Welcome to the North American Subaru Impreza Owners Club Thursday October 2, 2014
Old 02-09-2008, 10:40 PM   #1
Storm
Member#: 5218
96L Most Over-
Developed Beater
Default Interesting NA build
I wish I could say this was my build.....
http://www.rs25.com/forums/showthread.php?t=74916
Jay Storm
Old 02-09-2008, 11:42 PM   #2
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
That is a sick looking motor. The throttle set up is so unique - first I've ever seen like it.
axelthrasher is offline   Reply With Quote
Old 02-10-2008, 12:23 AM   #3
kevinh211
Member#: 56297
2004 STi HTA Green
28psi, MSPT Tuned
wow! that is the coolest throttle set up i have ever seen!
for those that dont want to click the link...
Originally Posted by Mobecktekniske
No, sorry..
This manifold I made.
Lets do the story.
Here are all the parts cut out from aluminium plate, + an injector holder and a bellmouth from TWM
Here the parts are welded together
Now its got the anodiseing threatment in gold colour
Here showing the new port shape against the manifold
The giljotine throttle slide is an sandwitch construction
and I did the throttle slide and top plate in black for the good looks
To avoid friction problems I made the throttleslide roll on small bearings.
And the bearings has adjustable height form the underside
50% power
Full throttle, wide open. No restrictions
Manifold seen for the front
Please dont mind if my English writeing is wrong sometimes, this is not my lanuage.
Best regard
Ole Mobeck
kevinh211 is offline   Reply With Quote
Old 02-10-2008, 01:21 AM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
wow jdm!++
mxpunk is offline   Reply With Quote
Old 02-10-2008, 07:22 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
More from the build....
Originally Posted by Storm
Sending you a PM Ole. Those cams are way more agressive than the special set of DOHC cams I got out in the garage.
Here are some moore camprofiles for the SOHC
Numbers below mean
duration in/out measured at 0.1mm without clearance
duration in/out measured at 1.0mm without clearance
Max valvelift in/out without clearance
lift at top dead center without clearance
251 / 238
197 / 192
10.30 / 8.90mm
0.40 / 0.40mm
259 / 246
205 / 200
10.55 / 9.10mm
0.65 / 0.55mm
261 / 249
212 / 207
10.80 / 9.30mm
0.95 / 0.80mm
264 / 254
220 / 215
11.00 / 9.50mm
1.25 / 1.05mm
270 / 262
228 / 223
11.25 / 9.70mm
1.80 / 1.55mm
270 / 269
234 / 231
11.50 / 9.90mm
2.30 / 1.95mm
286 / 284
244 / 240
11.80 / 10.20mm
3.10 / 2.65mm
291 / 290
252 / 248
12.05 / 10.40mm
3.65 / 3.10mm
296 / 294
258 / 255
12.35 / 10.65mm
4.15 / 3.55mm
296 / 297
258 / 254
12.35 / 12.10mm
4.15 / 3.75mm
Best regard
Ole M
would you rather... turbocharge, supercharge or NA build up wop Normally Aspirated with bolt-on Forced Induction Powertrain 26 06-26-2008 02:35 AM
Cobb Tuning 2.5L NA Build - Dyno Results [LONG] Trey Normally Aspirated Powertrain 99 04-03-2007 03:06 PM
Going from NA build to Turbo build G.Subramaniam Normally Aspirated with bolt-on Forced Induction Powertrain 33 07-16-2005 10:47 AM
Best parts for NA build up Stroke Normally Aspirated Powertrain 7 04-09-2003 04:47 PM
NA Build-up '99 RS Drifter Normally Aspirated Powertrain 5 05-10-2002 03:41 PM
