Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 05-06-2008, 04:19 PM   #26
blkwgn
Member#: 85087
2002 wrx wagon
That would be my reasoning as well, and now I have two cusco 1.3bar caps sitting on my table which are totally pointless. Should have bought oem. If I keep the oem one in place on the reseviour and the cusco on the radiator it will not be a higher pressure system and see the benefits, and i am not willng to guiny pig
Argh.
blkwgn is offline   Reply With Quote
Old 09-13-2008, 09:58 PM   #27
pho4life3100
Member#: 167451
2002 stage 1.5 wrx
aspen white
Hmm.. My 02s radiator crapped out on me too.. I got a used sti radiator for a good price so I'm droppin that one in... Does that 2 radiator cap thing apply to that radiator too then? I'm still a bit confused about this whole cap issue. I got all the pipes necesarry from the dealer but they only gave me one radiator cap and didn't say anything about a second? Any help would be appreciated!
Thanks!
pho4life3100 is offline   Reply With Quote
Old 09-13-2008, 10:06 PM   #28
pho4life3100
Member#: 167451
2002 stage 1.5 wrx
aspen white
Thanks!
Old 09-13-2008, 11:32 PM   #29
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Thanks!
I am pretty sure there's nothing special about the radiator in the STi - an impreza radiator is an impreza radiator (for 02 to 07, anyway) - so since the STi was at least an 04, it should have a cap on it, in which case you'll need the new hardline which goes across the backside of the radiator, as well as the new rubber line to go from that to the cap on the top of the radiator.
Old 09-28-2008, 01:10 AM   #30
snobordboi
Member#: 149130
2002 WRB WRX
VF39 Brembos etc
Hmm, just bought an aluminum rad to replace mine in my 02, and I guess I need the hard line and overflow lines, or is there any way to at least temporarily use hose to complete the system, since I am sick of smelling coolant from a leaking cap seam.
snobordboi is offline   Reply With Quote
Old 09-28-2008, 03:18 AM   #31
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Buy a plastic tee from home depot and some rubber hose from the auto store.
rougeben83 is offline   Reply With Quote
Old 10-03-2008, 05:57 PM   #32
icelt
Member#: 72311
2002 WRX Wagon 5-spd
I just had the Koyo radiator installed in my '02 WRX wagon about 2 weeks ago. Unfortunately after about 1.5 weeks I learned I was leaking coolant again. Initially I thought it was one of the original hoses I did not replace, but after poking around further I just found out it was because the passenger side cooling fan was cutting into the top main cooling hose. Basically the Koyo radiator is so much thicker than the stock one that it is creating interference between the fan and hose that wasn't there before.
Anyone have a similar problem using this radiator? Any suggestions for a fix? Maybe wrap some aluminum sheeting around a new hose and let the fan just wear itself down is what I was thinking. I'd really rather not have to pull both fans back out as that is not an insignificant effort.
Edit-----
Whoops, should have done some more searching first. Sorry 'bout that . So FYI it looks like the preferred solution is to just simply trim the upper radiator hose about 1/2" from the engine block connection side.
icelt is offline   Reply With Quote
Old 10-03-2008, 06:59 PM   #33
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Edit-----
you may need to trim the other end too, but its just a lot of fitting and cutting to make sure nothing rubs.
Good luck...
Old 10-03-2008, 10:35 PM   #34
icelt
Member#: 72311
Good luck...
Yeah the game plan is nice and clear now. Thanks for the input.
Old 10-09-2008, 12:17 AM   #35
wrxsabre
Member#: 191305
2002 WRX Wagon
Originally Posted by azscooby View Post
For $200 shipped you can get an aftermarket aluminum radiator....not a bad way to go.
I got a mishimoto from MAPERFORMANCE.com, do a search for this radiator, many have had very good luck, including myself. I would definitely do it again. I was pretty impressed, especially for the price. Easy install and no modification needed (although the site says fans won't work, they do.)
Save $320, and get a better radiator (IMHO.) But you will still need the two hoses and the metal pipe.
Good Luck
I'm looking into aftermarket aluminum radiators and spotted the Mishimoto also. They do say that you need to buy the slim fans. How were you able to get around this and use the OEM ones? Any problems since your original post on this?
wrxsabre is offline   Reply With Quote
Old 10-09-2008, 02:47 PM   #36
strohausii
Member#: 26770
'02 WRX
midnight black
^^^ Am I wrong to think the Mishimoto's are OEM thickness but only all aluminum construction?
strohausii is offline   Reply With Quote
Old 10-09-2008, 02:50 PM   #37
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
here's the specs on Mishimoto alum. radiator.
Core Size: 344mm x 692mm
Rows: 2
Inlet: 32mm
Outlet: 32mm
Core Thickness: 42mm
Tank Wall Thickness: 2mm
Fill Neck: 32mm
Purchase Includes: Mishimoto Radiator, 1.1Bar Rad Cap, Overflow Valve Cover, Fan Bolts, 1 Year Warranty
I think the alum. one is thicker than oem. But the mishimoto one with plastic end tanks might be same size as oem.
rexman2002 is offline   Reply With Quote
Old 11-11-2008, 07:48 PM   #38
wrxsabre
Member#: 191305
2002 WRX Wagon
Took a leap of faith and ordered it anyhow. Only problem I had was I had to cut about 1cm off the top hose cause it was hitting the fans. Oh and the drain plug was broken but I used the one from my old radiator.
Old 01-19-2009, 10:18 AM   #39
steriodwrx
Member#: 176585
I've had the mishimoto radiator in my 03 WRX for 2 years now with no problems and it came with a 1.3bar cap. My buddy dropped his mishimoto radiator when he was installing it and broke the drain plug, all he had to do was email mishimoto and they sent him a replacement the same day. I'm sticking with the mishimoto products on my next build, great product and price. oh and they dont have plastic end tanks they are all dual core aluminum radiators.
steriodwrx is offline   Reply With Quote
Old 08-24-2009, 12:42 PM   #40
libel infamy
Member#: 183205
2000 Outback Sport
Default new rad. on my '03 wrx
im currently in the process of switching out my stock radiator (which is cracked) and replacing it with the new version rad.
everything seems to be lining up well but what do i do with the two copper pipes coming out the bottom of the new rad? i know im going to have to buy all new hoses im just waiting for the info on how many exactly i need.
since i bought my rad thru an aftermarket distributor, it came with nothing else, no hoses or extra radiator cap. i bought a cap and clamps at a local parts store and i'm wondering exactly what else i need to get inorder to have the install run smooth.
thanks
libel infamy is offline   Reply With Quote
Old 08-24-2009, 01:07 PM   #41
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....is your WRX an automatic or standard (stick)?
Kean is offline   Reply With Quote
Old 08-25-2009, 10:24 AM   #42
libel infamy
Member#: 183205
2000 Outback Sport
standard
Old 08-25-2009, 10:30 AM   #43
Kean
Member#: 25187
'08 Foz Prem TGM
....then there should be no copper pipes at the bottom of the radiator. Likely, those metal pipes are for the trans oil cooler used in the AT application. ....I would make sure that they sent you (or that you ordered) the right radiator. There is a difference between the two.
Old 08-25-2009, 02:06 PM   #44
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
One other thing. The connectors for the fans are pull connectors not push connectors. I fought with this at first. The look like you would push on the tab to release the elec. connector. But you actually pull it up with your finger and release it. That took way too long for my being dense.
And just get a 5/16" tee and hose and that will allow you use all the original pieces on your new rad. Mine was the same way, I put the tee in the middle of the old return line. And hooked the one from the cap nipple to the tee, works perfect.
Travis
Picture of said Tee
T_Racer69 is offline   Reply With Quote
Old 08-26-2009, 06:50 AM   #45
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I bought the "ebay radiator". CXRacing.
I'm quite a bit detail oriented, I want things to fit and work right.
It took me 3 hours to fit this thing in.
It's also an aluminum radiator, dual core.
The issue with the 2 caps and associated pressures seemed not too clear at the time, so I chose the radiator without additional cap.
Among the problems with it:
The fans seemed that they would hit both the bottom and top hoses. I had to continue to trim both hoses.
At the bottom of the fan shroud/support, there are some "hooks" that look like a 1" conduit would be supported by them in passing side to side. I thought it was a twinscroll JDM cooling, maybe a AT conduit. I'm not sure, but the hooks are there.
Once you trim the bottom hose, it's angle relative to the radiator changes and it begins to rub against the driver's outermost hook.
SO, out comes the radiator again, to trim the hook..
When everything was said and done, 3 months into usage of this, it started a slow leak by the drain plug.
I changed the rubber gasket of the plug with a rubber o-ring.
3 weeks later it started to leak again there
I changed the o-ring with a GM drain plug rubber gasket.
It's been 2 weeks...
Oh, and do yourselves a favor, read the forums, research before buying any slim fans, ok?
They cannot provide sufficient cooling.
Also, did you look at the suggested installation method for the slim fans?
Pass a plastic rod through the radiator core with a "catch washer" on the other side.
And then what? vibrate the radiator core as soon as the fans come on, untill something gives, then ... buy another radiator?
Also, the radiator I have not only is almost twice as thick compared to stock, but the support pins at the bottom are welded in such way as to space the radiator from the radiator support by 1/4", shifting it closer to the engine.
When it's installed, you can say goodbye to doing timing belt without removing the radiator first, I think even replacing the crank pulley is iffy with this thing on.
Old 08-26-2009, 07:02 AM   #46
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
As far as changing the pressure at which the system runs by changing the cap pressure:
I wonder what that does to the water pump lifespan.
Old 08-27-2009, 12:10 AM   #47
en3d
Member#: 5238
GGA Black
I just installed one this weekend. I went with the CXRacing off of ebay (original style, no cap). I saved the money on the additional hoses and line.
I painted the radiator high temp black (I wanted to keep the engine back as stock looking as possible).
I had to trim both upper and lower radiator hoses by 1/4 inch on each end. Get all new clamps (4). Get some radiator hose lubricant ($1.xx at autozone) this will help with install for hoses and will help with sealing the hose. If you get a non OEM radiator, use a little loc-tite on the bolts for radiator fans. Replace the thermostat and get a new gasket for it and use some thermostat gasket maker.
This is also a great time to install a crank pulley (I installed a Kartboy). Love it.
I've had no leaks. The radiator was $135 shipped, new hoses, thermostat, clamps and coolant, it was less than $180.
en3d is offline   Reply With Quote
Old 08-27-2009, 02:10 PM   #48
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
cxracing '03 radiator (with cap) was the tits for me.
<140 shipped.
only mod i did was to put a solid brass 1/4"npt in where the POS petcock was.
i also used machine thread bolts instead of screws to mount the fans.
reused everything else. trimmed both hoses carefully to fit, perfectly.
most frustrating part was disconnecting those mother****ing fan electrical harness plugs.
ride5000 is online now   Reply With Quote
Old 08-29-2009, 03:24 AM   #49
mikercp
Member#: 166465
1994 Civic Cx
Frost White
Quick question...
I have an 03 wrx, and upgraded to a mishimoto new style radiator w/cap. Also all the necessary parts for the new style radiator were purchased from dealership.
Since, I noticed im still having some weird overheating issues..car was fine for a couple months..then i drove out to laughlin and on inclines the car temp would rise..Then just recently with the heat rising in Socal my wife was driving in stop/go traffic and the temp started to rise past the 2/3 mark so she had to pull over to cool it off..Coolant is full and not leaking at this point..i suspect either a bad radiator cap or my tstat is starting to stick closed.
Ive swapped out the thermostat and i have the following setup as far as my caps go:
On the turbo coolant tank im using the same cap that ive always had on there since ive owned the car.
On the mishimoto radiator im using a 1.3bar Greddy radiator cap
Do i need to change the cap by the turbo coolant tank ?
Ive read that higher pressure cap needs to go on the top....so does that mean I move the 1.3Bar cap to the coolant tank by turbo..and I have to use a different cap on the radiator?
mikercp is offline   Reply With Quote
Old 08-29-2009, 11:31 AM   #50
en3d
Member#: 5238
GGA Black
Hmm... you installed a new tstat. How much coolant did you put in? with these aftermarket radiators, you need more coolant than the stock one.
OEM 02 WRX Radiator & Fan assembly make offer subypal Engine/Power/Exhaust 1 03-29-2010 09:19 PM
stock L radiator or 02 wrx radiator for ej20k swap? 2slofouru Subaru Conversions 1 04-16-2009 09:54 AM
OEM 02 RS Subwoofer installed in a 08 WRX Hatch possible? ejicon Car Audio, Video & Security 4 04-11-2008 02:49 AM
FS: UT: OEM 02 WRX springs, OEM 99 RS Springs, OEM 02 WRX Black Scoop - $5 Sandkicker RMIC Private Classifieds 7 12-07-2007 11:45 AM
JDM 6spd and Complete Rear End (Brembos!), WRX OEM Spoiler, WRX Radiator & Fans moss Private 'For Sale' Classifieds 48 09-21-2005 11:35 AM
