#1 |
Member#: 167128
PRSIC
Vehicle:1999 Impreza RS White/Black |
i just got a injen intake for my 99 RS, and i dint come whit tha plate for the air sensor.
the intake is from a 01 that dosent have the air sensor in the intake. What can i do to make this work on my car. Thanks
#2 |
Member#: 171071
It's going to be easier to just get the correct intake for your car. You can check here subaru intake to see the +'s and -'s of each brand.
To make that intake work you are going to have to modify the piping, which I don't recommend. You can use a saw and or a drill to make an opening, then use rubber to seal it. Even then, there is a good chance you will damage the sensors over the long haul, and it isn't cheap. |
#3 |
Member#: 167128
PRSIC
Well i got the intake for free, so is their any other way to make it work.
THanks |
#4 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Cut the pipe where the MAF needs to go, put a silicone coupler on either side and clamp it back together. It's not a huge deal.
Jay Storm |
#5 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Buy a MAF adapter http://cgi.ebay.com/ebaymotors/93-05...spagenameZWDVW
Cut the tube a little shorter, attach the MAF adapter to the stock MAF housing, attach the housing to the tube. |
| Thread Tools | |
| Display Modes | |
| help whit swap | abrawrx | Built Motor Discussion | 2 | 05-06-2008 01:35 PM |
| help whit GREDDY PROFEC B SPEC 2 | puppet4950 | General Community | 0 | 02-24-2008 03:59 PM |
| Help whit the build | GR-RACING | Normally Aspirated Powertrain | 17 | 02-12-2008 07:29 PM |
| help whit greedy profec b- spec 2 setings | puppet4950 | UTEC | 0 | 01-12-2008 01:08 PM |
| i need help whit my sti cluster 2007 to fit in the wrx 2006 | subaru_west | Electrical & Lighting | 2 | 01-12-2008 04:44 AM |
