Old 02-13-2008, 03:44 PM   #76
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
Originally Posted by EvoSpeed View Post
Flat out.
Derek- I trust willi to be thorough and objective and upon ANY marked improvement i will probably buy one. I believe others will also.
Yep. I'd say this is what I'm waiting for before picking up the Grimspeed package. Let's get this show on the road!
SilverSubie2.5 is offline   Reply With Quote
Old 02-13-2008, 05:24 PM   #77
Syph3r_
Member#: 150804
2006 Impreza 2.5i
CGM
Is he getting both the IM and the TBS to test?
Sounds to me like he is only getting the TBS which isn't a bad thing because if I get anything, most likely it will just be the TBS until I see that the IM spacers do something more for the trouble of installing them.
Syph3r_ is offline   Reply With Quote
Old 02-13-2008, 05:44 PM   #78
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
I'm pretty sure he is just getting the TBS. For most people, it has been the other way around. That is, getting the IM spacer and not the TBS, because the IM spacer does work. There is no questioning that the IM spacer significantly reduces IM temps, which will equal out to a small power gain. And from what I've read, installing them isn't TOO much hassle. More work that the TBS, but still 45 min-1 hour.
Old 02-13-2008, 07:25 PM   #79
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Originally Posted by littlebhatia View Post
Follow up
I have been driving like maniac, it's been snowing. The temps have been below 20 degrees since I filled my tank (89 octane with ethanol). That is the background. The noise of the car is straight up MEAN. Normally I get 260 miles per tank. I am at 280 and the light is about to come on.
My thoughts are if I drive normal and the environmental conditions improve.... I quite possibly could see more improvement.
The consensus is that the people who ACTUALLY have a TBS do like the product regardless of what those who do not have one blog. No complaints yet.
Finally, thanks to Group A for stepping up to the plate - Respect.
this is kinda a threadjack, but its about miliage so its distantly relevant to TBS's. Anyway, i have a 07 2.5i and i use 87 gas no ethanol and i get 340 miles a tank on avg. I dont drive like a maniac all the time, but i def do drive hard more than enough. Just wondering what could account for such a huge difference in mpg's?
RaceFaceXC is offline   Reply With Quote
Old 02-13-2008, 08:52 PM   #80
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
Mix of city/highway, location (FL vs. Omaha), how much idling he does ('cause its cold out), tire pressures... for that matter, tires, how hard you flog it, etc.
Personally I get ~260 a tank, straight city with a good deal of flogging.
ArcticWolf is offline   Reply With Quote
Old 02-13-2008, 10:05 PM   #81
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
mines all city too, my highway mileage is horrible. the 06's have a 15.5 gallon tank? i keep a close check on my tires but i have pretty mild weather. just seems like its too much of a difference to attribute to tires, air temp. But i cant complain either!
Old 02-13-2008, 10:10 PM   #82
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
15.9 gal tank, close enough. I fill around about the bottom of the gauge, barely before the light goes on (3 gal left)
Old 02-13-2008, 10:25 PM   #83
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
what mpg's you getting? im between 25-28 all city driving... ill get 23-25 on highway (80 mph)
Old 02-13-2008, 10:27 PM   #84
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
rough number crunch = 20 all city, I don't see highway too often, town's not that big and I don't go anywhere (yet).
Last OT post by me on this thread - we can do PM's if you want.
Old 02-13-2008, 10:35 PM   #85
GADGTGUY
Member#: 20614
03 TS Wagon
BRP
Hey Guys,
I was just warned that my post violates some sort of vendor rules.
Sorry if I offended anyone.
I guess if you want to disucss things we can take it off-line.
D.
GADGTGUY is offline   Reply With Quote
Old 02-13-2008, 11:56 PM   #86
littlebhatia
Member#: 170532
07 2.5i
obsidian black
i run my tires 23 front and 20 rear in snow and have this huge thule rack with a fairing on the roof.
littlebhatia is offline   Reply With Quote
Old 02-14-2008, 03:47 AM   #87
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Nyah, aren't you supposed to run your tires a little higher in the snow?
I get about 22 MPG, I go about 320 miles for a tank of gas. I don't accelerate hard all the time, but I do occasionally. I suspect that if I drive less on highways, my MPG would increase. Cruising at 3k for 30 minutes is blah.
I run my tires 37F 35R, Kumho Ecsta ASX, which is now out of production.
My mileage does get a bit higher every once in a while. But I think it's going to stay there for a while, until I get an intake or something.
formula91 is offline   Reply With Quote
Old 02-14-2008, 07:49 AM   #88
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
I'm suspecting you meant 33/30.
Old 02-14-2008, 11:17 AM   #89
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
I have the same car and i get about 280-300mpt (miles per tank) city or 360-380mpt highway then gas light and i drive slow and quick with some WOT runs here and there.
Do you not have any street lights in your town? I see about 50-60 on my 15 minute commute in the burbs. Does your "driving hard" consist of WOT for more then a second or two?
EvoSpeed is offline   Reply With Quote
Old 02-14-2008, 11:58 AM   #90
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
300mpg?!
Counterfit is offline   Reply With Quote
Old 02-14-2008, 11:59 AM   #91
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
Originally Posted by Counterfit View Post
300mpg?!
edited
Old 02-14-2008, 08:09 PM   #92
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
My drive to work is pretty short. 15 mins and i stop twice at stop signs and go over 3 speed bumps before im out of the neighborhood. then i do 55 for about a mile and a half. stoplight. then i do 65 for another 2 miles. stoplight. then i do 45-50 for a mile with atleast on stop for a light. up to 3 stops if i get all reds. then 70 for 3 miles. stoplight. Its rural highway/small town driving but not freeway driving. Yeah, when i get on it ill go WOT til im afraid to exceed the speedlimit anymore. My fav place to do it is one wide low traffic road where the limit is 65 and i usually go WOT til atleast 80. anyway, im real happy with my milage, better than i had thought it would be when i saw the EPA sticker on the window b4 i bought.
Old 02-14-2008, 10:04 PM   #93
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, TBS on it's way to me for testing. I'll let you guys know when it gets here. Who knows how long Customs will run it on their car before letting me have it
Old 02-14-2008, 11:05 PM   #94
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
HA! Good to hear, can't wait!
Old 02-14-2008, 11:16 PM   #95
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, since the community is interested in this, what do you guys want to see?
I have a plan for what I want to test and how to do it, but what data or test would you all be interested in?
Old 02-14-2008, 11:17 PM   #96
Chi_San
Member#: 53558
2002 WRX Wagon
HP, torque, AFR.
Chi_San is offline   Reply With Quote
Old 02-14-2008, 11:25 PM   #97
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by Chi_San View Post
HP, torque, AFR.
Unless you want to donate dyno time, HP and torque are going to be from a software based road-dyno. AFR is covered, I just installed a LC-1.
Old 02-14-2008, 11:32 PM   #98
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
Well, what results CAN you offer? Whatever you have, I'm sure we're willing to hear it.
Old 02-14-2008, 11:40 PM   #99
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The way I'm planning on attacking it is via logging with Enginuity. I'll be able to report back in any changes in engine breathing or AFR. Also, from looking at the change in RPM over time, software can calculate HP an torque, but the evaluation of breathing will have more resolution. Realistically, a TBS can only influence the amount of air entering the engine, so the airflow will tell the tale for power. I'll also be using the RPM data to calculate intervals (i.e., does it go from 50-70 or 20-50 faster or slower than it used to, etc.).
Old 02-14-2008, 11:46 PM   #100
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
Sounds acceptable. My PayPal account awaits your results!
Throttle body spacer PARANOID56 Normally Aspirated Powertrain 13 12-14-2005 08:51 PM
Calling all cars with mud flaps. mrtrex Member's Car Gallery 16 02-05-2003 01:02 PM
calling all cars with 18inch wheels icemanzx18 Member's Car Gallery 9 05-03-2002 11:33 AM
throttle body spacer haven Normally Aspirated Powertrain 6 09-30-2001 01:45 AM
Nitrous Throttle Body Spacer Joncas Normally Aspirated Powertrain 5 07-15-2001 04:06 PM
Message Board Statistics All times are GMT -4. The time now is 07:22 AM.
