Old 02-12-2008, 03:45 PM   #1
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Default 2.5 sti motor, 2.5 wrx motor
what is the difference in the two motors? are they the same? or different, i know this is probably a noob question, but could somebody please explain the differences in the two motors
olsen726 is offline   Reply With Quote
Old 02-12-2008, 03:46 PM   #2
ultimate_wrx
Member#: 145598
2006 Cobb stage2 WRX
the 06/07 wrx engine has more potential if compairing stock internals.
but i think the 08 sti has them beat.
ultimate_wrx is offline   Reply With Quote
Old 02-12-2008, 03:49 PM   #3
banjabi
Member#: 119385
GDA
you got to be kidding me? you sound like you were born yesterday.
the sti has stronger stock internals than the wrx. if you're going to mod heavy with balls out performance, sti is most ideal. in the OPs case, if you're going for a swap, go with an sti swap - go big or go home.
banjabi is offline   Reply With Quote
Old 02-12-2008, 03:51 PM   #4
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Wrong Scooby Specialist.
mapleleaf is offline   Reply With Quote
Old 02-12-2008, 03:53 PM   #5
dees421
Member#: 156291
2008 Impreza 2.5i
I think I read somewhere on here where the blocks are different. The STi has closed deck block and the WRX has a open deck block.
dees421 is offline   Reply With Quote
Old 02-12-2008, 04:01 PM   #6
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Same motors.
Different dish size on the piston.
STI 8.2 vs. WRX 8.4 CR
Some say the heads are minutely different.
It's been debated to death.
Old 02-12-2008, 04:11 PM   #7
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
^^ I was under the impression the heads were different, because they have the same part # for the shortblocks.
Then again, they change little details every year....
aboothman is offline   Reply With Quote
Old 02-12-2008, 04:13 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
from what i've read:
same block
same internals
different heads which make for the 0.2 difference in CR
Old 02-12-2008, 04:19 PM   #9
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
The heads are a highly debated topic, I've never found any conclusive evidence myself, but I'm sure there is something out there.
From what I understand, the dish of the piston is sized slightly different which is what changes the CR.
I am by no means an expert.
If Nasioc's piece of **** search engine worked somewhat well, I might be able to find the threads debating this.
Anyone else want to try?
Old 02-12-2008, 04:21 PM   #10
ultimate_wrx
Member#: 145598
yeah nasiocs search feature does need an overhaul.
Old 02-12-2008, 04:38 PM   #11
bindriftin
Member#: 106411
2001 GM6
Silverthorn
^^^Not if you are patient...
bindriftin is offline   Reply With Quote
Old 02-12-2008, 04:45 PM   #12
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
the block is the same, same part number etc. i want to call SOA and ask them because i have been wondering this myself
bhhamblin is offline   Reply With Quote
Old 02-12-2008, 05:18 PM   #13
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
yeah there are no closed deck usdm wrx's or stis
Le Saboteur is offline   Reply With Quote
Old 02-12-2008, 05:20 PM   #14
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
They are the same for anything most people want to do.
Both are semi-closed deck.
DiscoGsus is offline   Reply With Quote
Old 02-12-2008, 06:07 PM   #15
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
I miss the old fully closed 2.2 cast iron block with oil squirters. That's a great motor.
Old 02-12-2008, 07:17 PM   #16
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the short blocks are NOT the same part # and here is why
using an 07 wrx and 07 STi
WRX
Bore Stroke
mm (in)
99.5 79.0 (3.92 3.11)
Piston displacement
cm3 (cu in)
2,457 (149.94)
Compression ratio
8.4
WRX STi
Bore Stroke
mm (in)
99.5 79.0 (3.917 3.110)
Piston displacement
cm3 (cu in)
2,457 (150)
Compression ratio
8.2
Old 02-12-2008, 07:22 PM   #17
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
heads are also different
Old 02-12-2008, 08:02 PM   #18
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
It gets hard to keep up with Subaru part #'s.
They change constantly. I've seen many Subaru parts that are indeed the identical part to one another, yet have different numbers. This can vary a great deal year to year. It's very difficult to get a conclusive answer.
I've seen EJ255 and EJ257 shortblocks from 2 different model years with the same part #.
Subaru is known to mix and match parts at times if one specific part is not avail. at the plant that day.
Volvo used to do that a lot at the plant in Halifax back in the day.
Old 09-24-2008, 02:05 PM   #19
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Take a look at:
http://forums.nasioc.com/forums/show...1594587&page=2
Jeff
sponaugle is offline   Reply With Quote
Old 09-24-2008, 02:31 PM   #20
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
it wasn't cast iron...
MannyMohawk#5 is online now   Reply With Quote
2.5 STI vs. 2.5 Na block masterpickle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 01-19-2008 02:21 AM
WTB: 2.5 STi or 2.2 Turbo Short Block outback2.5HO NWIC Private Classifieds 18 03-15-2006 09:44 PM
97 2.2 to 2.5 sti.... or 2.0... shiftykapone Subaru Conversions 0 02-12-2006 02:57 AM
2.5 STi block:compatible w/ USDM WRX heads? mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-03-2004 09:17 PM
2.0 STi vs. 2.5 STi motor ShzSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 05-12-2003 02:05 PM
