIC 1 05-26-2001 09:14 PM
