Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 01-16-2009, 06:47 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default 2008+ RCE STI Starter Kit, New Yorker Project Package, RCE T2 Clubsports, and more!!!
2008+ STI and WRX Starter Kit
Improve all aspects of your GR Impreza with this starter kit.
Better handling, better response, and more power!
Cobb Accessport Engine Management
Whiteline 22mm adjustable front swaybar
Whiteline 22mm adjustable rear swaybar
Kartboy Pitch Stop Mount
Whiteline Steering Rack Bushings
$1240 shipped
Starter Kit PLUS Package
STI Group N Front Top Mounts
$1390 shipped
Regular Guy Starter Package
Racecomp Engineering Regular Guy Performance Springs
Super mild drop to preserve damper travel. Spring rates designed to match the stock valving and improve performance. Stay tuned for more details.
$1730 shipped
Call 410-579-1501 to order or discuss options!
__________________
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is offline
Old 01-16-2009, 06:47 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The New Yorker Project STI Package
Transform your GR into the ultimate Subaru
Racecomp or Vorshlag Front Camber Plates
Racecomp Engineering Clubsport Coilovers
Whiteline Roll Center Kit
Whiteline Anti-Lift Kit
Cusco Front Lower Brace Type-2
Cusco Front Strut Tower Brace Type-OS
Whiteline Rear Camber Adjustment Kit
$3694 shipped
Call for additional options like swaybars, custom spring rates, Cobb Accessport, and more!
__________________
410-846-5407
Old 01-16-2009, 06:47 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering T2 Clubsport Coilovers by KW
Racecomp Engineering is proud to announce their Clubsport Coilovers for the 2008 STi! One of the most anticipated suspension options for the new body style Impreza is available now!
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts....these are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008 STi.
These coilovers feature the same inox-line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3's, yet still offer an amazing ride quality not felt with other brands. These do not come with strut top mounts, but we have a few options available.
$2295 shipped for coilovers only
$2570 shipped with Group-N front tops and STi rear tops, fully assembled
$2655 shipped with Cusco front camber plates and STi rear tops, fully assembled
Ohlins 2008 STi Sportline DFV Coilovers
Ohlins has announced their new DFV Sportline Height Adjustable coilover suspension for the 2008 STI.
Long known for their excellent racing and street dampers, Ohlins is now able to offer a street/track solution for the new 2008 Subaru Impreza.
Highly flexible damping range allows for comfortable street ride and excellent track performance. New DFV (Dual Flow Valve) technology allows for more advanced valving on both the rebound and compression side, resulting in even better ride quality and performance. A first for Ohlins Sportline on a Subaru, these coilovers are dual height adjustable, allowing separate preload and ride height adjustments.
Combined with the 2008 Impreza's redesigned rear suspension, Ohlins is able to take the tenacious grip offered by the new STI one giant step forward, while allowing the user to fine tune the balance and handling of the car.
*Includes front camber plates and rear pillowball top mounts
*Separate ride height and preload adjustment
*Spring rates are 500 lbs/in front and 400 lbs/in rear
*Custom spring rates and valving are available
$CALL!
__________________
410-846-5407
Old 01-16-2009, 06:48 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GR Chassis Camber Plates
Based off of the highly successful GD style RCE camber plates, we have extended our lineup to include the GR chassis. Basically identical to the previous generation's camber plate except for the obvious new strut top design that came along with the new chassis. These will be offered in both lowering and non-lowering versions. We are accepting preorders now for these which will be available shortly.
$499 shipped
Racecomp Engineering GR Chassis Sway Bars
These are in the works, more information to follow shortly. Please give us a call to discuss what we have planned and to get on the preorder list.
Whiteline GR Chassis Sway Bars
Whiteline 22mm Front Adjustable Sway Bar - $175 shipped
Whiteline 24mm Front Adjustable Sway Bar - $197 shipped
Whiteline 20mm Rear Adjustable Sway Bar - $197 shipped
Whiteline 22mm Rear Adjustable Sway Bar - $197 shipped
Cusco GR Chassis Suspension Parts
Cusco OS Front Strut Tower Brace - $168 shipped
Cusco Type-2 Front Lower Arm Brace - $170 shipped
This mount is a huge upgrade over the stock piece. No added harshness, no negatives to this upgrade. Really improves comfort and feel and its cheap! This piece will fit the 2008 Imprezas.
$120 shipped
The KCA334 Anti-Lift/Caster Kit is designed by Whiteline and adds approximately +0.5 deg static caster to both front wheels while changing the nature of front anti-dive and anti-lift geometry. The low-compliance polyurethane bushings also maintain higher dynamic positive caster.
$121 shipped
__________________
410-846-5407
Old 01-16-2009, 06:48 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
space
__________________
410-846-5407
Old 01-23-2009, 04:39 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
bump!
__________________
410-846-5407
Old 02-11-2009, 10:56 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
So three guys walk in to a Sears on a Sunday morning......
__________________
410-846-5407
Old 02-13-2009, 06:06 PM   #8
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
what?
__________________
410-846-5407
Old 03-02-2009, 05:00 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Remember kids.
Don't eat the.... well you know... snow.
__________________
410-846-5407
Old 03-06-2009, 12:06 PM   #10
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
buuuump!
__________________
410-846-5407
Old 03-09-2009, 06:04 PM   #11
sTiknight
Member Sales Rating: (10)
Member#: 77543
2005 Stage 2 STi
OPB/Silver RPF1s
qoute for rce tarmacs 2 with any camber plates for a 05 sti shipped to 35244
sTiknight is offline
Old 03-09-2009, 06:06 PM   #12
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
2799.00 shipped with a free double cheeseburger !!
FOR A 2005 STI..............
Myles
__________________
410-846-5407
Old 03-10-2009, 03:42 AM   #13
Diabolus
Member Sales Rating: (20)
Member#: 72620
can i get a quote for Tarmac 2 for a GM6?
Diabolus is offline
Old 03-20-2009, 02:13 PM   #14
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
not sure how we missed that....sorry pm coming now!
__________________
410-846-5407
Old 03-27-2009, 02:36 PM   #15
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
bump!
__________________
410-846-5407
Closed Thread
FS: FL: 1993 BMW 325 Race project, S50 motor, M3 trans and more Whiteghost 2.5 Private Vehicle 'For Sale' Classifieds 2 02-17-2009 11:23 PM
Harman Motive Stage 2 Power Packages, Oil Coolers, Downpipes and More! AQ Motorsports Engine/Power/Exhaust 9 10-13-2008 09:25 PM
2007 STI Starter-Like new only 1500 miles! ScoobyNubieToo! Engine/Power/Exhaust 13 04-27-2007 07:50 AM
STi Suspension Kit Vs. M2 Sport Package Comments Needed SLKWrx Brakes, Steering & Suspension 14 05-21-2002 02:37 PM
