Old 02-07-2008, 12:37 AM   #1
nismo4life
Member#: 118317
Default Coolant temp gauge on the fritz?!?! Help
I have a 208,000 mile 2.2 OBS. Don't know when the Timing belt or Water pump was last done but I will get it done next week. I am leaving in 12 hours for South Carolina to the Sand Blast Rally with my brother who is racing in it so I need you guys to anwser asap. I think my Coolant Temp Sensor might have gone bad. I started to overheat one day. Changed the Thermostat and problem persisted. Ended up that my rad was broken on the top plastic piece, replaced it and all was well. Recently my temp gauge started rising. This is were it gets real weird.
If I am driving and it starts to go up, If I come to a stop and shut the car off, and then immediately turn it back on 8/10 times it will go back to proper operating temperature almost instantly. Tonight I was giving it a test drive since I just finished installing a new clutch/flywheel/2nd gear shift fork and I stopped at a intersection. Needle started climbing. Eventually hit the checkered part of the gauge at the top at the H. I turned the Heat on full blast and mind you my heat is still hot, clutch in or not unlike some others who have posted this issue. I look at the gauge and nothing, so I get pissed, take a left turn and romp 1st-4th. I look down and the ****ing gauge is going down AS IM BEATING THE PISS out of my car from maxxed out at the H to just under the mid point. WTF?!??! Is it possible that my temp sensor is crazy?! How hard/long of a job is it to change the water pump!?
nismo4life is offline   Reply With Quote
Old 02-07-2008, 12:45 AM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I'm having a similar problem with my temp guage. Try hitting the cluster or the dash and see if it doesn't bounce around (it shouldn't if it's doing its job correctly). I'd like to get an aftermarket guage soon in case it actually does overheat and I just ignore it.
Wiscon_Mark is offline   Reply With Quote
Old 02-07-2008, 12:58 AM   #3
Major Johnson
Member#: 120705
2007 FXT Sports
World Rally Blue
I couldn't tell you what's going on but if you've got an extra $150 laying you could pick up a Scan Gauge and it'll tell you real time exactly what the temp is instead of "low", "ok", or "oops too late".
Major Johnson is offline   Reply With Quote
Old 02-07-2008, 09:24 AM   #4
nismo4life
Member#: 118317
You mean one of the OBDII scan tools?!
Old 02-07-2008, 12:25 PM   #5
nismo4life
Member#: 118317
I went to Scoobaruu stealership and one of the techs was nice enough to look at the car real quick. When I changed the rad I left a funnel with coolant and the car running for about 15 minutes to let all the bubbles out. I guess somehow a MAJOR air pocket was created in the radiator and basically the radiator wasn't running lol. He cracked the cap slightly and a **** load of steam came out. He was nice enough to fill it back up and I've been beating the ever living piss out of it for the last 45 miles and the needle has not moved once. I'm just happy its nothing major right now since I need to drive leave for SC in an hour lol.
Old 02-08-2008, 03:08 AM   #6
Major Johnson
Member#: 120705
2007 FXT Sports
World Rally Blue
Oh well that's cool at least it was something simple like that.
Coolant temp gauge on cluster not working - JDM STi V7 Swap moss Subaru Conversions 7 10-14-2007 02:15 AM
oil gauge on the fritz...please help!!! eazyd123 Electrical & Lighting 22 09-30-2006 09:46 PM
HELP Greddy 60mm turbo gauge on the fritz! nottheliving Interior & Exterior Modification 7 03-07-2005 10:34 AM
HELP Greddy 60mm turbo gauge on the fritz! nottheliving Electrical & Lighting 0 10-20-2004 05:53 PM
Transmission temp gauge idea, Switch to use coolant temp gauge so no dash space taken ciper Transmission (AT/MT) & Driveline 6 06-05-2003 03:54 PM
