Old 02-13-2008, 08:44 PM   #1
buskibum
Member#: 50467
2001 GC8 Coupe
Ridge Pearl Blue
Default Fuel and Engine Temp Lights Out
I have a 2001 Impreza RS and turned it on this morning and my fuel gauge and engine temp illumination were out (not lighting up, gauges seem to work). Doesn't look like they're on their own fuse in the manual, anyone know what would cause that and where the light to replace is?
buskibum is offline   Reply With Quote
Old 02-13-2008, 08:51 PM   #2
dan13
Member#: 157726
hunk of metal
Check your ground wires.
dan13 is offline   Reply With Quote
Old 02-13-2008, 09:47 PM   #3
GrundleJuice
Member#: 165749
are those two gauges right next to each other? maybe they share the same light source? could that be out? is it a bulb? EL panel? LED? Im not familiar with the lighting in the gauge cluster.
Old 02-13-2008, 09:56 PM   #4
buskibum
Member#: 50467
2001 GC8 Coupe
Ridge Pearl Blue
yep, both are next to each other, but it's weird because the illumination behind me speed and tach are fine... ground wires prob aren't a bad idea to take a look at.
Old 02-13-2008, 11:13 PM   #5
GrundleJuice
Member#: 165749
well your speedo and tach probably have their own light source. id guess there is a bulb or EL panel behind each gauge (counting the gas/temp and one gauge) so if one fails, the other two will still work. not xmas tree lights in there. I would be that the entire gauge cluster shares a common ground and all the gauges would be out if a ground were the problem. Its not a fuse, that is for sure. you should post this question in the lighting and interior forums.. probably get a correct answer real quick. if you find out, id be curious to know what it was. good luck.
AT Oil Temp light and dead engine after install? clarrkkent Car Audio, Video & Security 6 09-19-2009 01:16 AM
Interior and engine bay lighting how to's for strobers.. PickNarker Member's Car Gallery 10 07-10-2009 05:58 PM
Fuel and Engine Temp Illumination Out buskibum Electrical & Lighting 3 02-14-2008 12:09 PM
Stalling out at stop lights and engine is super lean! compfool Service & Maintenance 7 04-08-2006 12:04 PM
Timing and Engine temp Scooby South Engine Management & Tuning 3 07-23-2004 03:12 PM
