Old 02-08-2008, 02:40 PM   #1
rutuner18
Member#: 142294
1997 Brighton
Red/Black/Silver
Default ej22e n/a tuning questions
I have a 98 impreza with a 2.2 L engine. I have only done moderate work to the engine itself. Is it worth trying to build this engine any further? I'm not looking for a gargantuan amount of power, just something I can flog the heck out of every once in a while without any worries. However, I am really short on cash. What 2 do? I heard that this is one of the toughest engines subaru built. Is that true?
Here's my current setup...
I know there will be some flaming, That's been my experience thus far. I just want honest opinions.
Thanks,
Rutuner18
aka. Brandon
rutuner18 is offline   Reply With Quote
Old 02-08-2008, 02:49 PM   #2
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Looks like you put a lot of work into the exterior. I like it.
Start learning about Enginuity. There is an Enginuity tuning thread somewhere in this N/A forum. All you need is a tactrix cable ($75), a windows laptop, and the ability to read up on the proper tuning methods.
I used Enginuity and it really made a difference in torque throughout the powerband.
sc00ter is offline   Reply With Quote
Old 02-08-2008, 02:55 PM   #3
SilverSubie2.5
Member#: 136144
2010 STi
I was pretty sure Enginuity does not support pre-05 ECU's, maybe you know something I don't though.
SilverSubie2.5 is offline   Reply With Quote
Old 02-09-2008, 10:51 AM   #4
Project GC4-RS
Member#: 128264
1997 "GC8wannabe"
Brilliant Red
siic mirrors bro
Project GC4-RS is offline   Reply With Quote
Old 02-09-2008, 12:23 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
No RomRaider (formerly Enginuity) for you......
Not much you're going to be able to do with the motor as it sits. You could find a good EJ25 shortblock and put your EJ22 heads on it for a high compression frankenstein motor....but outside of some sort of swap....you're looking at minimal gains.
Jay Storm
Old 02-09-2008, 03:12 PM   #6
John*G
Member#: 19562
95 coupe
red
I have, in the past, added an aluminum flywheel, light weight pullys, and Delta re ground cams to a 2.2. It felt very strong, especially compared to the 1.8 that was in there previously. This was in a 95 coupe that went on a diet.
I also cleaned up the ports, in the bowl area under the valves. and had an intake, headers and an exhaust. At the same time I also owned a 2003 with the 2.5, a much heavier car. The 95 felt faster.
The 2.5 swap is much easier and probably can be done for just about the same cost. And in the end have more power.
If you want to save the 2.2 get a pully,and reground cams from delta. If it is time for a timing belt change there is your excuse as it is not much more work.
John*G is offline   Reply With Quote
Old 02-09-2008, 06:47 PM   #7
subyboy
Member#: 119432
2005 Impreza WRX
World Rally Blue
This might sound pretty weird but I had a 99' 2.2L w/ 2.5 DOHC heads. I was running the 2.5 injectors and it pulled really hard. I "raced" my friend with a Nissan Sentra SER with I/H/E, from a 40 mph roll to 80 and he only put one car length on me, The timming was off and it ran rich to 3500 RPMs. If you were to put a fuel controller on it to fix that little problem with the fuel and have the timming set correctly you should have alot of power. Just my two cents.
subyboy is offline   Reply With Quote
Old 02-09-2008, 10:14 PM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I think you should find yourself a used EJ25 shortblock. Just like Jay said, throw your EJ22 heads on it with some cams and a complementing exhaust system. But keep in mind the EJ22 heads will run out of steam up top, especially since you would be shoving 300 cc's more air through them.
~Josh~
Old 02-09-2008, 10:23 PM   #9
rutuner18
Member#: 142294
1997 Brighton
Red/Black/Silver
Wow. A lot of good ideas! Keep them coming! Still unsure.
Old 02-09-2008, 10:25 PM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
maybe you could try getting a SAFC to scale fuel or something then run meth so you can run uber timing
in reality though its cheaper to go turbo then anything..high hp n/a is way expensive for EJ motors
mxpunk is offline   Reply With Quote
Old 02-09-2008, 10:27 PM   #11
rutuner18
Member#: 142294
1997 Brighton
Red/Black/Silver
Will the Ej22e hold up to boost? I'm only talking about nine or ten pounds which isn't exactly "low boost". I have stock internals and top end, bigger injectors and a fuel pressure regulator, with a msd ignition system (minus the box, that's next week ). What would I have to do to keep her together. The engine has 152,000 on her. Ideas ? ? ? ?
Thanks everyone for the input so far!!
Old 02-09-2008, 10:32 PM   #12
GrundleJuice
Member#: 165749
what engine management are you using? most n/a ecu's wont be able to compensate for anything above atmosphere or maybe 1 psi more in terms of fuel ratio (even if your injectors can). I like how you say you are short on cash but still ask about turbo-ing the little old lady. :-)
EJ22/EJ207 hybrid ECU question Bohemian_Funk Other Engine Management 8 10-19-2010 09:41 PM
EJ22 to EJ25 Swap Questions. TooManySubies Subaru Conversions 9 02-03-2007 02:50 PM
Another ej22 into WRX conversion question!!! ParadiseWRX Subaru Conversions 7 10-08-2004 01:42 AM
EJ22 into '94 impreza question chip4761 Subaru Conversions 14 03-17-2004 10:58 PM
Cobb Tuning Questions WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-27-2001 10:59 AM
