Old 02-12-2008, 01:31 AM   #1
Dobbs
Member#: 28291
2015 WRX
Default Weird negative timing on deceleration / engine braking
Sup guys...
A few basics about the car -- 2002 wrx, full stage II junk (full TBE), drop in filter, stock IC, stock turbo, stock tranny. 91 octane.
This comes from a custom stage II tune with very conservative timing (basically the same as stock, just smoother). The load sites in question with the negative timing correspond to ~26 degrees of timing on the map. Should I worry about this? There is virtually no load being placed on the engine, and I would guess that it is either the hyper sensitive knock sensor, or drivetrain noise, etc...
Anyone else seen something like this?
Code:
Time	Load	RPM	Timing	KC	PSI	TPS
298068	0.22	1053	12	0	-6.67	0
298299	0.22	1041	13	0	-6.67	0
298579	0.22	1035	13.5	0	-6.67	0
298679	0.22	1031	13.5	0	-6.67	0
298890	0.22	1040	13	0	-6.67	0
299030	0.22	1038	12	0	-6.67	0
299220	0.2	1018	15	0	-6.82	0
299390	0.18	992	16.5	0	-7.11	0
299591	0.18	962	18	0	-7.11	0
299781	0.22	950	17.5	0	-7.11	0
300031	0.26	1011	10	0	-6.53	5.49
300282	0.26	1199	-6	0	-6.38	16.86
300432	0.77	1414	26.5	0	-0.44	11.76
300582	0.4	1548	30.5	0	-2.47	20
300782	0.69	1839	33	-0.5	-0.73	20
300932	0.67	1945	34	-0.5	-0.73	20
301153	0.68	1975	34.5	-0.5	-0.58	20
301383	0.69	1946	34	0	-0.44	20
301623	0.72	1891	32	0	-0.15	20
301794	0.73	1896	31	0	0.15	20.39
301984	0.72	2150	35.5	0	0.29	20.39
302164	0.72	2318	36	0	0.15	20.39
302354	0.72	2434	35.5	0	0.15	20.39
302555	0.75	2588	34	0	0.15	20.39
302755	0.75	2756	32.5	0	0.15	20
302945	0.76	2932	32.5	0	0.15	20
303116	0.75	3100	33	0	0.15	19.61
303296	0.76	3307	34	0	0.29	19.22
303506	0.74	3482	35	0	0.15	18.43
303726	0.73	3616	38	0	0	13.33
303947	0.54	3689	42.5	0	-1.6	1.96
304127	0.26	3666	34.5	0	-5.22	0
304287	0.14	3532	22.5	0	-7.69	0
304488	0.12	3291	15	0	-7.84	0
304658	0.1	2978	18.5	0	-8.13	7.06
Code:
98882	0.16	1442	11.5	0	-7.55	0
99053	0.16	1419	11.5	0	-7.55	0
99263	0.16	1407	11.5	0	-7.55	0
99433	0.16	1402	11.5	0	-7.55	0
99644	0.16	1388	11.5	0	-7.55	0
99834	0.17	1366	11.5	0	-7.4	0
100054	0.17	1364	11.5	0	-7.4	0
100204	0.17	1348	17	0	-7.4	0
100395	0.17	1325	17.5	0	-7.4	0
100605	0.17	1321	16.5	0	-7.4	0
100785	0.17	1305	-7	0	-7.4	0
100975	0.18	1290	-1	0	-7.4	0
101186	0.18	1276	5	0	-7.4	0
101376	0.18	1256	11.5	0	-7.4	0
101626	0.18	1259	16	0	-7.55	0
101807	0.18	1255	15	0	-7.55	0
101987	0.2	1244	15	0	-7.4	2.35
102187	0.3	1218	4.5	0	-6.96	4.31
102428	0.36	1242	7	0	-5.8	4.31
102588	0.39	1219	14	0	-4.93	4.71
102778	0.48	1244	26	0	-3.92	9.02
102988	0.7	1244	23.5	0	-2.18	12.55
103209	0.67	1253	23.5	0	-1.31	15.69
103359	0.7	1294	24.5	0	-0.44	20
103629	0.71	1319	25	0	-0.15	24.31
103820	0.71	1344	25	0	0.15	25.88
104020	0.72	1377	25	0	0.29	26.67
104180	0.72	1410	25	0	0.44	27.06
104370	0.75	1424	25	0	0.44	28.24
Dobbs is offline   Reply With Quote
Weird scratching sound when decelerating in gear. samwY General Community 28 09-20-2012 11:29 AM
positive, neutral, negative. I have way too much time on my hands. deathinacan Off-Topic 75 03-09-2010 01:57 AM
(HELP) Check engine light on deceleration scoobyru00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-25-2005 06:59 PM
Weird chirp / squeak noise from exhaust on deceleration? Rexxxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-25-2004 04:47 AM
