Welcome to the North American Subaru Impreza Owners Club Friday August 22, 2014
Old 02-07-2002, 01:45 PM   #1
Erik Dahlen
Member#: 15053
2002 Impreza WRX
Beautiful Blue
Default Questions about my ECM on Warrenty?
I just took my MY02 WRX in on warrenty now here is the problem. The dealer told me that the #3 cylinder was misfiring because there was not enough fuel burning off due to poor oxygen consumption. The dealer sent in the ECM to get it remaped so there would be a widerwindow for the spark plugs to fire. He said the problem was due to the fuel I was using. I live at high altitude in Denver CO and he said that Federal Law requires the fuel have a higher alcohole content for enviromental purposes than in Japan and OZ.
Have you heard anything about this Federal law?
I was using Premium UnL should I continue to use Premium or go to a lower grade? (I think I should the higher grade for the Turbo)
I was also wondering if I should use Synthetic oil or continue to use the 5-w30 SEA?
Is there any brands of gas sold like Conoco that I should avoid besides generic?
Confused and need some answers!!!
Thankx
Erik
Erik Dahlen is offline   Reply With Quote
Old 02-07-2002, 02:09 PM   #2
WRXSTi69
Member#: 12012
Default Re: Questions about my ECM on Warrenty?
Thankx
Erik
Erik, despite my reputation here (ahem) I think I can give you some help.
The remapping of the ECU is done to correct a fuel delivery problem that may develop due to heat from the turbo after a hot soak situation. I know of no Fed law requiring higher alcohol content in fuel in your area, but some fuels do use higher blends of alcohol, especially in the premium octane blends. Your dealer should be able to perform a quick check on a sample of your fuel to determine approximate alcohol content. Anything greater than 10 percent is not recommended by Subaru, and may cause driveability problems. More important than alcohol content is the RVP (Reid Vapor Pressure) of the fuel. If you are using a fuel with a very high RVP, it will tend to vaporize in the fuel line and injector (especially #3 injector, closest to the turbo) when the car is shut off hot. This means #3 cylinder runs lean on hot restart, setting the misfire code. If your fuel is okay, the remapping should take care of your problem.
Hope this helps.
WRXSTi69 is offline   Reply With Quote
Old 02-11-2002, 05:53 PM   #3
Erik Dahlen
Member#: 15053
2002 Impreza WRX
Beautiful Blue
Thanks, I got my WRX back Thursday but haven't driven it all weekend hopefully nothing else will go wrong.
I was also wondering what type of oil I should use synthedic or stick with the 15W-30 SEA?
questions about my header install on my 2.5i 2.5EYE Normally Aspirated Powertrain 4 08-11-2009 08:34 AM
question about my new mods on my car junkboxer Factory 2.5L Turbo Powertrain 3 01-04-2008 10:50 AM
Questions about my break in on my STI Vampyr Newbies & FAQs 9 08-29-2005 05:28 PM
I Have A Good Question About The Antenna On My WRX? tricked-out Car Audio, Video & Security 2 04-07-2002 08:19 PM
Question about an ECM problem? Erik Dahlen Newbies & FAQs 2 02-11-2002 05:47 PM
