Old 02-13-2008, 09:14 AM   #1
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
Default FPGreen 7cm Airflow
Hey everyone - I'm in the process of tuning a 2.5 litter with an FPGreen w/ supporting mods and a BigMAF(70mm). Car runs great, but I still think its lacking a good amount of airflow. Anyone a 20g+ on a 2.5l w/ a 7cm housing and a BigMAF that I can compare it to. Right now pretty close to redline it is pushing right at or under 300 g/s ~22psi.
Thanks..
TheShad0w is offline   Reply With Quote
Old 02-13-2008, 11:12 AM   #2
testes1010
Member#: 47145
2012 Gas Saver
Once you went with the BigMAF you can pretty much quit comparing g/sec to anyone else, because everyone tunes there BigMAFs different.
testes1010 is offline   Reply With Quote
Old 02-13-2008, 11:32 AM   #3
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
I agree with you there, but even prior to going to the BigMAF, it wast exactly moving allot of air IMO.
Old 02-13-2008, 05:13 PM   #4
testes1010
Member#: 47145
2012 Gas Saver
What MAFv or g/sec were you seeing before the BigMAF?
If it wasn't maxing out the MAFv(5.0v @ ~352g/sec) on the original intake something isn't right OR the original intake wasn't 'stock' reading.
Old 02-14-2008, 12:12 AM   #5
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
This stock ECU maxes its MAF at 296/4.69v - which is pretty much on the spot to where it is consistently now. Obviously using a dif voltage since the larger housing, but ~300 g/s.
I found the flow low for its rating - but for the most part every 2.5l I've tuned with aftermarket turbos have had 8cm housings.
Old 02-14-2008, 09:59 AM   #6
testes1010
Member#: 47145
2012 Gas Saver
You can rescale the MAF to run upto 5.0v-352g/sec w/o needing to go BigMAF.
Code:
MAF values for stock WRX MAF housing
0.94	0.98	1.02	1.06	1.11	1.15	1.19	1.23	1.27	1.31	1.36	1.4	1.48	1.57	1.65	1.73	1.82	1.9	1.99	2.07	2.15	2.24	2.32	2.4	2.49	2.61	2.74	2.87	2.99	3.12	3.24	3.37	3.49	3.62	3.75	3.87	4	4.12	4.25	4.37	4.5	4.63	4.71	4.79	4.84	4.88	4.92	4.96
1.22	1.4	1.62	1.84	2.14	2.46	2.82	3.2	3.62	4.06	4.54	5.1	5.76	6.98	8.34	9.86	11.54	13.42	15.52	17.92	20.64	24.46	27.94	31.68	35.78	42.56	50.1	58.4	67.38	77.06	87.6	99.2	111.84	125.52	140.2	156.04	173.08	191.42	211.12	232.3	254.98	278.52	295.64	313.26	322.44	331.82	342.66	352.02
Readup, I've done this on many cars & its works flawlessly:
http://forums.nasioc.com/forums/show...light=300g%2Fs
Old 02-14-2008, 10:49 AM   #7
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
Yeah I have done this too - but the client wanted room to grow..
Old 02-14-2008, 03:33 PM   #8
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
If he wanted room to grow shoulda gone with a 8cm lol
Every MAF sensor reads differently, so its really not something you can accurately compare to, even between people who also have a big MAF. If your air fuel targets are on, timing is good, airflow reading isnt erratic, and its making power, thats what counts.....
Turbo_Mike is offline   Reply With Quote
FS- FPGREEN 7cm less than 2k miles josh04 RMIC Private Classifieds 10 01-17-2008 03:45 AM
FPGReen 7CM IWG 2.4 Inlet, Perrin Inlet Blue TopEndPull TXIC Private Classifieds 8 12-12-2007 11:41 PM
Blown V43 Swap to FPGreen 7cm 4ST-AIR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 10-27-2007 09:22 PM
Whats the fastest STi ever ran with FPgreen 7cm or 8cm green downsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-01-2007 03:57 PM
20G 8CM or Keep my FPgreen 7CM? TopEndPull Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 02-12-2007 11:18 AM
