Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 02-07-2002, 01:31 AM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Default Attn:Legacy turbo kit drivers, didnt someone do the kit w/out changing the water pump
I am asking just that. I remember reading somewhere that someone had done the setup without swapping for the Legacy turbo waterpump. I ask this because this is the second time around for the install and I would like it if I could skip that step. It would be so much easier to use the same pump and not have to remove the timing belt etc. I think Someone stacked some gaskets in between the non-turbo side manifold to make it clear the stock pump. Anyone have any clue what I am talking about?
scootr
scootr is offline   Reply With Quote
Old 02-07-2002, 01:59 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Not really sure if this is what you are looking for but I used the stock EJ25 waterpump on my EJ22T. It works fine without having to use different gaskets or anything.
Eric
Eric SS is offline   Reply With Quote
Old 02-07-2002, 02:08 AM   #3
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Well,
the water pump from the legacy turbo goes at a different angle, and has to clear the different shaped manifold. I think someone made more space for (the stock RS pump) to fit by putting extra gaskets in. The stock RS pump goes down and the Legacy one goes to the side. I think it is different on yours.
Thanks,
scootr
Old 02-07-2002, 09:41 AM   #4
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
I don't know that anyone has done this with stock Legacy headers. It might work with the Cusco or other aftermarket header.
Putting multiple gaskets on one side only would be bad - you would be mounted crookedly. And you would have to add about an inch of clearance, because there is about a 1/2" collision with the thermostat housing, which is plastic, so it needs to more than just clear it. That also affects all of your other geometry - whether a spacer is needed to clear the head with the up-pipe, where the turbo lands...
It is quicker to change the pump than it is to figure out a way to avoid it.
blaster88 is offline   Reply With Quote
Old 01-02-2004, 09:38 PM   #5
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
bump i would like to know if there is a way to use the stock rs pump with this setup
thanks
Greg
GregBolby is offline   Reply With Quote
Old 01-03-2004, 03:56 PM   #6
aigburth
Member#: 8619
1996 RHD GC '96
http://spookyempire.com
I've done 3 gc8 turbo conversion's,if you turbo with factory part's you have to change the waterpump,sorry.
Alan
aigburth is offline   Reply With Quote
Can someone please post a pin out for the OEM 6 pin trailer wiring harness? silence2-38554 Electrical & Lighting 0 08-04-2009 02:21 AM
How do I know when to change the tranny and rear diff fluids? Malasubidude Newbies & FAQs 7 08-20-2008 05:34 PM
synthetic oil and changing the filter with out draining the oil warpspeedwrx Service & Maintenance 16 07-21-2003 11:16 AM
How do you clean puke out of the seat? EddieC168 Newbies & FAQs 10 03-26-2002 12:18 PM
