Old 02-11-2008, 11:13 AM   #1
mattminer
Member#: 90642
WKD Everything
Default Reflash switch
Hi guys,
Im looking to add a switch for 'test connector mode' on my dash, Im wondering if i can leave the 02-03 jumper block attached all the time, or do i need to make a switch / find a dual switch to do this?
-M@
mattminer is offline   Reply With Quote
Old 02-11-2008, 11:37 AM   #2
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
Yes you can leave the flash block connected.
brettm is offline   Reply With Quote
Old 02-11-2008, 01:55 PM   #3
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
i made nice little plate with two switches and mounted it in the change holder thingy by the door. it works really nice. I know you can leave the power blocks connected...but i prefer not too. I think that if it was ok to do, then why design the circuit and make it optional??
Wheeler Bement is offline   Reply With Quote
Old 02-11-2008, 02:35 PM   #4
mattminer
Member#: 90642
WKD Everything
is there a good toggle switch out there thats like single switch, 2 connections?
-M@
Old 02-11-2008, 02:35 PM   #5
Zumble
Member#: 34860
2005 Forester CGM
can the car start at all when its in test mode? If it can't.. maybe I'll rig up a switch as a theft deterrent.
Zumble is offline   Reply With Quote
Old 02-11-2008, 04:22 PM   #6
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
What I do to make my life easier is I have some wires zip tied to my Tactrix cable, and near the USB Connector, i soldered the leads onto a switch... Then, on the OBD2 Ends, I ran some slack, and put a Male spade on 1 wire, and a female on the other... That way I dont have to reach under the dash plugging & unplugging all the time...
nperkins is offline   Reply With Quote
Old 02-11-2008, 04:34 PM   #7
mattminer
Member#: 90642
WKD Everything
nice!
im worried about leaving the jumper thing on my02 plugged in all the time, what exactly is it jumpering? i understand what the green test connector does, thats easy.
-M@
Old 02-11-2008, 05:03 PM   #8
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
you can leave the flashblock in... It doesnt do anything unless the gree test mode is connected as well.
Old 02-11-2008, 06:17 PM   #9
WeldingHank
Member#: 98645
2002 WRX Wagon
i've had my flash-block connected 24/7 for the better part of a year now. I have yet to have any issues with it.
WeldingHank is offline   Reply With Quote
Old 02-11-2008, 06:31 PM   #10
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
mine started in test mode...the CEL was flashing like crazy as well. I knew instantly what I did so I turned it off. don't know if owuld have driven around the block though.
Old 02-11-2008, 08:34 PM   #11
mattminer
Member#: 90642
WKD Everything
ok...so i broke out my FSM. apparently that connector simply connects data link connector pin 6 to the ecu pin a10, makes sense that nothing happens leaving it connected.
good enough for me
-M@
Old 02-11-2008, 11:38 PM   #12
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
I got a $2.00 black plastic switch w/connectors and dremeled a slot in one of the blank switches on the lower left dash.
So much easier than trying to reach under there or getting out of the car. It looks super clean as well..
fujiillin is offline   Reply With Quote
Old 02-12-2008, 09:21 AM   #13
mattminer
Member#: 90642
WKD Everything
pics?
-M@
Old 02-12-2008, 11:32 AM   #14
benw
Member#: 103320
1998 swapped
Forester L
I did the same thing that everyone here did. I just let mine sit on the steering column.
benw is offline   Reply With Quote
Old 02-12-2008, 11:41 AM   #15
qoncept
Member#: 44762
2013 BRZ
Just a heads up, the green test connectors house simple spade connectors. So wire your switch with those and you have an easy to install and easy to remove switch.
qoncept is offline   Reply With Quote
Old 02-12-2008, 02:38 PM   #16
vaccine
Member#: 94490
i did similar to as qoncept said.
a soldered a 9-pole switch thou with the jump-block all wired into it. as well as 2 wires that have plugs on the end for the green connectors. plug and play works a treat!
vaccine is offline   Reply With Quote
Old 02-12-2008, 03:07 PM   #17
mattminer
Member#: 90642
WKD Everything
where did you get this switch? I was thinking about simply using a DPST switch to do this.
-M@
Old 02-13-2008, 09:19 AM   #18
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
I've had a switch installed for a couple years now. I can't imagine not having a switch installed. I probably have 150 reflashes on my stock computer.
http://www.bescaredracing.com/sti/ec...h/DSC06399.JPG
t
WolfPlayer is offline   Reply With Quote
Old 02-13-2008, 06:53 PM   #19
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I made a switch with two crimp on connectors that slide into the greens. I just lay it across my lap and when I need to flash I can flip the switch. You can leave the flash block connector plugged in all the time.
Clark
AZScoobie is offline   Reply With Quote
Old 02-14-2008, 02:21 AM   #20
vaccine
Member#: 94490
-M@
didnt know we only had to switch the green connectors and not the block.
make it even easier then. i live in australia and got it from JayCar.
Old 02-14-2008, 11:19 AM   #21
batchman
Member#: 94656
02 WRX Quicksilver
hums Indiana Jones theme
+1 for micro DPST switch. 2$ from radio shack. they don't carry electronic parts like they used to but they do have these.
batchman is offline   Reply With Quote
04 fog switch for reflash, colors? diagram? juiced04 Electrical & Lighting 0 06-10-2009 01:17 AM
Link 44s switching to Reflash on 2002 WRX 2.5, fuel problem, help! fc3swrx Engine Management & Tuning 0 03-30-2009 08:18 PM
Reflash Bait and Switch - Buyer Beware ! Dyno Flash General Community 209 01-10-2007 11:25 PM
UTEC users switching to Reflash? Brad B. Engine Management & Tuning 83 01-15-2006 03:52 PM
Cobb reflash and dealer reflash question battosai Bay Area Impreza Club Forum -- BAIC 0 09-11-2003 11:23 PM
