Old 02-13-2008, 05:23 AM   #1
Foxhound
Member#: 170336
06 Impreza 2.5i
CGM
Default Why is this happening?
Hello all, im kinda new around here. Ive recently bought a 2006 Impreza 2.5i with 10k miles on it. Right now im ~13k and for a while now, whenever I brake at certain speeds (usually around 50), I can feel the car vibrate/shake very mildly.
Normally, If the steering wheel shook as well, I would think I needed rotors/pads, but the steering wheel doesnt shake ONE bit. I only feel the shaking from my foot/leg.
Im pretty sure its just the early stages of warped rotors or wearing pads. Please point me in the right direction!
Foxhound is offline   Reply With Quote
Old 02-13-2008, 08:03 AM   #2
mopartodd
Member#: 164929
2014 Impreza Premium
Jasmine Green Metalic
Sounds like you're on the right track. Brakes would be the first thing I'd look at.
mopartodd is offline   Reply With Quote
Old 02-14-2008, 01:28 AM   #3
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
check your break pads, rotors and even check the pressure in your tires. Not sure why the steering wheel would shake but I'm pretty sure it's all connected together.
ejicon is offline   Reply With Quote
Old 02-14-2008, 02:05 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Rotors are probably warped.
Old 02-14-2008, 03:42 AM   #5
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Rear rotors are either warped or something is wrong with the rear part in general. Most likely it will be the rotors. It's strange though, why would it start warping so early on in its life? I guess it's not unusual to get an unlucky case every once in a while.
It is rear because you feel it in the pedal and your seat, but not in the steering wheel. Front warped rotors would transmit vibrations through the steering column as well.
But it wouldn't hurt checking the front rotors or replacing them.
I doubt it is worn pads because then you'd get squeaking sounds or something like that.
I could be improper wheel balancing or alignment... but I doubt it.
formula91 is offline   Reply With Quote
Old 02-14-2008, 03:43 AM   #6
PA-Outback2000
Member#: 161832
2000 Outback Limited
warped rotors absolutely! check out to be sure though.
PA-Outback2000 is offline   Reply With Quote
Old 02-14-2008, 04:27 AM   #7
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Stop ridding your brakes.
10k warped rotors....pretty bad dude.
Wrx_Fan_0717 is offline   Reply With Quote
Old 02-14-2008, 08:23 AM   #8
Sylon
Member#: 109000
2006 Impreza 2.5i
Obsidian Black Pearl
Its warped rotors, I had the exact same problem, except mine were all 4 rotors. And good luck getting SOA to replace them. They don't beleive that there is a common problem with the 06's 2.5i rotors, and that they will warp really soon. Mine did it for a long time, but right around the same mileage as you.
I had to talk them into it, and when all else failed, I had to pull the military card. I couldn't afford the $900 it would take to replace the damn things. They told me it was from "excessive and abusive driving", which I took offense to, because I treat my car like I would my own child, I baby this thing. Its never seen a race track, never driven hard. So, it was complete BS what they were saying and that they wern't going to replace it under warranty.
Finally, I pulled the military card and they told me "they would replace them under warranty as a one-time good gesture".
There is a problem with some of the 2.5i rotors, because I'm not the first to have this issue.
Sylon is offline   Reply With Quote
Old 02-14-2008, 12:27 PM   #9
RS Guy1513
Member#: 102812
05 CGM 2.5 RS
07 Triumph Tiger 1050
it's probably material deposits from the brake pads on the rotor..really doubt you warped the rotors unless you are tracking the car like crazy...lots of people will tell you "you wapred rotors". just either try a rebedding procedure, get them cut, or replace them
RS Guy1513 is offline   Reply With Quote
Old 02-15-2008, 12:23 PM   #10
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
^^ This is the only person to actually point you in the right direction. The stock pads tend to cause uneven pad deposits on the rotors. Re-bedding the pads may/will help (it worked for me on my Legacy), but you may want to consider installing different pads (like Hawk HPS) and then re-bedding. This should solve your problem.
jac04 is offline   Reply With Quote
Old 02-15-2008, 02:41 PM   #11
RS Guy1513
Member#: 102812
05 CGM 2.5 RS
and when you stop the car hard and they are hot, provided its five speed, if you can avoid holding your foot on the brakes while stationary, that will help a lil with reducing pad deposits as well
Old 02-15-2008, 03:47 PM   #12
Naito
Member#: 114263
2014 Forester XT
I can't believe you could warp your rotors in just 10K, no matter how abusive. I have the same car and I've taken it to the track twice on the stock brakes, stock pads, and I dont' have vibration on my brakes. Either you're riding the brakes, braking hard and holding the brakes down while stopped at lights, or something. My brakes were smoking after my first track day and I never got such shaking or vibrating, they just stopped braking very effectively until I bled the brakes the next day from overheating.
My car has 46000km on it now, which is about 30k miles.
Naito is offline   Reply With Quote
Old 02-15-2008, 04:14 PM   #13
sadsack
Member#: 102327
2003 Legacy - RIP
+2 for pad deposits
Most likely, the first owner did a lousy job bedding the pads, and never did anything more than mild braking. This would cause greater accumulated deposits since they were never "burned off" periodically.
sadsack is offline   Reply With Quote
Old 02-15-2008, 04:55 PM   #14
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
+3 on pad deposits, I imagine with uneven braking (riding the brake, pumping it, or holding it at the lights after you've really heated them up) you hotspot the rotors and deposit more material than you would on cold spots... I've driven the piss out of my rotors on my 07 and I've had no issues whatsoever.
You would have to seriously heat up the rear rotors to the point of warping them and I highly doubt your rear brakes can generate that kind of heat.
Stoptech has a great article on the myths of warped rotors, I'm lazy though and don't want to go searching for the link, but I'm sure you can easily find it on their site.
One thing that car probably is overdue for is a proper brake servicing, clean and regrease the slider pins and backs of the pads (copper antiseize to quiet them) , check the wear on the pads (subaru pads last forever apparently)
Sir-Knight is offline   Reply With Quote
Old 02-15-2008, 07:13 PM   #15
RS Guy1513
Member#: 102812
05 CGM 2.5 RS
Old 02-15-2008, 09:11 PM   #16
cmiovino
Member#: 134005
2004 WRX Premium
bingo.
time for an upgrade!
Oh man, why is this happening again Hyper Service & Maintenance 13 02-05-2010 09:13 AM
Why is this happening to my battery terminals and hold-down? BeBop86 Electrical & Lighting 12 11-21-2008 08:56 PM
Why didn't this happen to me Rodan Off-Topic 15 02-09-2005 05:10 PM
Why is this happening? WRXVII Brakes, Steering & Suspension 1 07-24-2004 10:01 PM
('93-'01) Why Is This Happening dvs81n Impreza Forum 4 06-13-2001 10:49 PM
