Old 05-14-2001, 02:44 PM   #1
Ragstylz
Member#: 1266
2005 Outback 2.5XT
White and silver
Question steering wheel shaking
When I go above 60mph, the steering wheel sometimes shakes. Not real bad, but annoying. My car still goes straight, so I thought the wheels needed balancing. I got them balanced and rotated, but it still does it a little bit. What else can be wrong?
Jeff
Ragstylz is offline   Reply With Quote
Old 05-14-2001, 02:46 PM   #2
Habu
Member#: 3052
Post
Alignment.....
Gotta fly!
Skippy
Habu is offline   Reply With Quote
Old 05-14-2001, 02:52 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
definately, have you had an all wheel alignment?
bumped anything - ANYTHING AT ALL....???
this could remedy your issues...
j. www.subiegal.com
Old 05-14-2001, 05:54 PM   #4
slidewaysmike
Member#: 3517
2005 Legacy GT
Post
Another thing that you might try, and you might think this is silly, but it works.
Climb under your car, and run your hand around the entire inner portion of your wheels. Or do it from the outside of each wheel by reaching throught the spokes.
If there is a little bit of mud caked in any of the areas of your wheels, it will give you a shake in your steering wheel.
Clean them all out nicely and see if that helps.
Mike
slidewaysmike is offline   Reply With Quote
Old 05-14-2001, 07:43 PM   #5
BilboWRX
Member#: 6341
Post
Do you remember hitting any potholes lately? Itís possible that you might have bent a rim. This will give you a vibration at speed. This scenario would be more likely with a large wheel/low profile tire set up.
BilboWRX is offline   Reply With Quote
Old 05-14-2001, 07:44 PM   #6
WeRX
Member#: 3652
1989 Honda Pirate
Type RRRRRR
Post
Steering wheel shake can also be caused by bent wheels and flat spotted tires. Try swapping the fronts and rears and see if it goes away.
WeRX is offline   Reply With Quote
Old 05-14-2001, 07:46 PM   #7
Ragstylz
Member#: 1266
2005 Outback 2.5XT
White and silver
Post
i got them rotated with the balancing, still a little shake, i'll try for a wheel alignment...know what's a good price?
Jeff
Old 05-15-2001, 07:22 AM   #8
AWDrivin
Member#: 1687
99 2.5RS
Unhappy
I'm guessing it could still be the balancing. My '99 RS was smooth as silk all 35,000 miles on the RE92s. I just got a set of Kumhos and the car has been exactly like yours ever since. Never had an alignment, but getting new tires shouldn't warrent a new alignment, right? I'm thinking that they did a $hitty balancing job.
Chuck
AWDrivin is offline   Reply With Quote
Old 05-15-2001, 08:37 AM   #9
Keith
Member#: 191
2012 J train
Brown
Post
I'm having the same problem with my RS, but I think its because of the lack of a wheel weight on the front driver side I guess it fell off, but I hit some big potholes with my rs also..so i HOPe its the wheel balancing.
Good luck fixing it
Keith
Keith is offline   Reply With Quote
Old 05-15-2001, 10:32 AM   #10
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Talking
It could also be that your wheels are not torqued down to the same pressure.
TaiChih is offline   Reply With Quote
Old 05-15-2001, 11:45 AM   #11
Buck-O
Guest
Member#:
Post
I had a problem similar to this on my integra.
Had my alignment checked (it needed it anyway), still did it.
Had my tires rotated, still did it.
So i took them back to the tire shop i got them from, and just had them rotated the day before, and asked for the tires to be inspected. Turns out the tire i had was improperly manufactured, and there was a lump of rubber on the inside wall of the tire. And while the rotating would counter this. The hard spot in the tire was VERY noticable at speed.
Might be somthing to have looked at as well.
Old 05-15-2001, 04:01 PM   #12
goose
Member#: 3578
Post
got the same problem... just had my rims powdercoated and put back on- suspecting shaety balancing as the culprit- all though one of my rims had a mild curbing incident about a month before the coating... let me know how things go with you and I'll pass along anything I pick up ok?
goose is offline   Reply With Quote
Old 05-15-2001, 07:02 PM   #13
Ragstylz
Member#: 1266
2005 Outback 2.5XT
White and silver
Post
Well, I curbed the rear wheel a couple of weeks ago(just not paying attention), but would the rear be able to cause the steering wheel to shake? And for some reason, it really only happens in the morning, and only aournd 60mph, higher or lower than that and nothing, really odd. I would get it aligned if I knew that was the problem, but since it's on and off like this, I don't know
Jeff
Old 05-16-2001, 12:30 AM   #14
Star*Child
Member#: 5659
Post
I was driving muddy/snowy roads at speed and collected some mud on the inside walls of my wheels. On the freeway it would shake and get worse as I got faster (70+).
I cleaned out the mud from the inside of the wheels and no more shake
Star*Child is offline   Reply With Quote
Steering Wheel Shake WRXURV8 Brakes, Steering & Suspension 11 08-26-2002 09:59 PM
steering wheel shaking problem ezatnova Brakes, Steering & Suspension 5 07-22-2002 12:23 PM
what could this be? When I am at speed, the steering wheel shakes a little wrxxtc Brakes, Steering & Suspension 5 06-19-2002 05:23 PM
Steering Wheel Shaking at 70-75mph Rozos Brakes, Steering & Suspension 6 10-09-2001 03:09 PM
Got rims now steering wheel shakes WRXThis Brakes, Steering & Suspension 11 05-21-2001 06:22 AM
