Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-13-2008, 12:08 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element Hydra Nemesis 2.6 Sneak Preview
Here is the latest Nemesis 2.6 Hydra in all it’s glory. We listened to you (well most of you ) and here it is. You are seeing it here first.
The main window is now more “Windows” like in that you can move around each tuning window. You can also define the layout to your preference.
As you can now see you can data log while viewing the main tuning screen. Logging parameters are user definable now.
When in using “Autotune” now the software will place the exact percentage your fuel map is off in any given fuel cell. You can then use the multiply/divide feature to correct that cell manually and precisely now. Volumetric Efficiency fuel tuning is also now an option.
The boost control system is more advanced than ever with boost target, coolant temp boost trim, air temp boost trim, tps boost trim, boost upper limit, maximum boost (boost cut), and gear based boost trim. All this lets you define how you prefer boost response based on TPS and allows you to limit boost when coolant temps are too low or too hot and most importantly lets you compensate for large weather changes that can often add 2-3 psi of boost change.
More programmable user definitions have been added.
A number of features have been added to the closed loop fuel control but the most important has been the addition of the “Wide Closed Loop TPS” which allow you to define the closed loop limit based on TPS now.
The tuning categories are broken down into more logical sections such as “2D Staring” etc. All 3D Maps are now fuel resolution with 1024 load cells.
There is so much more and it’s awesome!
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 02-13-2008, 12:12 PM   #2
Shabib67
Member#: 61749
so when is this coming out and can you tell us the price of it by itself and with the wideband? Also with the new advancements in boost control would their be any point of using a electronic/manual boost controller?
Shabib67 is offline   Reply With Quote
Old 02-13-2008, 02:19 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Isn't that supposed to say "Element Tuning EMS"
Come on, dude, you're the marketing staff for crying out loud!
jblaine is offline   Reply With Quote
Old 02-13-2008, 02:24 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
We like to keep it short and sweet
The final price has yet to be determined but it will likely be about +$200 more than the Nemesis 2.5 but we may not increase the price initially. We have talked about a special release price.
Old 02-13-2008, 02:31 PM   #5
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Will the WRX units be upgraded as well? (Units for WRX with STi longblock swaps )
CoolRex is offline   Reply With Quote
Old 02-13-2008, 02:35 PM   #6
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
What about mouse input?
Cut/Paste?
Those are glaring weaknesses.
Nixlimited is offline   Reply With Quote
Old 02-13-2008, 02:35 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Yes of course the Nemesis 2.6 EMS will be available for the WRX, STI, and RS for all model years.
Thanks,
Phil
Old 02-13-2008, 03:23 PM   #8
Element Tuning
Member#: 54918
673 WHP Element
Cut/Paste?
Mouse point and click of the 32x32 was vetoed by me and others due to laptop usage issues while tuning inside of a car. It's not going to happen in this version but may in future versions. Navigation of the 32x32 maps is still via arrow keys.
Cut and paste, multiply and divide, and more have been added.
Thanks,
Phil
http://www.elementtuning.com
Old 02-13-2008, 03:54 PM   #9
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Thanks,
Phil
Yes, the point is that we can use excel outside of the tuning software to do very quick data manipulation. That's much easier with mouse input, but I will take cut/paste as a start.
Old 02-13-2008, 05:20 PM   #10
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
I should point out, with mouse input, I could actually make effective use of the graphs. When you can't grab and rotate them, they are significantly less useful. However, if I can cut-paste into and out of excel, that's less of an issue.
Old 02-14-2008, 09:47 AM   #11
WickedRydaX
Member#: 31900
Is there a release date yet? More importantly to me what is the date and cost I can send my boxes in to get updated? Looks nice, I can't wait to try it out in person.
ThankS
MCL
WickedRydaX is online now   Reply With Quote
Old 02-14-2008, 10:33 AM   #12
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Will this release be buggy like the last one? I recall some serious issues with the last one on the STi's.
Old 02-14-2008, 11:37 AM   #13
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Man thats nice Phil I want to upgrade all ready
Poweredbysnail is offline   Reply With Quote
Old 02-15-2008, 02:59 PM   #14
andythierry
Member#: 65629
It is available immediately?
andythierry is offline   Reply With Quote
Old 02-15-2008, 06:32 PM   #15
Element Tuning
Member#: 54918
673 WHP Element
This will not be released until it's perfect and that's why we really aren't giving a release date yet but we are optimistic for April. I've had a version of Nemesis 2.6 since November so it's definitely been in beta for quite some time now.
Thanks,
Phil
Old 02-16-2008, 09:54 AM   #16
MartinSTi05
Member#: 145145
2006 wrx STi
You mean Nov 2008?
MartinSTi05 is offline   Reply With Quote
Old 02-16-2008, 11:35 AM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Originally Posted by MartinSTi05 View Post
You mean Nov 2008?
It's only 9 months away... It will be here before you know it
At least until then there is the 2.5 version which is still perfectly good for most intents and purposes
jigga is offline   Reply With Quote
Old 02-16-2008, 01:36 PM   #18
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Phil - is my 2.5 box upgradeable to the 2.6?
SloRice is offline   Reply With Quote
Old 02-16-2008, 01:48 PM   #19
SPIN2GST
Member#: 106665
05 Buschur Powered
Evo w/corn in da poop
Originally Posted by SPIN2GST View Post
Heres a great idea...how about an undo button.
What? You mean you make mistakes?
Where are my screen shots?!!??!
SPIN2GST is offline   Reply With Quote
Old 02-18-2008, 09:05 AM   #20
Element Tuning
Member#: 54918
673 WHP Element
You mean Nov 2008?
LOL! I meant to type in April instead of November.
Old 02-18-2008, 11:31 AM   #21
harrybauls
Member#: 134433
Quick question... will our existing maps import to V2.6 without tweaking?
harrybauls is offline   Reply With Quote
Old 02-18-2008, 11:54 AM   #22
Element Tuning
Member#: 54918
673 WHP Element
At this point everything imports but the 3D PWM maps since the resolution has been increased to a full 32x32. When it's released I will have imported these maps manually but currently we only use these for the closed loop AVCS, Open loop AVCS, and Hydramist 3D Water Injection mapping.
With that said there are new maps that to be taken advantage of will have to have new maps made for such as boost pressure compensation for air temp, coolant temp, and tps.
Thanks,
Phil
Old 02-18-2008, 11:56 AM   #23
Element Tuning
Member#: 54918
673 WHP Element
Yes all Nemesis 2.5 boxes can have the circuits and flashes upgraded but the price is TBD.
Sorry but Nemesis 2.0 boxes cannot be upgraded due to hardware limitations. There is talk about an trade-in program however but no pricing info on that just yet.
Thanks,
Phil
Old 02-19-2008, 11:02 PM   #24
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
You should shoot for a release date thats pre-race season. lol
project_skyline is offline   Reply With Quote
Old 02-19-2008, 11:20 PM   #25
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
the new version looks awesome, can't wait to get a chance to use it
Benchmark Tuning is offline   Reply With Quote
Element Tuning's Hydra Nemesis 2.6 Tuning Tips Element Tuning Other Engine Management 11 06-04-2011 11:42 PM
Hydra Nemesis 2.6 and DashDaq anubis328 Other Engine Management 0 10-01-2008 12:45 PM
New Element Tuning Hydra Nemesis 2.6 Release Details Element Tuning Other Engine Management 26 06-11-2008 05:19 PM
New Hydra Nemesis 2.6 Awesome New Features Element Tuning Other Engine Management 113 04-18-2008 12:06 AM
04 STi Element Tuning Hydra Nemesis 2.5 berserksti Engine/Power/Exhaust 11 10-10-2007 10:54 PM
