Old 02-12-2008, 10:15 PM   #1
JLW2007RS
Member#: 162089
2008 G37S IPL
Default o2 sensor wiring question
Can splice two o2 sensor wires into one o2 sensor. so basically can i eliminate one o2 sensor and wire both to the other?
JLW2007RS is offline   Reply With Quote
Old 02-12-2008, 11:06 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
No. thats the simple, concise answer. If you want an explanation, do some research on what O2 sensors are used for in the first place (and what cat's are for) and i think you might answer your own question and actually learn something in the process. a search here will probably give you tons of info and a wiki search will also give you a bunch of info. google search would work, too, im sure. good luck.
Old 02-13-2008, 02:56 PM   #3
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
Do some homework first: http://en.wikipedia.org/wiki/Oxygen_sensor
"They determine if the air fuel ratio exiting a gas-combustion engine is rich (with unburnt fuel vapor) or lean (with excess oxygen). Closed-loop feedback-controlled fuel injection varies the fuel injector output according to real-time sensor data rather than operating with a predetermined (open-loop) fuel map."
Not a good idea. Upstream O2 monitors exhaust gases and adjusts fuel trims, it also serves as a benchmark for the downstream O2 which monitors for emissions and also makes minor modifications to the fuel trims. If you combine the two you elminate that benchmark and will throw a CEL. More importantly both O2 sensors exist to check on each other, if the upstream sensor fails the downstream takes over as the primary monitor of exhaust gases. Bottom line: don't do it.
Question, why would you?
LTracer is offline   Reply With Quote
Old 02-13-2008, 04:04 PM   #4
JLW2007RS
Member#: 162089
2008 G37S IPL
to get around driling another o2 sensor bung somewhere after my second cat if i put headers in
Old 02-13-2008, 05:12 PM   #5
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
I just had a O2 sensor bung rewelded on my stainless Stromung track pipe (came with a manufactured extender that needed to be removed) by a local machine shop. Cost $40 and was well worth the headache of trying to deal with the P2096 CEL. I'd advise against trying to have it done at a chain exhaust shop, I got the "you know this is $10,000 fine blah blah blah" and proceded to walk out with track pipe in hand. Find a good machine/fabrication shop and take the individual piece to them.
Old 06-27-2008, 10:00 PM   #6
MSo
Member#: 5008
2002 /06 STi GGA
SRP
What happen since then? Still have a P2096 code?
Tell me more about reWelding.
I have same code with Perrin catless DP
Thanks.
MSo is offline   Reply With Quote
Old 06-27-2008, 11:18 PM   #7
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
No more P2096, just the P0420 (cat ineffiency). I settled with this and disabled via romraider.
o2 sensor wiring question JLW2007RS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 02-12-2008 10:16 PM
Front O2 sensor wiring question Patrick Olsen Normally Aspirated Powertrain 0 06-02-2006 06:59 PM
Rear O2 sensor wiring question powbmps Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-17-2005 09:51 PM
O2 sensor wire? Brian Mayfield Normally Aspirated Powertrain 7 06-14-2001 03:14 PM
