Old 02-14-2008, 07:27 PM   #1
Phx Cobra
Member#: 161157
04 STI
Default Some residual goo after debadging
I debadged the rear of my car this past weekend. It looks AWESOME. However if I look at it in direct light up close I can still faintly see the outlines of where the letters were. I know it is probably just me being picky but would like it to be smooth at any angle.
Would a claybar be able to clean it off? I washed, and rewaxed it all but still shows up, especially when it gets a lot of dirt/dust on it(gone down a dirt road 2x already)
Phx Cobra is offline   Reply With Quote
Old 02-14-2008, 07:30 PM   #2
Phatzilla18
Member#: 86475
Chapter/Region: HIIC
2001 Impreza 2.5RS
STM
try claybar and maybe some goo-gone
Phatzilla18 is offline   Reply With Quote
Old 02-14-2008, 07:37 PM   #3
Phx Cobra
Member#: 161157
04 STI
Yea used some googone and adhesive remover already, claybar should do it I hope.
Old 02-14-2008, 07:44 PM   #4
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
clay bar will definitely do it. just take your time!
Le Saboteur is offline   Reply With Quote
Old 02-14-2008, 07:45 PM   #5
Phatzilla18
Member#: 86475
2001 Impreza 2.5RS
STM
you may also need to use an orbital buffer and some polish if it's real bad
Old 02-14-2008, 09:12 PM   #6
captianwonderful
Member#: 115109
2003 WRX
blue
wd40 should do it.
captianwonderful is offline   Reply With Quote
Old 02-17-2008, 06:43 PM   #7
jryan87
Member#: 130797
2007 WRX TR
01 Leg GT DD
When I debadged my car, it left very very tiny etch marks in the outline of all the letters...its acually embedded into the paint, not real noticeable at all. hopefully its not the case here, but thats what happened to me
jryan87 is offline   Reply With Quote
Old 02-17-2008, 06:46 PM   #8
whoosh
Member#: 40989
OT vag inspector
the best way is to use the enzymes from your tongue so you don't ruin your paint or wax job.
whoosh is offline   Reply With Quote
Old 02-18-2008, 01:28 PM   #9
Phx Cobra
Member#: 161157
04 STI
Did the claybar this weekend and rewaxed and it looks good. Can't see them anymore at all. Thanks for the advise guys!
Old 02-18-2008, 06:25 PM   #10
Beebs99
Member#: 73803
2008 4 Door WRX
Just incase they come back, hit it with some 3m rubbing compound and then polish and top with wax. I did mine this weekend too and it looks nice.
Beebs99 is offline   Reply With Quote
Old 02-21-2008, 02:56 PM   #11
Phx Cobra
Member#: 161157
04 STI
I think this is how mine is, it rained last night so it got kinda dirty from the road, and the outlines are showing up a bit again.
Going to try rubbing compound this weekend, then claybar again, polish and rewax.
Old 02-21-2008, 03:25 PM   #12
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Dont use any rubbing compound, unless you want to take off the clearcoat
try goof-off,or goo gone a few times.
kevin2.5rs is offline   Reply With Quote
Old 02-21-2008, 03:56 PM   #13
ufslouis
Member#: 142837
MBP
Put on some turtle wax bug and tar remover. Let it sit for like 5 min. Wipe it off and then use a blow drier to heat up the glue. The use your thumb to peal off the glue. Just make sure you don't heat it up too much or you'll get blisters on your thumbs.
Good luck.
ufslouis is offline   Reply With Quote
Old 02-21-2008, 04:43 PM   #14
Phx Cobra
Member#: 161157
04 STI
There is no glue left, like jryan it seems to be etched into the paint(probably from being 4 years old) so hopefully some rubbing compound and maybe a buffer to polish it will smooth it out some.
Old 02-22-2008, 09:03 PM   #15
wrx7886
Member#: 172139
WR blue pearl
try some 3000 grain sandpaper
wrx7886 is offline   Reply With Quote
Old 02-27-2008, 11:39 AM   #16
fabolous
Member#: 169045
How hard is it to actually debadge a car?
I really like the way it looks, but I'm kind of afraid of screwing it up.
Any suggestions? Serious ones would be awesome, but I'm prepared for the flaming!
Thanks.
fabolous is offline   Reply With Quote
Old 02-27-2008, 12:07 PM   #17
injustice
Member#: 142273
2002 WRX Wrb RIP
BMW M3 SSII
I debadged my car this weekend. The glue came off no problem with goo gone. I heated it up first with a blow drier, and took the badges off with dental floss.
However, my problem came when there was a faint outline (not of glue) of the letters. You can only see it at a certain angle when the light reflects off a certain way. It looks as though this outline is etched into the paint, but you can feel the ridges of the outline when you rub your fingers across it. Its really annoying to me and I want it off.
ive searched and searched for an answer. Im going to try a claybar this weekend, but not sure if it will work since it seems the outline is not glue or dirt.
Any other suggestions?
injustice is offline   Reply With Quote
Old 02-27-2008, 12:31 PM   #18
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.......the surface area around an emblem is typically hard to get at and is therefore easily neglected (and susceptible scratches, wax build up, etc.). “De-badging” reveals these flaws and will usually result in a visible border where the emblem once was. You will need to use a mild polish to remove the ghosting effect and restore the finish around the border areas. Personally, I would clay (to help remove any build-up), polish (to help remove the "ghosting"/scratches) and then follow up with your favorite wax.
Kean is offline   Reply With Quote
Old 02-27-2008, 12:35 PM   #19
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
I have that 2. Havent clay bared or buffered yet. Im gonna buffer soon seeing as the weather is getting better and I need to remove some scratches I got from the winter conditions
Super_HKS is offline   Reply With Quote
Old 03-01-2008, 07:04 AM   #20
leafs fan
Member#: 109882
2006 2.5i wagon
2011 Ford Flex
+ 1 for bug and tar remover.
leafs fan is offline   Reply With Quote
Old 03-01-2008, 07:09 PM   #21
iamcgr
Member#: 141685
2002 WRX (ots stg 2)
Had to wetsand mine.
Tried every suggestion availble via search and I could still see it under certain angles.
iamcgr is offline   Reply With Quote
Old 03-03-2008, 12:45 PM   #22
injustice
Member#: 142273
2002 WRX Wrb RIP
BMW M3 SSII
Update:
I was having a problem with the outline of the subaru letters still on my wrb trunk after I debadged it. It wasnt glue but more of an etching into the paint.
I used a clay bar extensively, doing one letter at a time. After I polished, then waxed. It made a HUGE difference. I cannot even see the outline except for at ONE certain angle and in order to see it from there I have to look very very hard.
Yay for clay bar and some elbow grease.
Oh I used Meguiars clay, polish AND wax. Good products.
Removing buildup around "subaru" lettering after debadging? iamcgr Interior & Exterior Modification 11 07-18-2007 01:23 AM
I still need help after debadging :( SoareS Car Care & Detailing 44 12-02-2005 04:17 PM
NXT wax residue appearing after waxing... Why? WR^2X Car Care & Detailing 9 09-18-2005 10:53 PM
subaru letters still seen after debadging... Otaku64 Car Care & Detailing 16 07-18-2002 11:21 PM
Ideas after debadging.. Tats Car Care & Detailing 11 05-01-2001 09:56 PM
