Old 02-07-2008, 03:05 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default high mileage GDB RS - what to look for?
Im going to be checking out a 02 RS this weekend hopefully and it looks to be in good conditon, other then the fact it has over 160K on it.
The new RS motors are pretty bullet proof..ala no HG problems like the old EJ25D motors (phase I) correct?
How do I check if the wheel bearings are shot? And most importantly, anything else I should check for?
mxpunk is offline   Reply With Quote
Old 02-07-2008, 10:07 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i could always tell if wheel bearings were going or gone by side loading them. a gentle sweeping turn at moderate speed (not parking lot slow, above 40 mph) would make them sing. well actually it was more like a dull roar. kinda like the noise a bowling ball makes when it rolls down the ally. If they are real basd they might make noise all the time and then it could be hard to hear any change when rounding a curve. my 98 chevy had bad bearings in the rear and it sounded like i was on a gravel road when i would round a particular curve. i dont know any for sure way without getting the wheels off the ground.
GrundleJuice is online now   Reply With Quote
Old 02-08-2008, 03:56 PM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks. now to the motor!
Old 02-09-2008, 01:24 PM   #4
03 bug eye
Member#: 140571
2003 wrx
aspen white
ive heard that even on the newer 2.5L motors you should still check to see if the timing belt and waterpump have been replaced. they should have arleady been done bcause you usually run into problems with those just over 100k. also asked for all service records if he has them so you can check when the last major tune ups were. good luck
03 bug eye is offline   Reply With Quote
Old 02-10-2008, 06:30 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
well checked out teh car today, for a high mileage car it wasnt really in bad shape at all considering it was in upstate NY and tons of salt!
not teh bargaining!
Old 02-18-2008, 09:28 PM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
does anyone on here have a high mileage 02+ rs??
2002 RS - What to look for? PleiadesNight Impreza Forum 1 03-14-2009 11:49 PM
Looking at a used 02 automatic impreza rs, what to look for? MrMakesitRain General Community 5 04-05-2008 12:53 AM
Shopping for 02/03 WRX/RS.. what to look for? PeteS99 Newbies & FAQs 9 10-21-2005 01:13 PM
('93-'01) What to look for in a 2.5 RS teamzzyzx Impreza Forum 11 11-21-2003 09:51 AM
('93-'01) Buying an RS! What to look for? trilap5e Impreza Forum 3 06-14-2002 06:16 PM
