Old 02-06-2008, 08:44 PM   #1
jdiddy
Member#: 108144
04 Forester XT
4eat
Default What did I do to the LEgacy???
So I just got my tactrix cable and loaded up enguniuty and loaded the latest definiotion. Then I loaded up ECUflash and then plugged it into the car which was running, when I clicked 05-06 LGT in ECUflash the car instantly died. I pulled the cord out of the OBD2 port and then tried to restart teh car....would not turn over...waited about10 seconds and tried to start her again. It was really hard to get her to turn over but she finally did and now the check engine light is on and the cruise light is flashing
jdiddy is offline   Reply With Quote
Old 02-06-2008, 09:00 PM   #2
jibber
Member#: 6675
98 SF5 some mods
01 allroad
First read this a few times:
http://www.scoobypedia.co.uk/index.p...ReflashingECUs
I am assuming that the car will run now:
Next try resetting the ECU with enginuity, and then try reading your rom again starting with the car off, and following the instructions.
Good luck
jibber is offline   Reply With Quote
Old 02-06-2008, 09:01 PM   #3
drkramm
Member#: 159156
2007 wrx
wrb
so you tried to flash the car while it was running ?
first you shouldn't even be able to do that
im not sure how a legacy is set up , but with the wrx,sti's you need to have the green test connectors under the dash plugged in
with them plugged in the car won't start but you can read write the ecu
with them un-plugged you can start the car but cant read write
drkramm is offline   Reply With Quote
Old 02-06-2008, 10:05 PM   #4
jdiddy
Member#: 108144
04 Forester XT
4eat
I did not try and flash just read the ROM. The LGT does not have the green and white connectors...
Old 02-06-2008, 10:23 PM   #5
jibber
Member#: 6675
98 SF5 some mods
01 allroad
Did you clear the codes? Any luck with the reading while the car is not running?
Old 02-07-2008, 12:38 AM   #6
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I have the same year LGT as you. We don't have the connectors on the Tactrix cable, but we do have a pair of connectors under the carpet below the glovebox.
Follow the scoobypedia instructions, they worked for me.
What did I do to the wife's Forester? Opie South East Region Forum 21 07-02-2008 01:19 PM
Dog House (94.9) question. What did they do to get suspended? Andrew Bay Area Impreza Club Forum -- BAIC 16 09-08-2005 05:44 PM
What did Chris3 do to get TO??? wolf8314 Off-Topic 55 03-04-2005 03:16 PM
Oh jeeesh, what did I do to my new WRX T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 12-18-2003 10:46 AM
What did they do to my steering wheel? deke Brakes, Steering & Suspension 7 05-25-2002 10:56 PM
