Old 02-08-2008, 01:13 PM   #1
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Default JDM NA 2.0 Pistons and con rods
hey I am looking to see where I can get some JDM NA 2.0 pistons. I know there are some NA JDM engines that came in the 2.0 variety. If anyone has any info let me know
Thanks
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 02-08-2008, 08:09 PM   #2
qtr_wrx
Member#: 109567
Is yours SOHC or DOHC?? mine is SOHC which is easier than the DOHC
JDM NA 2.0,,,,,,,,, before 98 I have no idea about them? 98~05 are SOHC, 120hp @ 5400rpm (bore/stroke is same as ej205 engines, but with higher CR,,,,,, mine is 10:1)
06~08 are DOHC, 165hp @ 6400 rpm (redline is @ 7600rpm!! bore/stroke is same as ej205 engines, but CR is 11.2:1 some countries get 11:1)
hope that helps
qtr_wrx is offline   Reply With Quote
Old 02-09-2008, 10:54 AM   #3
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
I have a EJ25 but I am looking for stock NA pistons that will fit the EJ20 bore. Playing around with the various motors I have in the garage.
Yeah if you come across an motors over there like yours I woud be very intreseted in the internals.
Thanks
Josh
Old 02-13-2008, 09:27 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Josh,
Do you care what year? I've got the pistons from a 1990 Ej20D. It's something like 9.5 or 9.8 to 1. Came in a closed deck block with heads pretty much identical to the Ej20G heads used on the first generation legacy.
Nippon Motors in CA usually has these motors in stock. You've just got to be sure to ask for the DOHC NA and not get a SOHC NA 2.0l...
Old 02-13-2008, 09:29 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
How do these motors compare to the 2.5 NA ones?? a closed deck 2.0 NA motor is def. rare!
mxpunk is offline   Reply With Quote
Stock 2.0 and 2.5 pistons and offset col5555 Built Motor Discussion 1 07-06-2009 12:24 PM
Parts swap needed: My stock 2.5 crank and rods for your stock 2.0 crank and rods. HamFist RMIC Private Classifieds 4 04-17-2009 10:10 PM
FS: JDM V4 STi pistons and connecting rods A-Dev VIC Private Classifieds 1 01-17-2007 03:08 AM
FS: 2.5 RS turbo forged JE pistons and Crower rods Jude DeMeis Private 'For Sale' Classifieds 2 01-16-2005 09:18 PM
NA 2.5, H4 and 3.0, H6 Alpha1 News & Rumors 19 06-02-2003 04:39 PM
