Old 02-16-2008, 05:28 AM   #1
CCTXRS
Member#: 158181
2001 Impreza RS
Default clutch adjustment/ clutch problems
on hydro man trans. do you need to adjust the clutch the more it wears down? if not i have a problem and idk what it is
alright so i got my 01 Rs about 5 months ago... and ever sense i had it ive had a few problems with my clutch. Well i could push down the peddle all the way to the floor and seriously i let off a centimeter and it would start to engage. That and the slave cylinder piston was not fully pressed against the throw out fork. So i get under the dash and i ajust the rod that gos to the master cylinder all the way out. Then i had to adjust the clutch peddle a lil bit in to have the slave piston fully pressured to the fork plate. or w/e its called. Is this normal.... or what could be the problem. Any help would be greatly appreciated cause i know little about transmissions....
CCTXRS is offline   Reply With Quote
Old 02-16-2008, 09:01 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you can adjust the pedals, but for a hydraulic clutch (master+slave) there's nothing else to adjust
Old 02-16-2008, 10:36 AM   #3
CCTXRS
Member#: 158181
2001 Impreza RS
ok well you can adjust the peddle yes... then there is a silver rod that gos through the firewall that i believe go's to the master cylinder.... it is ajustiable also... i adjusted it.
look here... on part A
http://phunkadelic.org/WRX/4_-_Transmission.pdf
go to clutch system
then master cylinder.
theres a pic there the first one and you can see that is for sure adjustable
Old 02-16-2008, 10:56 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is only one adjustment, the master cylinder pushrod length. This is only supposed to be used to initially set the proper pedal travel and freeplay, and is NOT intended to be used as a means to compensate for wear. As the clutch disc wears and nears the end of its life, the engagement point on the pedal will get higher. This is a sign that the clutch should be replaced soon.
An engagement point too close to the floor, especially when accompanied by excess free play or a soft pedal, indicates a problem with the hydraulic system. This can be as simple as trapped air, which can be corrected by bleeding, or more serious as in a bad master or slave cylinder.
Old 02-16-2008, 04:45 PM   #5
CCTXRS
Member#: 158181
2001 Impreza RS
see i thought that it was self adjusting myself... there for i was kinda weirded out by having to adjust so much crap. Now which should i replace first... master cylinder or slave...
ive tried bleedin it and there was no air in the line from what i saw.
Old 02-16-2008, 07:41 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you've bled the system and still have a soft pedal, it's best to replace both the master and slave at the same time. This is because you usually can't tell which one is actually bad (unless it is visibly leaking), and also because when only one is replaced the other one will typically fail shortly afterward.
Old 02-17-2008, 12:26 AM   #7
CCTXRS
Member#: 158181
2001 Impreza RS
hmm good call. thx
Old 01-03-2010, 10:41 PM   #8
95preza
Member#: 233965
2011 WRB WRX
2000 Impreza L
I think I have a similar problem, I just got a 95 Impreza, 1.8, 5spd, AWD, the clutch engages within the first 1/4 of releasing it, other than that everything is fine. So Im wondering what excess free play and soft pedal is?
95preza is offline   Reply With Quote
Old 01-03-2010, 11:41 PM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
The 95 is cable operated and easy to adjust. Go under the hood and look at the fork with the cable attached to it. Push the fork toward the back of the car and note how much cable slack you have. Tighten the nuts so that they remove (almost all) the slack. I try to keep it to where I can slightly wiggle the fork forward/backward, but no more than 1/8" of free play.
Jay
Old 01-04-2010, 12:11 AM   #10
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
^^ Good advice +1
sense of nature is offline   Reply With Quote
Old 01-04-2010, 10:18 PM   #11
95preza
Member#: 233965
2011 WRB WRX
2000 Impreza L
That worked perfectly, thank you!!
is the clutch adjustable?? new clutch help!!! JT's06sti Transmission (AT/MT) & Driveline 4 05-29-2009 10:13 PM
New clutch? or adjust clutch? rack Alaskan Impreza Club Forum -- AKIC 13 02-26-2006 03:33 AM
New Clutch or Clutch Adjustment Sherb Transmission (AT/MT) & Driveline 0 11-25-2002 11:11 AM
Clutch Adjustment philrb Normally Aspirated Powertrain 6 12-13-2000 09:51 PM
Clutch Adjustment philrb South West Impreza Club Forum -- SWIC 1 12-12-2000 09:36 AM
