Old 02-08-2008, 08:44 PM   #1
starace
Member#: 157206
07 Super STi
Default Please critique this log...
http://www.box.net/shared/xhbg0v78kw
Here are my mods:
06 WRX
+20 Block
Cobb - Billit Crank
Eagle H-Beam Rods
Cp Pistons
Ported Heads
+1 mm BC Valves
BC Single Springs/Locks
GSC Stage 2 Cams 274's
FP Red 8 CM
3" Agency Power Hard Turbo inlet
EQL Header
Custom 3" TBE
Perrin - FMIC,Big MAF,Fuel Rails
TGV delete
Stock Modded Injectors 995 CC
Unorthodox underdrive Pulleys
starace is offline   Reply With Quote
Old 02-09-2008, 02:16 AM   #2
benw
Member#: 103320
1998 swapped
Forester L
some serious knock.
what were the AFRs when boost comes on?
benw is offline   Reply With Quote
Old 02-09-2008, 02:42 AM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Wow, that thing hasn't exploded yet???
Old 02-09-2008, 03:36 AM   #4
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Heya mate - try posting the log in the RomRaider forums, theyhavesome good opensource tuners there who will generally help and give direction if something is up with your log
wrxsti.l is offline   Reply With Quote
Old 02-09-2008, 09:12 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
That thing looks fast! From 50-100mph in 5sec?
His IAM is 1 which is fine atleast.
akira02rex is offline   Reply With Quote
Old 02-09-2008, 12:45 PM   #6
turboge
Member#: 35076
2004 507whp Wagon
4800-up looks good. You're going to cause damage with the -11 knock feedback before that though.
turboge is offline   Reply With Quote
Old 02-09-2008, 06:01 PM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I don't think so. I think FLKC is masking the knock.
Take a look at timing going from 4731->4899 rpm. It drops. Then take a look at timing going from 5718->5894 rpm. 14.5 degrees total timing at 7034 rpm seems low to me, even considering the load.
I posted my comments on romraider, but I just want to add that you can blow your engine with this tune. You should get this fixed as soon as possible.
And double check your rough correction ranges.
mickeyd2005 is offline   Reply With Quote
Somebody please check this log...... XPT STAGE 2 RACE MAP eMoneyyy Engine Management & Tuning 2 07-06-2009 01:17 PM
Gurus, critique my logs and map, please phlegmon Open Source Reflashes 4 06-03-2008 10:17 PM
Critique my Log xcntrk75 UTEC 5 05-19-2007 08:56 AM
Please critique this computer... GarySheehan Off-Topic 67 09-13-2004 06:40 PM
Critique This Please. 2.5RSMatt General Community 39 11-19-2003 08:27 PM
