Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 11-18-2005, 03:12 PM   #1
tfisher311
Member#: 94517
1997 Legacy GT
Default Engine rattle, clatter
I hate to do this b/c there are 100 threads about everyone's different engine noises. This is the last abnormal noise left on my car and I'm having trouble self diagnosing it. I really don't want to bring it to the shop until I've done everything I can to figure it out.
I hear a healthy clatter as the engine approaches 3k RPM, it happens running up through the gears and/or at cruise. The frequency is timed with the engine speed and is really timed perfectly with the exhaust pulses. I sounds more internally mechanical than a heat shield or loose part rattling. It only really happens under load (accelerating or climbing a hill) although it doesn't happen 100% of the time. Sometimes when it is happening, I can let off the throttle then reapply power and it will be gone. It doesn't correllate to engine temp at all. It happens hot and cold. My biggest issue with the noise is that I can't get it to happen unless I'm underway so it's hard to get my head under the hood at 35mph.
I've removed all the heat shields as they broke loose. There doesn't appear to be anything loose in the engine compartment that is capable of this noise.
I have some ideas about what this might be based on some research here but the symtoms don't match up with anything that I've read.
Any advice or thoughts would be great. Thanks.
tfisher311 is offline   Reply With Quote
Old 11-18-2005, 09:14 PM   #2
big_jesus
Member#: 58661
what engine? is this your 97 legacy?
big_jesus is offline   Reply With Quote
Old 11-21-2005, 10:32 AM   #3
tfisher311
Member#: 94517
1997 Legacy GT
The engine is the NA 2.5L in a Legacy GT sedan. Stock except for no heat shields.
I took it from Boston to VT this past weekend and it ran great. It pulls great, cruises real smooth, no complaints; until the noise kicks in.
If I cruise at ~62MPH it puts the tach right around 3kRPM, sometimes I hear what could be described as a wrap. I can make it go away by letting off the gas. Then if I add power it's not there, until cruise speed around 60MPH is reached. It simply doesn't happen above 70MPH.
It's clearly in or very close to the engine since it's coming from under the hood and it is perfectly timed with the exhaust pulses. I know it's not valves or pistons since they make noise at cold start and go away when warm. This a much richer almost but not quite metallic wrap/clatter/rattle.
It killing me.
Old 03-12-2008, 03:25 PM   #4
DC16A2
Member#: 174357
2002 OBS
Default Me too!
"I hear a healthy clatter as the engine approaches 3k RPM, it happens running up through the gears and/or at cruise. The frequency is timed with the engine speed and is really timed perfectly with the exhaust pulses. I sounds more internally mechanical than a heat shield or loose part rattling. It only really happens under load (accelerating or climbing a hill) although it doesn't happen 100% of the time. Sometimes when it is happening, I can let off the throttle then reapply power and it will be gone. It doesn't correlate to engine temp at all. It happens hot and cold. My biggest issue with the noise is that I can't get it to happen unless I'm underway so it's hard to get my head under the hood at 35mph."
I'm experiencing exactly as you have described, tfisher311, on my 2002 Impreza - Outback Sport. I don't know what our problem is, but it sounds like "valve clatter" from the research I've been doing on the internet. It's driving me nuts too.
-Dave
DC16A2 is offline   Reply With Quote
Old 03-12-2008, 03:29 PM   #5
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
exhaust leak?
subikid is offline   Reply With Quote
Old 03-12-2008, 03:33 PM   #6
subiesurfer
Member#: 121330
06 impreza
SGM
if ure car has 6 stars on the front, expect rattles lol
cant help u out w this one but i know what ure going through, ive had a handful of rattle already on my 06
subiesurfer is offline   Reply With Quote
Old 03-12-2008, 07:27 PM   #7
subikid
Member#: 114122
red
atta way to be encouraging about our cars bud
Old 03-14-2008, 12:14 PM   #8
DC16A2
Member#: 174357
2002 OBS
Default Still clattering..
I wonder if it's a failing pump or something inside the engine, or something belt driven, and so "pulses" along with applications of throttle. Going to have a friend sit behind the gas pedal over the weekend while I listen to the engine bay, maybe something needs lubrication.
Old 03-14-2008, 02:09 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
pop the hood and turn it on. stick a screwdriver to your ear and the other end to various parts of the engine. I've had a mysterious rattle for the past 6 months, it's rod knock on mine. happens right at startup then quits after 1 second or so. then comes back at 3K rpms or so. pretty bad after it's warm. the solution? new shortblock....for me anyway.
yarrgh is offline   Reply With Quote
Old 03-14-2008, 02:22 PM   #10
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
I have been told that a certain amount of valve clatter is normal on Subaru engines; this may be what subiesurfer is referring to. This sounds similar to what my car does and my engine is completely fine (also a SOHC NA 2.5L).
I think is has something to do with spring loaded valves. Maybe the experts here can shed some light on this.
mslstixx is offline   Reply With Quote
Old 03-15-2008, 12:00 AM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Tfisher, Do you know whether your car has hydraulic lash adjusters?
I'd like to see the results of a leakdown test.
Any cel's?
Tim Sanderson is offline   Reply With Quote
Old 03-15-2008, 11:11 AM   #12
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Definitely try listening with a screw driver or something like that to the engine. It should give you some sort of idea if something is making noise in it. If its a rattle then it might be something on your exhaust. Mine had a complete crack around one of the welds. It rattled like hell until I figured out what was wrong with it and had a new one put on because it would not hold a new weld.
gtbensley is offline   Reply With Quote
Old 04-16-2008, 05:47 PM   #13
DC16A2
Member#: 174357
2002 OBS
Default Rattling sound fixed.
It was actually a loose heat shield. The guys at North Coast Subaru did a good job.
Old 04-16-2008, 07:02 PM   #14
GrundleJuice
Member#: 165749
a blown out cat will make some noise... and i think of this because it will be most of the time but not always.
GrundleJuice is online now   Reply With Quote
Turbo rattle or Engine rattle? Help Please wrx747 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-20-2012 07:52 PM
Why does my engine rattle? edkwon Normally Aspirated Powertrain 9 02-27-2002 10:44 PM
Engine rattle [buzz] when decelerating ? Rob in a WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-03-2001 08:28 AM
MY98 RS Clutch chatter and engine rattle Bronco Normally Aspirated Powertrain 8 05-29-2001 04:46 PM
