Old 02-10-2008, 12:40 AM   #1
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Default Problem reading ECU with ECUFLASH
2007 Impreza 2.5i
I cannot get passed picking which car to read. All it says is "error check log"
It doesnt get passed the init sequence.
using v1.34
Do i need the test connectors for a 2.5i???
Subyroo2.5 is offline   Reply With Quote
Old 02-10-2008, 08:51 AM   #2
Tea cups
Member#: 103136
You need to connect the green test mode connectors under the dash. You need to wait until prompted to turn your ignition to on (to on, engine OFF) and then when you do so, immediatlely hit the OK button. You need to be using a tactrix cable. If all this does not help you then read here:
http://www.romraider.com/Documentati...aiderFAQ#toc12
Tea cups is offline   Reply With Quote
Old 02-10-2008, 09:36 AM   #3
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
I thought you only needed the jumpers for WRX!!??
Old 02-10-2008, 10:02 AM   #4
Tea cups
Member#: 103136
Read the FAQ I posted! You need to connect the test mode connectors (ALL Subarus do regardless). The jumper is a whole separate deal that has nothing to do with the test mode connectors and is only applicable to the 16-bit ECU (ex. 02-05 USDM WRX). So, no, you don't need the jumper but ALL models have to be in test mode to read/flash with Ecuflash.
EcuFlash unable to read ECU snobrder_ad Open Source Reflashes 13 07-23-2008 07:04 PM
Problems pulling my ECU with ecuFlash AruisDante Open Source Reflashes 13 06-13-2008 08:49 AM
Problem with EcuFlash & Enginuity reading maps differently! akira02rex Open Source Reflashes 3 03-19-2008 02:04 PM
2007 2.5i EcuFlash prob reading ECU RaceFaceXC Open Source Reflashes 3 02-21-2008 09:40 AM
need help! can't read ecu thru ECUFlash sgmongoose Commercial ECU Reflashes 9 08-08-2007 11:58 AM
Message Board Statistics All times are GMT -4. The time now is 04:43 AM.
