Old 02-11-2008, 11:55 AM   #1
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
Default How to tell difference between 04/05 STI HID headlights from regular 04/05 headlight
Like the title said, I was just wondering if there's a way to tell the difference in the reflectors that the STI HID headlights have compared to the non HID ones.
Thanks in advance for your response!
*EDIT*
Just to clarify my question, I know how a regular halogen bulb looks like compared to an HID. I just want to know if there's anyway to distiguish between a regular 04/05 light assembly (mainly the low beam reflectors) compared to a STI reflector assembly
Cyclonus is online now   Reply With Quote
Old 02-11-2008, 12:28 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
i'd ask caesar @ lightwerkz.net
Old 02-11-2008, 06:29 PM   #3
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
It's bright! HOLY COW!
tux121 is offline   Reply With Quote
Old 02-11-2008, 06:40 PM   #4
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Open up the bulb cover and the HID version will have the igniter plug. If you have the headlight out then flip it around and you can see the HID ballast mounted underneath the headlight.
minifreak is offline   Reply With Quote
Old 02-11-2008, 06:54 PM   #5
kyosho
Member#: 53079
2005 RIP 2005 WRX
236/243 CA91 Tim Bailey
From what they showed me at EDO, there's also this thing that sits in front of the bulb in 04/05 that looks different. It's the thing that helps cut the light
kyosho is offline   Reply With Quote
Old 02-12-2008, 10:27 AM   #6
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
what if it's just the headlight assembly? no hid bulb, wiring and ballast
Old 02-12-2008, 10:34 AM   #7
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Then that's probably a WRX headlight
EdHilario is offline   Reply With Quote
Old 02-12-2008, 11:24 AM   #8
kyosho
Member#: 53079
2005 RIP 2005 WRX
I am assuming you bought a used headlight assembly? Does it have a hole in the back of the housing for the bulbs?
The other thing to check is.... there's a little piece that blocks the light in the middle of the housing. Basically what the guy told me at the shop was (i am going to try and draw this with text):
WRX:
< ---- bulb ... bulb emits light and scatters all over the place
STI:
____ ... there's a little flat thing that's part of and above the "<"
<----bulb ... bulb emits light but the top thing cuts the light off appropriately
There's basically this straight thing on the top in the STI housing. Again, this is what he showed me. I don't know if he was talking out of his butt or not.
Old 02-12-2008, 01:48 PM   #9
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
I'm actually planning to get USDM STI HID headlight assemblies as I have a CADM STI with HID's installed by the previous owner. I don't want a messed up beam pattern blinding othe drivers.
I'm asking about how to differentiate an STI HID reflector assembly from non HID reflector assembly as I don't want to get the wrong ones.
If someone can post pictures of an 04 STI USDM headlight assembly, I can try to compare it with my headlight assembly.
Old 04-03-2008, 12:09 PM   #10
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
Anybody else know?
Old 04-03-2008, 03:36 PM   #11
hypoxvi
Member#: 173002
don't the sti headlights not have the amber reflectors inside?
hypoxvi is offline   Reply With Quote
Old 04-03-2008, 06:37 PM   #12
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
I think all of them have the amber reflector, but what I'm talking about is the low beam reflectors
they're supposed to be more suited for the beam pattern of a HID bulb so that excess glare won't occure.
Old 04-03-2008, 10:07 PM   #13
hypoxvi
Member#: 173002
yes this is true, they have a projector for the low beam.
Old 04-04-2008, 04:38 AM   #14
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
I'm talking about the 04/05 sti, not 06/07
How to tell what year a usdm sti tmic is... atomic4877 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-27-2009 10:02 AM
How to tell difference between TD05 & TD06 SurfWagon General Community 1 04-15-2008 11:14 AM
I figured out how to bypass the immobilizer so 06 STI owners can user the 04 STI key Jag32 Car Audio, Video & Security 16 07-09-2006 10:05 AM
OT: How to tell if you have an STI ghostfoot7 Vancouver Impreza Club Forum -- VIC 7 10-12-2005 02:10 AM
How to tell if I have an STi short shifter d00f Transmission (AT/MT) & Driveline 5 01-01-2002 01:43 PM
