Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 09-26-2011, 04:00 PM   #26
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Thank you for your response.
I might be getting the 08 STi hub assembly complete that's why I'm asking.
I'll keep on searching to find out if the inner side of the axle will fit in other transmissions.
Old 11-26-2011, 10:26 AM   #27
toph
Member#: 78640
08 STi 3.5XT-R
15 STi CWP | 02 STi Wagon
Does anyone know how much fluid to put in the transmission and also the rear diff? Also where is the fill point? Seems different than my 04 WRX. Thanks in advance!
Found capacity is 4.1QT for a GD STi, is it the same for a GR?
toph is offline   Reply With Quote
Old 11-26-2011, 11:19 AM   #28
GrundleJuice
Member#: 165749
owners manual - read it
Old 11-26-2011, 11:41 AM   #29
toph
Member#: 78640
08 STi 3.5XT-R
Thanks for the useful advice.
Old 11-26-2011, 03:06 PM   #30
GrundleJuice
Member#: 165749
Thanks for being too lazy to get the info that is painfully easy to find on here, google, our your owners manual.
I'm in a good mood so I'll tell you:
12 qts in the gear box - filler is under you shifter knob.
3.14159 in the diff
Old 11-26-2011, 06:02 PM   #31
toph
Member#: 78640
08 STi 3.5XT-R
3.14159 in the diff
Wow thanks man really appreciate the info!
Old 11-28-2011, 01:44 PM   #32
toph
Member#: 78640
08 STi 3.5XT-R
3.4QT's for anyone else wondering. This is per Andrewtech...
Old 03-25-2012, 02:22 AM   #33
jarrodblake
Member#: 314134
02 wrx
midnight black
i have been doing a little reading. im looking into swapping a 08 n/a 5 speed trans into a 02 wrx. from what i can tell the 08 n/a 5 speed trans has a 3.90 gear ratio? so it looks like i would need a 04-05 sti diff with the 3.90 gear ratio. will the 08 diff bolt in a 02?
jarrodblake is offline   Reply With Quote
Old 06-11-2012, 01:25 PM   #34
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I didnt want to make a new thread.
Will 08 STi hubs fit onto a 2010 Legacy GT without problems? Does anything have to be changed?
Old 01-31-2013, 06:51 PM   #35
JohnBarnes
Member#: 344921
3.14159 in the diff! Baaahahahahahaaa
3.14159 in the diff
JohnBarnes is offline   Reply With Quote
Old 12-09-2014, 10:12 AM   #36
cttransplant
Member#: 405780
2007 OBXT
Can someone confirm that the inner cv of an 04-07 axle works in an 08 differential?
cttransplant is offline   Reply With Quote
FS (WA) 2008 STi GT Spec Front Strut Tower Bar CO WRX Suspension/Brakes/Handling 3 04-26-2009 06:05 PM
Help with EDM 2008 STI tranny part numbers? or gear swap? Frank A International Forum 0 07-04-2008 12:31 AM
2008 WRX, 2007-2008 LGT and SPEC-B, 2007-2008 FXT and 2008 STi .COBB ACCESS PORT! RallySport Direct Engine/Power/Exhaust 2 12-12-2007 01:34 PM
Preliminary non-JDM 2008 STI specs Jon [in CT] News & Rumors 557 11-27-2007 02:09 PM
