Old 02-16-2008, 05:26 PM   #1
Psyklon
Member#: 80155
1998 OBS
Default SVX crank pulley Help!
My crank pulley on my 1992 svx awd broke, and fell off today. I do have an underdrive pulley sitting around from my impreza that i never installed.
Does anyone now if the svx and imprezas have the same belts, or what belts i would need to make this pulley work on the svx. I know the pulley should just bolt right on. It is a bomz racing aluminum underdrive pulley.
I have tried searching for this, but cant find much. Any help would be greatly appreciated, as i need to get my car running again soon, its my daily driver for now.
Psyklon is offline   Reply With Quote
Old 02-16-2008, 06:53 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
best thing you could do is match it up, try it. it probably will take less time to try it out then it will to get a response on here from some one who knows for sure.
flstffxe is offline   Reply With Quote
Old 02-17-2008, 10:49 AM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
yeah, throw it on, see if the belt will tension up.. its not a timing belt so i wouldnt get too worried if it wasnt a perfect fit until you can get the correct size belt to fit your frankenpulley setup.
Old 02-17-2008, 12:12 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
So long as the ribs, inner bore and keyway match....put it on. You'll probably have to use a shorter belt, as you would on an Impreza.
Old 02-17-2008, 12:39 PM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
first off.... how the hell did your stock pulley break and fall off ???
IllNastyImpreza is offline   Reply With Quote
Old 02-17-2008, 01:11 PM   #6
flstffxe
Member#: 155358
2008 Forester
Steel Silver
age, vibration it happens, not often but it does happen.
Old 02-17-2008, 10:23 PM   #7
Psyklon
Member#: 80155
1998 OBS
Yeah its a 92 with 167k on it, so that may have something to do with it. I just bought some belts today, going to install everything tomorrow.
Thanks for the help.
Perrin Lightweight crank pulley... help bstdwgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-24-2009 12:14 AM
lightened crank pulley help! humperdinc Newbies & FAQs 6 09-11-2009 05:57 PM
perrin crank pulley HELP!!! hackisacker Newbies & FAQs 2 06-30-2007 02:40 PM
I will trade my perrin crank pulley for a stock crank pulley NITROS Mid West Subaru Owners Club Forum -- MWSOC 8 07-21-2006 10:51 AM
Perrin Crank Pulley Vs Unorthodox Racing Ultra S lightened underdrive crank pulley west_minist Normally Aspirated Powertrain 3 02-21-2005 11:56 PM
