Old 02-14-2008, 08:31 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default timing belt...
ok, finally putting the timing belt on the car, lining up the dashes but the driver side cam pulley is very difficult to line up. should some of the valves still be open or all shut? sorry, tried to search but didnt find all the answers i need.
farrell is offline   Reply With Quote
Old 02-14-2008, 10:04 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya, that side is loaded while you line up the timing marks.
I use a small clamp to hold the belt on the driver side cam pulley. Do that side first. You can also use that thing above the crank timing sprocket to hold the belt in place there. Loosen the bolts, insert belt, push down on the bracket and tighten the bolts a little. It won't move or skip.
Once you get the belt on the driver side and the crank you snake it down under the water pump and over the toothed idler. then move on to the passenger side. you can turn the passenger side pulley to line up the mark on the pulley with the mark on the belt if you need to.
Then you install the tensioner but don't pull the pin.
Next is the upper idler then the lower idler. Turn the passenger side pulley to give you a little slack in the belt if you need it.
Once you have everything installed and you checked the timing marks you want to adjust the gap on that bracket above the crank sprocket. Get a 1/2mm. feeler guage and lay it lengthwise on the belt. Leave enough sticking out either side to grab with a pliers. Push down on the bracket and tighten the two bolts. Remove feeler guage with pliers. You now have 1/2mm gap there and your done guessing how to get an even gap on both sides.
Double check your timing marks and pull the pin on the tensioner. Also, double check that you torqued all the bolts on everything before you put her back together.
Good luck.
Tim Sanderson is offline   Reply With Quote
Old 02-15-2008, 09:28 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
I go a step further and rotate the engine by hand 4-6 revolutions to get the tensioner fully seated and check timing marks against the covers before I crank it up. Just an insurance step against belt slippage. Note that the belt marks won't line up, but the pulley marks should always line up on every other pass.
Fallow the above advice and you'll be good to go.
Jay Storm
Old 02-15-2008, 10:36 AM   #4
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
thank you guys! i got it on.
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 04:05 AM
FS: Gates Racing Timing Belt NEW/ PE timing belt Keo Engine/Power/Exhaust 6 07-04-2008 03:15 AM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
