Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 02-09-2008, 03:45 PM   #1
NycFox
Member#: 145639
2008 WRX
Default Anyone on here with AP or Engunuity?
Whatever the spelling is:
Is there anyone on here kind enough to help me out.
Ive been havibng a CEL for my front o2 sensor.
After some time, Im beginning it may just be the flash I got.
I dont want to dump $100 on it because Im not %100 a new flash may correct the problem.
Anyone here willing to help me out?
Throw you 20 bucks?
Worth a shot?
NycFox is offline   Reply With Quote
Old 02-09-2008, 04:02 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What is the exact Pxxxx code?
What exactly are you asking for someone to do?
The AP is "married" to one car/ECU and can't be used to flash another car without first being "unmarried" from the first one and putting that one back to stock. So if you want someone with an AP to flash a map to your car that isn't going to happen.
Old 02-09-2008, 04:07 PM   #3
NycFox
Member#: 145639
2008 WRX
P0031.
Yeah, I figured that.
I guess Im just wanting to see if a different flash can correct the problem before I spend the money on a new o2 sensor.
Old 02-09-2008, 04:24 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well that's a heater circuit problem, should have nothing to do with a tune or flash. But it could be from a wiring problem, sometimes the harness gets damaged from work that was done on or around the engine, or from coming into contact with the exhaust. Check that first.
Old 02-09-2008, 04:28 PM   #5
NycFox
Member#: 145639
2008 WRX
Well I did a search and saw you had wrote that so I did check it but all the wires are fine.
Old 02-09-2008, 04:37 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the wires are ok it's most probably the sensor itself, the heater elements do burn out sometimes. If you have the FSM there is a procedure to troubleshoot the code to determine if it's the sensor or not.
Old 02-09-2008, 04:44 PM   #7
NycFox
Member#: 145639
2008 WRX
FSM?
Do you think given my stage2 setup..That is what is causing all the extra heat?
How long do you think a new sensor would hold out for? Another 7xxxx miles?
Thx
Anyone on here live in Elizabethtown or at least familiar with it? wcu25rs South East Region Forum 6 07-26-2008 09:39 PM
Anyone on here with an RX? rally_rx Pre-2002 Factory Turbo Powertrain 10 08-28-2005 01:17 AM
anyone on here with an sti in pheonix area, please email me.. CBRDSpeedfactory Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-13-2004 03:00 PM
Anyone on here with Adult ADD? Eric SS Off-Topic 38 11-02-2003 09:13 PM
Blue WRX with CF hood on Pomona - anyone on here? Big_Hitter Rocky Mountains Impreza Club Forum -- RMIC 1 08-22-2003 11:47 AM
