Old 02-15-2008, 08:50 PM   #101
GrundleJuice
Member#: 165749
Williaty: if you can, test the afr and other parameters in the entire rpm range or in a few different ranges to see where it helps/hurts the most. if you PM me data id be happy to make some graphics to show visually what changes occurred like graphs, plots, etc.
Old 02-15-2008, 09:05 PM   #102
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That's already part of the plan.
Old 02-26-2008, 02:46 AM   #103
dan13
Member#: 157726
hunk of metal
bump for this
dan13 is offline   Reply With Quote
Old 02-26-2008, 09:23 AM   #104
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
yea i wanna see the results...i might look into these if it turns out they are worth something (anything is better then nothing)
zavier is offline   Reply With Quote
Old 02-26-2008, 11:56 AM   #105
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Customs is still sitting on the package or something. I'll let you guys know when I get it.
Old 02-26-2008, 11:58 AM   #106
dan13
Member#: 157726
hunk of metal
lol i bet they are using it
Old 02-26-2008, 12:14 PM   #107
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
LIARS! They are trying to screw you on this free part.....
EvoSpeed is offline   Reply With Quote
Old 02-26-2008, 01:44 PM   #108
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
I ordered the Group A Pitch Stop (engine mount) and it took 10 days from shipment to the time it arrived in Minnesota (right next to canada mind you). Must be homeland security issue... automotive parts = terrorism risk.
LTracer is offline   Reply With Quote
Old 02-26-2008, 01:47 PM   #109
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
My cosmo intake came from Canada and took only one day to clear customs. Then it took the standard shipping time. I got it in the standard 7-10 day shipping time and upon watching it with the tracking info it didnt take any longer because of customs whatsoever.
Old 02-26-2008, 03:54 PM   #110
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by rougeben83 View Post
Apparently these don't have any gains whatsoever for the DOHC phase 1 EJ25 at least. Pat Olsen dyno'ed his with one. Search this forums for his thread.
I'll be curious to see what williaty's testing shows. I had no reliable way to compare fuel consumption, so I only had the dyno results.
Log MAFv, Massflow, Load, MRP, and RPM without the TBS. Install TBS and make the same logging run again. If all those variables didn't go up (MAFv, Massflow, and Load are really the same thing, but it's nice to have the computer spit them out in different "views" for you), then the TBS doesn't work.
After the fact, I realized that I could have done something like this on the dyno. I ran the car on a Dyno Dynamics, which is a load bearing dyno, so I could have had them run the car up to Xmph at Y dyno load both with and without the TBS installed. Then I could have logged load and MAF using my Pocketlogger to see if there was any difference. Unfortunately, like I said I came up with that thought after I had already done the dyno testing, so it was too late to try that out.
Originally Posted by 06OutbackSport View Post
The TBS changes the whole thing. The powerban shifts down about 750 RPM so it explodes at 3250 RPM... which makes a world of difference. The sound from the SRI, which is incredible to begin with, starts at a lower RPM. It also feels like the lost torque at the very low RPM's (1500-ish) is back to normal. Quite worth it for a few extra horsepower and that amazing sound!
Originally Posted by GADGTGUY View Post
We never said that this product makes huge HP gains. All we say is that it helps restore lost torque and low end HP when an intake is installed on the car. It also adds a bit more to the car when the stock intake is still used.
This claim pops up repeatedly, but it just doesn't make any sense. A larger intake plenum should raise the RPMs at which peak torque occurs, not lower it. Subaru actually used variable volume intake plenums on the SVX's EG33 and the '01-04 Outback EZ30. The mechanism works to make the plenum smaller at low RPMs and larger at high RPMs so that there are effectively two torque peaks.
With that said, intake manifold design is a pretty complex thing, with lots of variables at play that can affect how well the manifold performs. Longer runners tend to boost low end performance at the cost of top end. Obviously the TBS won't change the length of the runners, but perhaps there is some improvement in low end with the TBS as a result of the throttle body to intake valve distance being increased? My personal dyno testing seemed to show essentially no difference in TBS vs. non-TBS down to maybe 3000 or 2500rpm or so, but I didn't try to test any lower than that.
Originally Posted by RaceFaceXC View Post
what mpg's you getting? im between 25-28 all city driving... ill get 23-25 on highway (80 mph)
You get better mileage in city driving than in highway driving?! How do you manage that magic trick? Even with a 10% shorter-than-stock 5th gear (so I'm doing 10% higher RPMs on the highway) I easily get better mileage on the highway than in city driving.
The way I'm planning on attacking it is via logging with Enginuity. I'll be able to report back in any changes in engine breathing or AFR. Also, from looking at the change in RPM over time, software can calculate HP an torque, but the evaluation of breathing will have more resolution. Realistically, a TBS can only influence the amount of air entering the engine, so the airflow will tell the tale for power. I'll also be using the RPM data to calculate intervals (i.e., does it go from 50-70 or 20-50 faster or slower than it used to, etc.).
I assume you have some good, level testing ground where you can get good repeatability? You seem to have this thought out pretty well, so I imagine the answer is YES, just checking.
Pat Olsen
Old 02-26-2008, 04:16 PM   #111
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Airport FTW
Old 02-26-2008, 08:02 PM   #112
GrundleJuice
Member#: 165749
Airport FTW
Hope you have permission to use it... i was chased out of the airport by the sheriff when trying to find the top speed of a new M3 and got away. They will arrest for that.
Old 02-26-2008, 08:57 PM   #113
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Taken care of.
Old 02-27-2008, 01:52 AM   #114
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
Williaty has connections yo!!!
leafs fan is offline   Reply With Quote
Old 02-27-2008, 02:51 AM   #115
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
You, sir, are an idiot. Next time make sure to load up the car with 4 of your buddies.
Old 02-27-2008, 03:32 AM   #116
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
How can you be so quick to call someone an idiot? Do you even have the facts??
First off it was an M5.
The kid had the limiter removed.
He was doing in excess of 160.
He had a car full of extra weight.
He was 18. The car had 500hp.
If someone who most obviously has more driving experience and brains than an 18 year old wants to drive the **** out of an M3 at an airstrip by all means let him. I think he will know when to brake, and I don't think he will invite 4 of his friends either.
I cant believe that you can compare people like that.
Subyroo2.5 is offline   Reply With Quote
Old 02-27-2008, 10:39 AM   #117
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
waits to see results.
Last edited by moogoob; 02-27-2008 at 11:25 AM. Reason: edit: \/ \/ \/ sorry... removed my OT comments
moogoob is offline   Reply With Quote
Old 02-27-2008, 11:07 AM   #118
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Wait, did a mod move this thread from NA to OT?
Old 02-27-2008, 02:50 PM   #119
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Looks like OT is invading the rest of the forums, they must be getting bored in there.
Chi_San is offline   Reply With Quote
Old 02-27-2008, 07:22 PM   #120
dan13
Member#: 157726
hunk of metal
I hope not.
Keep this on topic guys.
Old 02-27-2008, 10:23 PM   #121
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I call it like I see it. Trying to test the top speed of your car on a runway that you shouldn't be on, running from the cops, and then coming onto a internet forum and telling others about it as though you were providing valuable advice strikes me as pretty frickin' idiotic.
Old 02-27-2008, 11:31 PM   #122
GrundleJuice
Member#: 165749
Pat Olsen
Yeah, i still dont understand that, but whenever i go out of town for a race or something me and a couple buddies caravan and we are doing 80 or so most of the time and my mileage goes to ****. I dont know why, just thought that my engine being spun up to 3400rpm was drinking it up like a fish. I havn't crunched number for mpg's but i have noticeably fewer miles on my trip odo when i have to fill up.
Yeah, i heard all about that dumb****. And in my defense, I was 24 and work @ an airport as an A&P mechanic and have my pilots license so I am very familiar with the runway, its length, conditions and such. I also had a radio to monitor traffic so I know no one was in the pattern. If you want to pass judgement about my choice to break the law, thats fine but dont ever assume that I am putting anyone else in danger or being careless. I think that doing illegal high speed runs on a runway is a much better idea than doing them on a public road. And I don't know but I could guess that you have exceeded the speed limit before on a public road. You endanger many more people by speeding (or even driving legally) on a public road than on a pristene strip of concrete closed to other vehicles. Well the speed limit on a runway is a bit higher and there is no traffic. (no, runways dont actually have speed limits, I know. I'm making a point) It han handle very heavy aircraft traveling near 200mph, i think a 3500lb car designed to do 150+mph will be just fine. So next time you are about to call someone an idiot based on a breif vague description of what they did once, don't be a dickhead.
So if Williaty did the same thing as I, and didnt have his bases covered in terms of having permission to use said runway, I should have not warned him about it? I don't understand.
You sir, are a condescending prick.
Old 02-28-2008, 12:31 AM   #123
SilverSubie2.5
Member#: 136144
2010 STi
We need this thread. Please keep it on topic.
SilverSubie2.5 is offline   Reply With Quote
Old 02-28-2008, 02:31 AM   #124
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
At 80mph I'm doing 4000rpm with the Outback 5th gear I've got. Something definitely doesn't make sense. I'm trying to think of what could lead to such poor highway mileage (and such excellent city mileage). When you originally posted your mileage numbers I just assumed you had them backwards. To get 26-28mpg in city driving is even more unusual than getting 23mpg on the highway.
That's all great. I'm sure your employer would've been thrilled you were doing it, right?
Yes, I have. And when the police try to stop me for it, I pull over, because I'm man enough to accept responsibility for breaking the law.
You endanger many more people by speeding (or even driving legally) on a public road than on a pristene [sic] strip of concrete closed to other vehicles.
So if Williaty did the same thing as I, and didnt [sic] have his bases covered in terms of having permission to use said runway, I should have not warned him about it? I don't understand.
williaty's data gathering has nothing to do with trying to test the top speed of his car nor running from the police.
Oh, and let's keep this thread on topic. We need it.
Old 02-28-2008, 02:40 AM   #125
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
He didn't RUN from the cops, HE evaded them on his own turf. Something most anyone would do. RUNNING from the cops is a whole different show....
Stop calling someone on something that you have no right to. He was on PRIVATE property, in a controlled environment doing his thing. If you want to take it past there, feel free, but you made your point and so did we.
Throttle body spacer PARANOID56 Normally Aspirated Powertrain 13 12-14-2005 08:51 PM
Calling all cars with mud flaps. mrtrex Member's Car Gallery 16 02-05-2003 01:02 PM
calling all cars with 18inch wheels icemanzx18 Member's Car Gallery 9 05-03-2002 11:33 AM
throttle body spacer Haven Normally Aspirated Powertrain 6 09-30-2001 01:45 AM
Nitrous Throttle Body Spacer Joncas Normally Aspirated Powertrain 5 07-15-2001 04:06 PM
