#1 |
Member#: 47746
Vehicle:2000 Impreza 2.5 RS Midnight Blue |
ok, so im going to be asembling an engine tomorrow for a 00 rs. only thing i dont know how to do is set the timing. any tips or info? thank you!
also, when im swapping the engine (taking out old on and putting new engine in) is it easier to pull the trans out with the old engine and assemble it and put it in as 1 unit or leave the trans in and just pull the engine....
#2 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
If you don't have a manual, there are a few links to articles explaining how to do it. A search should bring up more than a few discussions as well.
I'd leave the trans in the car......less stuff to unbolt from underneath. Jay Storm |
#3 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
Definately leave the tranny in the car, you may think its just 8 or 10 more bolts to undo, but it is just a hassle. Timing is set via the stock ecu, assuming you have a stock ecu...and not some form of piggy-back or standalone engine management system.
I use a steel rectangular box tubing section positioned over the strut tower bolts, along with a section of chain, to hold the tranny up. This makes it easy to pull and re-install motor. Or you could just leave the jack there...but I only have 1 jack... ~Josh~ |
#4 |
Member#: 47746
so all i have to do is but the belt on the car and the computer will do it all by its self??
#5 |
Member#: 5218
#6 |
Member#: 120002
RMIC
Vehicle:2000 2.5 RS, '95 Legacy w/325k mi (RIP) |
To set cam timing all you have to do is make sure the timing marks on the crankshaft sprocket and cam gears are all pointing straight up and aligned with their appropriate timing marks on the block. The timing marks for the cams are on the backing plate for the timing cover and the timing mark for the crank is right by the crank position sensor.
#7 |
Member#: 5218
....and the timing mark for the crank pulley is the hashmark directly on one of the sensor "teeth" on the backside of the pulley.....NOT THE ARROW on the front of the pulley.
Jay Storm |
#8 |
Member#: 82556
Vehicle:1996 Legacy L wagon |
So... what they're saying is, better invest in a manual that has diagrams before you thrash your new interference motor and have to replace it right away again.
#9 |
Member#: 5218
I wouldn't even consider doing it without a manual of some sort.....
Jay Storm |
#10 | |
Member#: 45875
NESIC
Vehicle:92 SVX, STG3 5MT 97 Legacy, SwapInProgress |
... I thought I killed my engine in a legacy ![]() It starts and runs like new and then as it warms up it freaks out, throws a cam code... then forget about driving it.... scanner shows 15 to 47 degree timing advance ![]() Guess i'm under the hood again tomorrow, hope its okay... if I damaged a valve it wouldn't run smooth at startup like it does would it? it was a 97 SOHC california... did they still use the non-int 96 2.2??? |
#11 | |
Member#: 5218
If you read the procedure in the FSM....the arrow is used to put the pistons in a safe spot for timing belt removal because one of the cams will spring off the lobes when you release the tensioner.
#12 |
Member#: 45875
NESIC
good to know... the shop computer listed no such step.
after reading through a bunch of really old threads involving "the arrow" i am feeling better about this. Looks like if it was interference I would have noticed when I hand-turned the engine, kinda sucks to have to do it again, but o well... I nearly had that new engine early. |
#13 |
Member#: 45875
NESIC
I re-read the tech doc just to make sure I wasn't an idiot and it only mentions that the sprocket has a timing mark... it also clearly points to the front face of the sprocket
...so yeah, if you take your car to an independant shop make sure they know, cause they probably have the same "vague-enough-to-be-wrong" systemAnyway, for all that would like to know, the... 97 2.2 Cali. SOHC is non-interference ...or I'm the luckiest prick alive ![]() |
| Thread Tools | |
| Display Modes | |
| Help! Finally Put The Engine Together And In Car! Engine Is shaking alot,long explain | ToneWrx02 | Newbies & FAQs | 7 | 03-21-2010 05:12 PM |
| I have 1 hour to remove my doughnut gasket and put my car back together- any advice? | higgins14 | New England Impreza Club Forum -- NESIC | 11 | 04-05-2009 04:04 PM |
| Had alignment done, went back once, still pulls right with an explination this time | tungsten | Brakes, Steering & Suspension | 12 | 04-05-2007 11:06 PM |
| just put my system together...and am kinda dissapointed | rhd | Car Audio, Video & Security | 122 | 05-10-2005 01:54 PM |
| '00, '02 and '05. Put them all together and what do you get? | AcquaCow | Member's Car Gallery | 24 | 05-03-2005 07:54 AM |
