Old 02-09-2008, 08:48 AM   #26
Sylon
Member#: 109000
2006 Impreza 2.5i
Obsidian Black Pearl
What is the recommended length guys? Does it depend on which HFC you get? Well there are pretty much 2 most popular, so how long extension for either the Stromung and Random Tech HFC's?
Sylon is offline   Reply With Quote
Old 02-09-2008, 09:02 AM   #27
EdHilario
Member#: 137398
2004 Impreza
Apparently 24" was too short for Zepp. But I think that's long enough for my application. Go with the longest in case you're unsure.
EdHilario is offline   Reply With Quote
Old 02-09-2008, 04:18 PM   #28
ZeppelinPie792
Member#: 160287
2007 Impreza 2.5i SE
Newport Pearl Blue
Nah, I just had to re-locate the female connectors (or whatever the ones you plug the O2's into)
It fits fine, and is a little longer.
ZeppelinPie792 is offline   Reply With Quote
Old 02-09-2008, 04:25 PM   #29
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
That's friggin awesome! lol they even used the picture from our board.
It's only one product though. No varying lengths.
They even gave me credit for it!
I sent them an email to fix that though.
There are varying lengths, but maybe it has been updated since you checked it.
Old 02-09-2008, 07:37 PM   #30
EdHilario
Member#: 137398
2004 Impreza
Yeah it was just updated. I just ordered a 24" and a 36"
Old 02-09-2008, 08:11 PM   #31
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
I'll probably do the same. Their not expensive so better be safe.
leafs fan is offline   Reply With Quote
Old 02-09-2008, 08:22 PM   #32
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
Why did you get two? I only needed one 24".
I know I said it didn't work, but I just had to relocate the female connections.
Old 02-09-2008, 09:25 PM   #33
bomber991
Member#: 52539
2003 Impreza WRX
BLUE
Why don't you edit your post where you said it didn't work so others don't think it won't work.
bomber991 is offline   Reply With Quote
Old 02-10-2008, 04:53 AM   #34
EdHilario
Member#: 137398
2004 Impreza
I got two just to be on the safe side. I'm not sure if the front O2 sensor will reach on the other HFC pipes. Right now, I was pretty lucky to have the front one on mine reach.
Old 02-10-2008, 06:58 AM   #35
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
What is your exhaust setup right now?
Old 02-10-2008, 09:18 AM   #36
EdHilario
Member#: 137398
2004 Impreza
RalliTEK EL Headers, Espelir HFC, Custom 1-piece 2.25" Catback with 4" Tip Titanium Muffler
Old 02-10-2008, 02:05 PM   #37
GR-RACING
Member#: 167128
Chapter/Region: PRSIC
1999 Impreza RS
White/Black
What are the extensions for , im lost, what are you guys using them for?
Thanks
GR-RACING is offline   Reply With Quote
Old 02-10-2008, 04:05 PM   #38
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
Thanks
When you install an after market high flow catalytic converter, the O2 sensor cables will most likely not reach. You will have to get an extension so the rear one will reach the female connector. I am not sure if this is the case for a 2.5RS, but I know it is for a 2.5i
Old 02-10-2008, 04:53 PM   #39
GR-RACING
Member#: 167128
1999 Impreza RS
White/Black
ohh, thanks for the info
Old 02-10-2008, 07:27 PM   #40
EdHilario
Member#: 137398
2004 Impreza
GR-RACING, your question has been answered several times in other threads as well as in the post 17 of this one. It also explains it on the website that's being linked. If you don't know what it's for then you probably don't need one.
Old 02-10-2008, 08:38 PM   #41
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
How do you like the rallitek headers. Someone on tsc is selling them.
Old 02-10-2008, 11:40 PM   #42
EdHilario
Member#: 137398
2004 Impreza
I think he was selling a catback and it was sold.
They're okay, lost some rumble but gained some performance.
I'm probably going to change my whole exhaust setup this spring/summer.
Old 03-03-2008, 01:52 PM   #43
Silver '02 REX
Member#: 27963
2014 ATS
Has anyone ordered one of these extensions and received it yet? I got one and checked it out next to the new Bosch rear O2 sensor and the plugs don't match up. There is a long channel in the middle of the extension plug that goes from one end to the other but on the Bosch plug there is a little plastic divider in the middle of the channel. I sent an email to Cosmo's and they wanted more pictures but after I asked what they would like to see they haven't responded yet.
I will say I haven't checked the factory plug on the sensor on the car yet but the Bosch sensor is the correct one for my car.
Silver '02 REX is offline   Reply With Quote
Old 03-03-2008, 06:20 PM   #44
piker28
Member#: 22664
well that could be reason that also many people suggest only using oem factory sensor parts because alot of those aftermarket ones are not correct or never seem to work right
just a guess
piker28 is offline   Reply With Quote
Old 03-04-2008, 10:22 AM   #45
Silver '02 REX
Member#: 27963
2014 ATS
just a guess
I used a Bosch in my Front O2 when I had to replace it a couple of years ago and had no issues. Here is a pic illustrating what my problem is:
http://www.we-todd-did-racing.com/vi.../1051528_mf7wi
Worse comes to worse I could just swap the connector from the sensor in the car now to the new sensor.
Old 03-04-2008, 02:33 PM   #46
EdHilario
Member#: 137398
2004 Impreza
Hmm might be different sensors? The one that Casper's Electronic's made was based off from someone's 05 I think. Whether it was the OEM sensor or an aftermarket replacement, I'm not sure.
Old 03-04-2008, 02:42 PM   #47
Sylon
Member#: 109000
2006 Impreza 2.5i
Can you post up pictures of the bad extension? Perhaps they sent you the wrong one?
Old 03-05-2008, 10:34 AM   #48
Silver '02 REX
Member#: 27963
2014 ATS
Here you go. The sensor is for my 2002 Forester BTW.
Old 03-06-2008, 01:48 PM   #49
Silver '02 REX
Member#: 27963
2014 ATS
I just checked on the Bosch website and the 05 does call for a different sensor for the rear than my 02. maybe I will try and hit an auto parts store to see if the plug on the 05 matches the extension.
Old 03-06-2008, 11:32 PM   #50
EdHilario
Member#: 137398
2004 Impreza
Hmm I hope my extensions fit my O2 sensors. I haven't tried yet.
WTB: NEED o2 sensor EXTENSION ASAP!!!!!!!!!!! maxipad VIC Private Classifieds 1 08-29-2007 10:59 PM
PA: PDM O2 sensor extension (rear O2 - for P0420 code) Siper2 Private 'Wanted' Classifieds 0 04-16-2006 01:01 PM
anyone use the PDM O2 Sensor Extension to fix P0420 cel? criz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-17-2004 04:13 PM
PDM O2 Sensor Extension Cadaver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-30-2004 02:25 PM
