Old 02-15-2008, 09:29 AM   #1
batchman
Member#: 94656
02 WRX Quicksilver
hums Indiana Jones theme
Question WGDC IAT <-- requires hard reset??
Should I require a hard reset to make a change in WGDC IAT compensation effective?
'02 usdm wrx - Using test release (785?) w/ reset function on logger menu bar. I changed WGDC IAT compensation table and did a "soft" reset from the logger reset menu.
Logged.. didn't see compensation working.
Hard reset this morning.. appears to be working now but hard to tell b/c temp so close to my "0" compensation value.
batchman is offline   Reply With Quote
Old 02-15-2008, 09:33 AM   #2
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
It shouldn't require any resets. I would put a larger negative value in the temp column(s) you are seeing right now, and log for the change to verify.
fujiillin is offline   Reply With Quote
Old 02-15-2008, 11:08 AM   #3
ralli02
Member#: 128687
2004 WRX Wagon
When you changed your WGDC IAT Comp table did you save the map and reflash your ECU?
You didnt mention actually doing the reflash so just wanted to make sure you did that. Happy tuning!
ralli02 is offline   Reply With Quote
OT - Suggest an External Hard Drive! (small, reliable, < $150, under 200GB ok) Hotrodguru Off-Topic 27 11-29-2007 02:57 PM
GOT CROWER CAMS ? <------------ <----------- <---------- <------------- JSC Speed Engine/Power/Exhaust 3 06-03-2006 06:32 AM
Used cars < 02MY :: Why are they so hard to find? dowroa General Community 11 04-17-2006 06:31 PM
A dumb question - sorry - WGDC chucktoo Engine Management & Tuning 2 01-31-2005 02:09 PM
Does a Turbo-Back Require ECU Reset STX_REX Factory 2.0L Turbo Powertrain 3 05-01-2003 06:13 AM
Message Board Statistics All times are GMT -4. The time now is 08:33 AM.
